Thema: Probleme beim Compilieren
    Leider habe ich mal wieder ein Problem. Ich habe in der AsuroWiki das Beispielprogramm: "Kollisiontest mit den Tastsensoren" ausprobieren wollen doch beim compilieren schreibt er folgendes hin:
    C:\Asuro\ASURO_src\FirstTry>make all
    set -e; avr-gcc -MM -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=asuro.lst asuro.c \
    | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > asuro.d; \
    [ -s asuro.d ] || rm -f asuro.d
    C:\Users\Michael\AppData\Local\Temp\make384562.sh: /c/WinAVR/bin/avr-gcc: Invalid argument
    set -e; avr-gcc -MM -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=test.lst test.c \
    | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > test.d; \
    [ -s test.d ] || rm -f test.d
    C:\Users\Michael\AppData\Local\Temp\make384563.sh: /c/WinAVR/bin/avr-gcc: Invalid argument
    -------- begin --------
    avr-gcc --version
    avr-gcc (GCC) 3.3.1
    Copyright (C) 2003 Free Software Foundation, Inc.
    This is free software; see the source for copying conditions. There is NO
    warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
    avr-gcc -c -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=test.lst test.c -o test.o
    test.c: In function `main':
    test.c:73: warning: implicit declaration of function `Msleep'
    avr-gcc -c -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=asuro.lst asuro.c -o asuro.o
    avr-gcc -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=test.o test.o asuro.o --output test.elf -Wl,-Map=test.map,--cref -lm
    test.o(.text+0xa4): In function `main':
    C:\Asuro\ASURO_src\FirstTry/test.c:73: undefined reference to `Msleep'
    make: *** [test.elf] Error 1
    > Process Exit Code: 2
    Da ich noch sehr unerfahren in der Welt des Programmierens bin, würde ich mich freuen wenn ihr mir dabei helfen könntet. Ich arbeite mit dem Programmers Notepad und mein Compilierer ist der AVR Insight. Ich bin mir nicht sicher ob der Compiler richtig ist.
    Geändert von ActiveRobo (28.07.2012 um 12:29 Uhr)
    Lg ActiveRobo
    Visit this homepages: www.ikakrieger.siteboard.eu or: www.castleserver.net
    Hey Leute,
    Ihr würdet mir echt helfen wenn ihr mir antwortet. Und ich hätte noch eine Frage. Ich soll als Aufgabe ein Programm schreiben, dass meinen Asuro geradeaus fahren lässt und wenn er dann auf eine schware Linie trifft, dann soll er stehen bleiben und blinken. Nur im Moment weiß ich nicht wie ich das anstellen soll. Ich bin wirklich ein Anfänger auf dem Gebiet der Programmierung. Also währe es echt nett von euch wenn ihr mir helfen könntet.
    Lg ActiveRobo
    Fulda
    Hallo ActiveRobo,
    na dann wollen wir mal Dein Problem angehen.
    In dem Compiler- Output stehen mehrere Fehler, die wir erst mal beheben müssen.
    "test.c:73: warning: implicit declaration of function `Msleep'"
    bedeutet, dass Du die Funktion "Msleep" benutzt, bevor sie deklariert wurde.
    Kannst Du den Code (test.c) hier mal posten, oder mir per PN zukommen lassen, dann schaue ich Ihn mal durch.
    Deine zweite Frage gehen wir dann an, wenn Du Deinen aktuellen Code ohne Fehler compilieren kannst.
    Viele Grüße
    Stefan
    Zu: "test.c:73: warning: implicit declaration of function `Msleep'" siehe https://www.roboternetz.de/community...l=1#post555474
    zu: "C:\Users\Michael\AppData\Local\Temp\make384563.sh : /c/WinAVR/bin/avr-gcc: Invalid argument" ist schon kniffeliger. Wer bekommt das "Invalid argument"?
    In der Komandozeile eingegeben erhält man dies:
    D:\mic\KamAVR\asuro>set -e; avr-gcc -MM -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=test.lst test.c | sed ',\(.*\)\.o[ :]*,\1.o\1.d : ,g' > test.d; [ -s test.d ] || rm -f test.d
    sed: invalid option -- s
    Usage: sed [OPTION]... {script-only-if-no-other-script} [input-file]...
      -n, --quiet, --silent
                     suppress automatic printing of pattern space
      -e script, --expression=script
                     add the script to the commands to be executed
      -f script-file, --file=script-file
                     add the contents of script-file to the commands to be executed
      -c  --nocr     turn off \r$ translation; must be first switch on command line
          --help     display this help and exit
      -V, --version  output version information and exit
    If no -e, --expression, -f, or --file option is given, then the first
    non-option argument is taken as the sed script to interpret.  All
    remaining arguments are names of input files; if no input files are
    specified, then the standard input is read.
    E-mail bug reports to: bug-gnu-utils@gnu.org .
    Be sure to include the word ``sed'' somewhere in the ``Subject:'' field.
    Blau ist die Eingabezeile aus dem Makefile (im Orginal ist sie mit \ auf mehrere Zeilen verteilt), rot die Fehlermeldung. Der Befehl "sed" steckt in der Eingabe hinter dem | (Pipe). Aber bevor wir da lange rumsuchen, mit dem orginalen firsttry-makefile und allen Dateien in einem Verzeichniss funktioniert es bei mir:
    D:\mic\KamAVR\asuro>dir
     Datenträger in Laufwerk D: ist Files
     Volumeseriennummer: FC70-2BAE
     Verzeichnis von D:\mic\KamAVR\asuro
    30.07.2012  13:44    <DIR>          .
    30.07.2012  13:44    <DIR>          ..
    19.12.2005  12:38             7.680 asuro.c
    30.07.2012  12:33             4.876 asuro.h
    30.07.2012  13:44    <DIR>          lib
    19.12.2005  16:15             7.297 makefile
    30.07.2012  12:32                79 test.c
                   4 Datei(en),         19.932 Bytes
                   3 Verzeichnis(se), 841.583.415.296 Bytes frei
    D:\mic\KamAVR\asuro>make all
    set -e; avr-gcc -MM -mmcu=atmega8 -I. -g -Os -I../../lib/inc -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=asuro.lst asuro.c \
    set -e; avr-gcc -MM -mmcu=atmega8 -I. -g -Os -I../../lib/inc -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=test.lst test.c \
    avr-gcc --version
    avr-gcc (WinAVR 20100110) 4.3.3
    Copyright (C) 2008 Free Software Foundation, Inc.
    avr-gcc -c -mmcu=atmega8 -I. -g -Os -I../../lib/inc -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=test.lst test.c -o test.o
    avr-gcc -c -mmcu=atmega8 -I. -g -Os -I../../lib/inc -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=asuro.lst asuro.c -o asuro.o
    avr-gcc -mmcu=atmega8 -I. -g -Os -I../../lib/inc -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=test.o test.o asuro.o   --output test.elf -Wl,-Map=test.map,--cref -lm
    avr-objcopy -O ihex -R .eeprom test.elf test.hex
    avr-objcopy -j .eeprom --set-section-flags=.eeprom="alloc,load" \
            --change-section-lma .eeprom=0 -O ihex test.elf test.eep
    d:\WinAVR-20100110\bin\avr-objcopy.exe: --change-section-lma .eeprom=0x00000000 never used
    avr-objdump -h -S test.elf > test.lss
    Size after:
    test.elf  :
    section           size      addr
    .text             1692         0
    .bss                 1   8388704
    .debug_aranges      64         0
    .debug_pubnames    263         0
    .debug_info       1060         0
    .debug_abbrev      401         0
    .debug_line       1120         0
    .debug_frame       288         0
    .debug_str         358         0
    .debug_loc         388         0
    Total             5635
    Errors: none
    -------- end --------
    30.07.2012  13:45    <DIR>          .
    30.07.2012  13:45    <DIR>          ..
    30.07.2012  13:45                34 asuro.d
    30.07.2012  13:45            97.555 asuro.lst
    30.07.2012  13:45             9.840 asuro.o
    30.07.2012  13:45                31 test.d
    30.07.2012  13:45                13 test.eep
    30.07.2012  13:45             9.131 test.elf
    30.07.2012  13:45             4.775 test.hex
    30.07.2012  13:45            43.485 test.lss
    30.07.2012  13:45            11.353 test.lst
    30.07.2012  13:45            35.440 test.map
    30.07.2012  13:45             2.260 test.o
                  15 Datei(en),        233.849 Bytes
                   3 Verzeichnis(se), 841.583.185.920 Bytes frei
    Den Code kannst du dir unter diesem Link anschauen: http://www.asurowiki.de/pmwiki/pmwik...ollisionsTestC
    Lg ActiveRobo
  1. Problem beim Compilieren
    Von KingKaiser im Forum Asuro
    Antworten: 9
    Letzter Beitrag: 15.01.2012, 19:02
  2. Probleme beim Compilieren
    Von Coop im Forum C - Programmierung (GCC u.a.)
    Letzter Beitrag: 19.11.2010, 23:47
  3. Probleme beim compilieren
    Von Ananas im Forum Bauanleitungen, Schaltungen & Software nach RoboterNetz-Standard
    Letzter Beitrag: 15.09.2010, 15:49
  4. Gelöst: NIBObee Liniensensoren: Probleme beim Compilieren
    Von DerDudeESP im Forum Sonstige Roboter- und artverwandte Modelle
    Antworten: 5
    Letzter Beitrag: 06.03.2010, 13:27
  5. WinFact Probleme beim compilieren
    Von Robo14 im Forum Sonstige Roboter- und artverwandte Modelle
    Antworten: 0
    Letzter Beitrag: 10.05.2006, 08:30
