Werbung
Schaut ruhig mal auf meiner Homepage vorbei:
http://kampis-elektroecke.de
Oder folge mir auf Google+:
Daniel Kampert
Daniel
Sodele
mein Script sieht so aus:
und dann fügst du einfach unterCode:#!/bin/sh echo "0" > /sys/class/gpio/export echo "1" > /sys/class/gpio/export echo "4" > /sys/class/gpio/export echo "7" > /sys/class/gpio/export echo "8" > /sys/class/gpio/export echo "9" > /sys/class/gpio/export echo "10" > /sys/class/gpio/export echo "11" > /sys/class/gpio/export echo "14" > /sys/class/gpio/export echo "15" > /sys/class/gpio/export echo "17" > /sys/class/gpio/export echo "18" > /sys/class/gpio/export echo "21" > /sys/class/gpio/export echo "22" > /sys/class/gpio/export echo "23" > /sys/class/gpio/export echo "24" > /sys/class/gpio/export echo "25" > /sys/class/gpio/export echo "out" > /sys/class/gpio/gpio0/direction echo "out" > /sys/class/gpio/gpio1/direction echo "out" > /sys/class/gpio/gpio4/direction echo "out" > /sys/class/gpio/gpio7/direction echo "out" > /sys/class/gpio/gpio8/direction echo "out" > /sys/class/gpio/gpio9/direction echo "out" > /sys/class/gpio/gpio10/direction echo "out" > /sys/class/gpio/gpio11/direction echo "out" > /sys/class/gpio/gpio14/direction echo "out" > /sys/class/gpio/gpio15/direction echo "out" > /sys/class/gpio/gpio17/direction echo "out" > /sys/class/gpio/gpio18/direction echo "out" > /sys/class/gpio/gpio21/direction echo "out" > /sys/class/gpio/gpio22/direction echo "out" > /sys/class/gpio/gpio23/direction echo "out" > /sys/class/gpio/gpio24/direction echo "out" > /sys/class/gpio/gpio25/direction chmod 666 /sys/class/gpio/gpio0/value chmod 666 /sys/class/gpio/gpio1/value chmod 666 /sys/class/gpio/gpio4/value chmod 666 /sys/class/gpio/gpio7/value chmod 666 /sys/class/gpio/gpio8/value chmod 666 /sys/class/gpio/gpio9/value chmod 666 /sys/class/gpio/gpio10/value chmod 666 /sys/class/gpio/gpio11/value chmod 666 /sys/class/gpio/gpio14/value chmod 666 /sys/class/gpio/gpio15/value chmod 666 /sys/class/gpio/gpio17/value chmod 666 /sys/class/gpio/gpio18/value chmod 666 /sys/class/gpio/gpio21/value chmod 666 /sys/class/gpio/gpio22/value chmod 666 /sys/class/gpio/gpio23/value chmod 666 /sys/class/gpio/gpio24/value chmod 666 /sys/class/gpio/gpio25/value chmod 666 /sys/class/gpio/gpio0/direction chmod 666 /sys/class/gpio/gpio1/direction chmod 666 /sys/class/gpio/gpio4/direction chmod 666 /sys/class/gpio/gpio7/direction chmod 666 /sys/class/gpio/gpio8/direction chmod 666 /sys/class/gpio/gpio9/direction chmod 666 /sys/class/gpio/gpio10/direction chmod 666 /sys/class/gpio/gpio11/direction chmod 666 /sys/class/gpio/gpio14/direction chmod 666 /sys/class/gpio/gpio15/direction chmod 666 /sys/class/gpio/gpio17/direction chmod 666 /sys/class/gpio/gpio18/direction chmod 666 /sys/class/gpio/gpio21/direction chmod 666 /sys/class/gpio/gpio22/direction chmod 666 /sys/class/gpio/gpio23/direction chmod 666 /sys/class/gpio/gpio24/direction chmod 666 /sys/class/gpio/gpio25/direction
/etc/init.d/rc.local
am Ende ./Pfad + Name deines Shellscripts ein.
Daniel Kampert
Daniel
Klappt 1a, danke..
Sollen wir das Script vllt noch mit ins Wiki nudeln, unter GPIO ansteuerung?
Daniel Kampert
Daniel
Mach ruhig, ich bau erst mal mein PHP Script entsprechend um. ^_^
Ok ^.^
Am Wochenende schreibe ich mal ein paar Zeilen dazu.
Aber mal ne theoretische Frage.....
Wenn ich ein I²C Device auslesen will z.B. eine RTC kann ich ja ein C-Programm schreiben, welches die Kommunikation mit der RTC über I²C bewerkstelligt.
Die Uhrzeit kann ich dann ja mittels "Print"-Funktion in der Shell ausgeben lassen.
Nun kann ich in PHP ja auch über Shell_exec einen Befehl in der Shell ausführen lassen, sprich ich kann mittels PHP mein Programm zum auslesen der RTC starten und das was normalerweise per "Print" auf der Shell ausgegeben wird in eine Variable speichern und diese Variable dann mittels PHP im Browser anzeigen lassen.
Sehe ich das so richtig, dass das theoretisch funktionieren würde?
Oder ist da irgendwo ein Haken von dem ich gerade nichts weiß?
Geändert von Kampi (19.07.2012 um 08:14 Uhr)
Daniel Kampert
Daniel
