Danke, wieder mal was gelernt:
Code:/** * @brief Put string from program memory to ringbuffer for transmitting via UART. * * The string is buffered by the UART library in a circular buffer * and one character at a time is transmitted to the UART using interrupts. * Blocks if it can not write the whole string into the circular buffer. * * @param s program memory string to be transmitted * @return none * @see uart_puts_P */ extern void uart_puts_p(const char *s ); /** * @brief Macro to automatically put a string constant into program memory */ #define uart_puts_P(__s) uart_puts_p(PSTR(__s))
Zitieren
