der DS2450 16bit 1Wire ADC kannst Du als Wandler nehmen. Diesen kannst Du Dir auch als kostenloses Sample von Michrochip zuschicken lassen. Mit diesem kannst Du eine Auflösung von 16 bit erreichen. Wichtig ist hier nur Dein Platinenlayout, dieses muss sehr genau und gut entwickelt sein , um eine gute Wandlung hinzubekommen (Rauschminimierung, Wandlergenauigkeit).
Hier ist mein verwendeter Code in Bascom:
Code:Declare Sub Crc_get() Const 1w_readmem = &HAA Const 1w_writemem = &H55 Const 1w_convertch = &H3C Const 1w_readrom = &H33 Const 1w_matchrom = &H55 Const 1w_skiprom = &HCC Const 1w_searchrom = &HF0 Const 1w_conditsrc = &HEC Const 1w_ovdrvskprom = &H3C Const 1w_ovdrvmtchrom = &H69 Const 1w_vccoperation = &H40 1wreset 'reset the device 1wwrite 1w_skiprom 'Skip ROM 1wwrite 1w_writemem 'Write Memory 1wwrite &H1C 'Write to 001C 1wwrite &H00 1wwrite 1w_vccoperation 'VCC Operation keeps device active!! Crc_get 'Read in 2 bytes 16bits Crc_dummy = 1wread(1) 'read dummy byte 1wreset 'reset the device 'Write to locations beginning at 00 08 1wwrite 1w_skiprom 'Skip ROM 1wwrite 1w_writemem 'Write Memory 1wwrite &H08 'Write to 00 08 1wwrite &H00 ' Set up Channel A for 16 bit resolution 1wwrite &H00 '16 bit resoultion Crc_get 'Read in 2 bytes 16bits Crc_dummy = 1wread(1) 'read dummy byte ' 5.12 Volt range 1wwrite &H00 '5.12 Volt Range Crc_get 'Read in 2 bytes 16bits Crc_dummy = 1wread(1) 'read dummy byte ' Set up Channel B for 16 bit resolution 1wwrite &H00 '16 bit resoultion Crc_get 'Read in 2 bytes 16bits Crc_dummy = 1wread(1) 'read dummy byte ' 5.12 Volt range 1wwrite &H01 '5.12 Volt Range Crc_get 'Read in 2 bytes 16bits Crc_dummy = 1wread(1) 'read dummy byte ' Set up Channel C for 16 bit resolution 1wwrite &H00 '16 bit resoultion Crc_get 'Read in 2 bytes 16bits Crc_dummy = 1wread(1) 'read dummy byte ' 5.12 Volt range 1wwrite &H01 '5.12 Volt Range Crc_get 'Read in 2 bytes 16bits Crc_dummy = 1wread(1) 'read dummy byte ' Set up Channel D for 16 bit resolution 1wwrite &H00 '16 bit resoultion Crc_get 'Read in 2 bytes 16bits Crc_dummy = 1wread(1) 'read dummy byte ' 5.12 Volt range 1wwrite &H01 '5.12 Volt Range Crc_get 'Read in 2 bytes 16bits Crc_dummy = 1wread(1) '( Set up Channel C for output 1 1wwrite &HC0 'Output Open/Output OFF C0 is OFF 80 is ON Crc_get 'Read in 2 bytes 16bits Crc_dummy = 1wread(1) 'read dummy byte ' 5.12 Volt range 1wwrite &H00 'Doesn't matter space keeper Crc_get 'Read in 2 bytes 16bits Crc_dummy = 1wread(1) 'read dummy byte ' Set up Channel D for output 0 1wwrite &HC0 'Output Open/Output OFF Crc_get 'Read in 2 bytes 16bits Crc_dummy = 1wread(1) 'read dummy byte ' 5.12 Volt range 1wwrite &H00 'Doesn't matter space keeper Crc_get 'Read in 2 bytes 16bits Crc_dummy = 1wread(1) ') '******************************************************************************* '------------------ D S 2 4 5 0 --------------------- 1wreset 'reset the device 1wwrite 1w_skiprom '&HCC Skip ROM 1wwrite 1w_convertch '&H3C Begin Conversion 1wwrite &H0F 'Convert Mask 0000|DCBA ie 0F=0000|1111 1wwrite &H00 '0 'Preset Mask Set=D Clear=d DdCcBbAa ie 55=0101|0101 Crc_get 'Read in 2 bytes 16bits Waitms 6 'use formula to calculate exact duration for channels 1wreset 'reset the device 1wwrite 1w_skiprom 'Skip ROM 1wwrite 1w_readmem 'Read Memory 1wwrite &H00 'Read Channel A 1wwrite &H00 'Address 0000 and 0001 For I_x = 1 To 4 Lowbyte(i_x) = 1wread(1) Highbyte(i_x) = 1wread(1) Waitms 5 Adval_adc1 = Makeint(lowbyte(1) , Highbyte(1)) 'PSG 500 Adval_adc2 = Makeint(lowbyte(2) , Highbyte(2)) 'CDG 45 Adval_adc3 = Makeint(lowbyte(3) , Highbyte(3)) 'PCG 400 Adval_adc4 = Makeint(lowbyte(4) , Highbyte(4)) 'Print Adval_adc1 ; Spc(3) ; Adval_adc2 'IKR Next
Leider gibt es den AD nicht in Dip Version, nur in SMD.
Gruß MAT
Zitieren
