Ergebnis 1 bis 9 von 9
Thema: NIBObee - Play Bach!
Baum-Darstellung
  1. #9
    ich grabe eigentlich ungern 2 Jahre alte Threads aus, aber ich wollte andererseits auch keinen Neuen dafür öffnen.
    Ich habe das playbach Programm für den ATMega1284p angepasst, der im Tuningkit von Nicai Systems enthalten ist.
    Vielleicht nützt es ja jemandem Bild
     *  @brief   Play a melody from J. S. Bach.
     *           Push the left sensor to modify the speed.
     *           Push the right sensor to modify the sound volume.
     *           The sound quality depends on the underground, how many mechanical parts can vibrate
     *           on the robot, how the spheres are installed, the volume, etc..
     *  tip      Hold the wheels with all fingers to feel the music :)
     *           This also may reduce rasping/scratchy sound.
     *    Thanks to Oliver G. for the Version for ATMega16. I only ported it to 1284p.
     *  @author  Philipp Stiegler
     *  @date    2014-01-03
     *  @version 1.0-1284p
    #include <nibobee/iodefs.h>
    #include <nibobee/led.h>
    #include <nibobee/delay.h>
    #include <nibobee/sens.h>
    #include <nibobee/motpwm.h>
    #include <math.h>
    volatile uint8_t pulse; // helper for timing
    uint16_t noteCnt; // current note of the melody
    uint16_t beeperVolume;
    uint8_t beeperActive;
    uint16_t speed; // length of one note in ms (so actually 1/speed)
    void playNote(uint8_t note);
    void playNoteTime(uint8_t note, uint16_t time);
    void playScales();
    void initBeeper();
    void listenSensorInput();
    // Note names as used by european musicians. a1 = a' = 440 Hz
    // (x)es names are missing, but you know that cis' = des' etc.
    enum  {
      _C, _Cis, _D, _Dis, _E, _F, _Fis, _G, _Gis, _A, _Ais, _H,
      _c, _cis, _d, _dis, _e, _f, _fis, _g, _gis, _a, _ais, _h,
      c1, cis1, d1, dis1, e1, f1, fis1, g1, gis1, a1, ais1, h1,
      c2, cis2, d2, dis2, e2, f2, fis2, g2, gis2, a2, ais2, h2,
      c3, cis3, d3, dis3, e3, f3, fis3, g3, gis3, a3, ais3, h3, c4
    // frequencies for _c to _h, the remaining notes will be computed
    float freqTable[] = {
      130.81, 138.59, 146.83, 155.56, 164.81, 174.61, 185, 196, 207.65, 220, 233.08, 246.94
    // Some nice melody from J.S. Bach!
    // we don't need information about the note length,
    // cause we can recognize this melody with equal note lengths
    uint8_t melody[] = {
      c1, e1, g1, c2, e2, g1, c2, e2, c1, e1, g1, c2, e2, g1, c2, e2,
      c1, d1, a1, d2, f2, a1, d2, f2, c1, d1, a1, d2, f2, a1, d2, f2,
      _h, d1, g1, d2, f2, g1, d2, f2, _h, d1, g1, d2, f2, g1, d2, f2,
      c1, e1, a1, e2, a2, a1, e2, a2, c1, e1, a1, e2, a2, a1, e2, a2,
      c1, d1, fis1, a1, d2, fis1, a1, d2, c1, d1, fis1, a1, d2, fis1, a1, d2,
      _h, d1, g1, d2, g2, g1, d2, g2, _h, d1, g1, d2, g2, g1, d2, g2,
      _h, c1, e1, g1, c2, e1, g1, c2, _h, c1, e1, g1, c2, e1, g1, c2,
      _a, c1, e1, g1, c2, e1, g1, c2, _a, c1, e1, g1, c2, e1, g1, c2,
      _d, _a, d1, fis1, c2, d1, fis1, c2, _d, _a, d1, fis1, c2, d1, fis1, c2,
      _g, _h, d1, g1, h1, d1, g1, h1, _g, _h, d1, g1, h1, d1, g1, h1,
      _g, _ais, e1, g1, cis2, e1, g1, cis2, _g, _ais, e1, g1, cis2, e1, g1, cis2,
      _f, _a, d1, a1, d2, d1, a1, d2, _f, _a, d1, a1, d2, d1, a1, d2,
      _f, _gis, d1, f1, h1, d1, f1, h1, _f, _gis, d1, f1, h1, d1, f1, h1,
      _e, _g, c1, g1, c2, c1, g1, c2, _e, _g, c1, g1, c2, c1, g1, c2,
      _e, _f, _a, c1, f1, _a, c1, f1, _e, _f, _a, c1, f1, _a, c1, f1,
      _d, _f, _a, c1, f1, _a, c1, f1, _d, _f, _a, c1, f1, _a, c1, f1,
      _G, _d, _g, _h, f1, _g, _h, f1, _G, _d, _g, _h, f1, _g, _h, f1,
      _c, _e, _g, c1, e1, _g, c1, e1, _c, _e, _g, c1, e1, _g, c1, e1,
      c1 // melody shortened here...
    int main() {
      motpwm_init();
      led_init();
      sens_init();
      initBeeper(); // (i'm used to camel case naming...)
      speed = 130;
      beeperVolume = 500;
      playScales();
      uint8_t i = 3;
      while (i-- > 0) {
        // short pause
        beeperActive = 0;
        delay(500);
        beeperActive = 1;
        noteCnt = 0;
        while (noteCnt < sizeof(melody)) {
          playNote(melody[noteCnt]);
          noteCnt++;
        delay(4 * speed); // hold last note of the melody
        speed -= 20; // play melody a bit faster next time
      beeperActive = 0;
      delay(100);
      disable_interrupts();
      return 0;
     *  Listen for some user/sensor input.
    void listenSensorInput() {
      if (sens_getLeft())  {
        speed -= 10 * sens_getLeft();
        while (sens_getLeft());
      if (sens_getRight())  {
        beeperVolume += 100 * sens_getRight();
        while (sens_getRight());
     *  Play the given note and hold it for the time defined in global var: speed.
    void playNote(uint8_t note) {
      playNoteTime(note, speed);
     *  Play the given note for the given time (milliseconds).
    void playNoteTime(uint8_t note, uint16_t time) {
      uint8_t octave = note / 12;
      float frequency = freqTable[note%12] * (1<<octave);
      // set prescaler and compare value which will trigger interrupt
      if (octave == 0) {
        TCCR0B |= (1<<CS00) | (1<<CS02); // set prescaler to 1024
        TCCR0B &= ~((1<<CS01));
        TCCR0A |= (1<<WGM01);
        OCR0A = roundf( (16000000 / 1024.0f) / frequency) -1;
      } else if (octave <= 2) {
        TCCR0B |= (1<<CS02); // set prescaler to 256
        TCCR0B &= ~((1<<CS00) | (1<<CS01));
        OCR0A = roundf( (16000000 / 256.0f) / frequency) -1;
      } else {
        TCCR0B |= (1<<CS00) | (1<<CS01); // set prescaler to 64
        TCCR0B &= ~((1<<CS02));
        OCR0A = roundf( (16000000 / 64.0f) / frequency) -1;
      delay(time);
      /* Uncomment this code for a little pause between the notes
      TCCR0 = 0;
      motpwm_setLeft(0);
      motpwm_setRight(0);
      delay(time/3); */
     *  Play some standard scales for sound check.
    void playScales() {
      // chromatic scale
      for (int i = 0; i < 5 * 12; i++)
        playNoteTime(i, 20);
      // 4 octaves c major scale
      uint8_t cMajorScale[] = {
        _c, _d, _e, _f, _g, _a, _h,
        c1, d1, e1, f1, g1, a1, h1,
        c2, d2, e2, f2, g2, a2, h2,
        c3, d3, e3, f3, g3, a3, h3, c4
      for (int i = 0; i < sizeof(cMajorScale); i++)
        playNoteTime(cMajorScale[i], 100);
     *  Config timer 0 and set beeper active.
    void initBeeper() {
      TCCR0A |= (1<<WGM01); // set CTC modus
      OCR0A = (16000000/256) / 440 -1; // (value overwritten later)
      TIMSK0 |= (1<<OCIE0B); // allow compare interrupt
      beeperActive = 1;
      enable_interrupts();
     *  Compare interrupt handler
     *  Is called if TCNT0 = OCR0
    ISR (TIMER0_COMPB_vect) {
      if (beeperActive) {
        // let the motor turn left and right quickly to create some noise
        // the led_set() calls are just added to create some light effect sync. to the melody
        // the noteCnt % 8 distinction is also just for an effect - so deep notes are played on left,
        // higher notes on the right motor
        if (pulse++ % 2 == 0) {
          if (noteCnt % 8 <= 1 ) {
            led_set(3, 0);
            led_set(2, 0);
            led_set(noteCnt % 2, 1);
            led_set(!(noteCnt % 2) , 0);
            motpwm_setLeft(beeperVolume);
            motpwm_setRight(0);
          } else {
            led_set(noteCnt % 2 + 2, 1);
            led_set(!(noteCnt % 2) + 2, 0);
            led_set(0, 0);
            led_set(1, 0);
            motpwm_setRight(beeperVolume);
            motpwm_setLeft(0);
        } else {
          if (noteCnt % 8 <= 1) {
            motpwm_setLeft(-beeperVolume);
            motpwm_setRight(0);
          } else {
            motpwm_setRight(-beeperVolume);
            motpwm_setLeft(0);
      } else {
        motpwm_setLeft(0);
        motpwm_setRight(0);
    Hier gibts nochmals die Sourcen und vorkompilierte Binaries...
    http://www.roboter.cc/index.php?opti...projectid=2324
    Liebe Grüße
    Philipp
    EDIT:
    Ein Video gibts hier:
    http://www.youtube.com/watch?v=JPF5jKrtDwU
    Geändert von gateway (04.01.2014 um 13:28 Uhr)
  1. ACS an NIBObee
    Von pacman im Forum Sonstige Roboter- und artverwandte Modelle
    Antworten: 37
    Letzter Beitrag: 19.06.2011, 23:05
  2. ACS an NIBObee
    Von pacman im Forum Sensoren / Sensorik
    Letzter Beitrag: 06.06.2011, 08:32
  3. Xperia Play und Xperia Arc: Android 2.3.3 mit Facebook-Integration kommt
    Letzter Beitrag: 27.05.2011, 11:20
  4. TWI per Plug an Play
    Von francesco im Forum AVR Hardwarethemen
    Antworten: 7
    Letzter Beitrag: 18.05.2008, 15:46
  5. Ethernet per Plug and Play Karte
    Von PasstScho im Forum Elektronik
    Letzter Beitrag: 16.12.2004, 21:58
