Thema: RobotLoader: Wifi Terminal -> Kleinbuchstaben?
    NRW
    Hallo Leute,
    ich habe ein Programm für die M256 getestet, bei dem ich Text im Wifi Terminal des RobotLoaders eingeben und dann im Programm auswerten muss.
    Dabei kommen wohl eingetippte Großbuchstaben im Programm nicht an bzw. nur als Kleinbuchstaben.
    Habt ihr das auch bei euch so oder liegt's an mir?
    Geändert von Dirk (18.08.2012 um 21:40 Uhr)
    Dirk
    NRW
    Fehlte noch ...:
    Testprog.c
    // Includes:
    #include "RP6M256Lib.h"      // The RP6 M256 Library.
               // Always needs to be included!
    // Variables:
    // Reception buffer for the function getInputLine_WIFI():
    char receiveBufferWifi[UART_RECEIVE_BUFFER_SIZE_WIFI + 1];
    // WIFI receive functions:
     * Get chars of an input line from the WIFI.
     * Returns 0 (false), if the WIFI receive buffer is empty
     * OR a character of the input line has been received.
     * Returns 1, if the whole input line has been received
     * (with a "new line" character at the end).
     * Returns 2, if the WIFI receive buffer overflows.
     * The input line is stored in the receiveBufferWifi array.
    uint8_t getInputLine_WIFI(void)
    {static uint16_t buffer_pos = 0;
     if(getBufferLength_WIFI()) {
      receiveBufferWifi[buffer_pos] = readChar_WIFI();
      if((receiveBufferWifi[buffer_pos] == '\n')
       || (receiveBufferWifi[buffer_pos] == '\r')) {
       receiveBufferWifi[buffer_pos] = '\0';
       buffer_pos = 0;
       return 1;
      else if(buffer_pos >= UART_RECEIVE_BUFFER_SIZE_WIFI) {
       receiveBufferWifi[UART_RECEIVE_BUFFER_SIZE_WIFI] = '\0';
       buffer_pos = 0;
       return 2;
      buffer_pos++;
     return 0;
     * Get a complete input line from the WIFI.
     * This function waits for a whole input line from the WIFI.
     * The input line is stored in the receiveBuffer array.
     * The function is blocking until one of the two following
     * conditions occurs:
     * - A "new line" character has been received at the end of
     *   the input line.
     * - The WIFI receive buffer overflows.
    void enterString_WIFI(void)
     while(!getInputLine_WIFI());
    // Main function - The program starts here:
    int main(void)
     initRP6M256();    // Always call this first! The Processor will not work
           // correctly otherwise.
     initLCD(); // Initialize the LC-Display (LCD)
          // Always call this before using the LCD!
     setLEDs(0b0000);
     clearLCD(); // Clear the whole LCD Screen
    // Main test program:
     while(true)
      writeString_P_WIFI("\n\n");
      writeString_P_WIFI("\n|============================|");
      writeString_P_WIFI("\n| WIFI: Input a test string  |\n");
      enterString_WIFI();
      clearLCD();
      writeStringLCD(receiveBufferWifi);
      mSleep(10000);
    // End of main:
     return 0;
    Geändert von Dirk (19.08.2012 um 08:05 Uhr)
    Dirk
    Paderborn
    Hi Dirk,
    danke für den Bug Report, da war noch eine Konvertierung auf lowercase drin.
    Die nächste RobotLoaderVersion wird das korrigieren.
    MfG,
    SlyD
  1. RobotLoader 2.3a
    Von SlyD im Forum Robby RP6
    Antworten: 44
    Letzter Beitrag: 01.05.2013, 10:15
  2. Frage zu Wifi Modul
    Von toter_fisch im Forum Elektronik
    Antworten: 0
    Letzter Beitrag: 06.08.2012, 14:04
  3. RP6v2 M256 WiFi !?
    Von Dirk im Forum Robby RP6
    Antworten: 20
    Letzter Beitrag: 11.05.2012, 19:27
  4. ARM für WiFi steuerung ?
    Von fat tony im Forum ARM - 32-bit-Mikrocontroller-Architektur
    Antworten: 5
    Letzter Beitrag: 03.01.2010, 13:57
  5. Wifi Roboter
    Von newName im Forum Allgemeines zum Thema Roboter / Modellbau
    Antworten: 4
    Letzter Beitrag: 16.01.2008, 13:51
