Ergebnis 1 bis 10 von 182
Thema: Diskussion zum RP6 M256 WIFI Modul
Baum-Darstellung
  1. #27
    Max Web
    Edit: Scheinbar ist es doch nicht ganz so einfach... Hier die Log-Datei:
    RobotLoader is ready to go.
    #### Network close all...
    #### Network close all done!
    #### BEGIN CONNECT TO: 192.168.2.60:2000
    Network Connection Timeout ERROR (101)  ||| Network Connection attempt timed out!
    #### DISCONNECTED
    #### CONNECTED TO HOST: 192.168.2.60:2000
    Try to get ID...
    Reset Microcontroller...
    WAIT RESPONSE TIMEOUT!!!! RETRY FAILURE!  Please run again manually!
    Enter CMD Mode not OK, try again...
    ############# NETLOAD TIMEOUT!
    Reconnect...
    Connection interrupted!
    RESET MCU FAILED! CONNECTION ERROR!
    ########### Action failed! Abort. Please retry manually. If this fails, check settings!
    #### DISCONNECTED
    Nach Reset+Enable Passthrough kommt:
    WiFly Ver 2.32, 02-13-2012 on RN-171
    MAC Addr=00:06:66:72:03:4d
    Auto-Assoc ***************** chan=1 mode=************ SCAN OK
    Joining ****************** now..
    *READY*
    Associated!
    Using Static IP
    Listen on 2000
    Und hier der Rest:
    Enter Command Mode...
    CMD
    # show rssi
    show rssi
    RSSI=(-48 ) dBm
    <2.32>
    # show net
    show net
    SSid=***********************
    Chan=1
    Assoc=OK
    Rate=8, 6 Mb
    Auth=OK
    Mode=*******
    DHCP=OK
    Boot=147
    Time=FAIL
    Links=1
    <2.32>
    # show status
    show status
    Conns=0, WRX=0/0, WTX=0/0, RTRY=0, RTRYfail=0
     URX=6, UTX=279, RXdrop=0, RXerr=0,
    FlwSet=0, FlwClr=0
     TX-UDP=0, netbufs=0, evt=0, adhoc_lost=0
    Boots=1, Wdogs=0,TXon=1
    <2.32>
    # get wlan
    get wlan
    SSID=******************
    Chan=0
    ExtAnt=0
    Join=1
    Auth=*********
    Mask=0x1fff
    Rate=8, 6  Mb
    Linkmon=5
    Passphrase=******
    TxPower=0
    <2.32>
    # get ip
    get ip
    IF=UP
    DHCP=OFF
    IP=192.168.2.60:2000
    NM=255.255.255.0
    GW=192.168.2.1
    HOST=0.0.0.0:2000
    PROTO=TCP,
    MTU=1524
    FLAGS=0x7
    TCPMODE=0x0
    BACKUP=0.0.0.0
    <2.32>
    # get comm
    get comm
    OPEN=*OPEN*
    CLOSE=*CLOS*
    REMOTE=
    FlushSize=1024
    MatchChar=0
    FlushTimer=10
    IdleTimer=0
    CmdChar=$
    <2.32>
    # scan
    scan
    <2.32>
    SCAN:Found 5
    Num            SSID   Ch  RSSI   Sec    MAC Address    Suites
     Andere Netzwerke habe ich rausgenommen!
     2     ****************  01 -47 WPA2PSK ********************* AESM-AES  WPSPB 3100
    Den Router habe ich auch neu gestartet, wie gesagt ohne Erfolg... Mal geht es, mal geht es nicht - und vor Kurzem ging es noch problemlos.
    Geändert von Max Web (20.07.2012 um 13:08 Uhr)
  1. [ERLEDIGT] Kostenlose RP6 M256 WIFI Module für Testanwender!
    Von SlyD im Forum Robby RP6
    Antworten: 10
    Letzter Beitrag: 02.07.2012, 15:24
  2. RP6v2 M256 WiFi !?
    Von Dirk im Forum Robby RP6
    Antworten: 20
    Letzter Beitrag: 11.05.2012, 19:27
  3. ARM für WiFi steuerung ?
    Von fat tony im Forum ARM - 32-bit-Mikrocontroller-Architektur
    Letzter Beitrag: 03.01.2010, 13:57
  4. Wifi Roboter
    Von newName im Forum Allgemeines zum Thema Roboter / Modellbau
    Letzter Beitrag: 16.01.2008, 13:51
  5. Formate zur Diskussion
    Von sonic im Forum Konstruktion/CAD/3D-Druck/Sketchup und Platinenlayout Eagle & Fritzing u.a.
    Antworten: 24
    Letzter Beitrag: 03.08.2004, 18:41
