Hallo zusammen,
ich versuche gerade, das Beispiel RP6Base_Move_05.c zu kompilieren. Erst sagte er etwas, das im Ordner .deb was nicht stimmt. Den Ordner gelöscht und jetzt versucht er auch das Ding wirklich zu kompilieren, GCC schmeißt mir aber folgendes an den Kopf:
Zum compilieren führt Geany im jeweiligen Ordner ein "make all" aus.Code:make all (im Verzeichnis: /home/simon/Dokumente/Schule/Deutsch/Referat-RP6/Software/RP6Examples_20080915/RP6BASE_EXAMPLES/Example_05_Move_05) -------- begin -------- avr-gcc (Fedora 4.6.1-2.fc15) 4.6.1 Copyright (C) 2011 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. Compiling: ../../RP6Lib/RP6base/RP6RobotBaseLib.c avr-gcc -c -mmcu=atmega32 -I. -gdwarf-2 -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=../../RP6Lib/RP6base/RP6RobotBaseLib.lst -I../../RP6Lib -I../../RP6Lib/RP6base -I../../RP6Lib/RP6common -std=gnu99 -MD -MP -MF .dep/RP6RobotBaseLib.o.d ../../RP6Lib/RP6base/RP6RobotBaseLib.c -o ../../RP6Lib/RP6base/RP6RobotBaseLib.o ../../RP6Lib/RP6base/RP6RobotBaseLib.c: In function 'emergencyShutdown': ../../RP6Lib/RP6base/RP6RobotBaseLib.c:507:45: error: variable '__c' must be const in order to be put into read-only section by means of '__attribute__((progmem))' ../../RP6Lib/RP6base/RP6RobotBaseLib.c:508:45: error: variable '__c' must be const in order to be put into read-only section by means of '__attribute__((progmem))' ../../RP6Lib/RP6base/RP6RobotBaseLib.c:511:46: error: variable '__c' must be const in order to be put into read-only section by means of '__attribute__((progmem))' ../../RP6Lib/RP6base/RP6RobotBaseLib.c:512:46: error: variable '__c' must be const in order to be put into read-only section by means of '__attribute__((progmem))' ../../RP6Lib/RP6base/RP6RobotBaseLib.c:514:47: error: variable '__c' must be const in order to be put into read-only section by means of '__attribute__((progmem))' ../../RP6Lib/RP6base/RP6RobotBaseLib.c:516:47: error: variable '__c' must be const in order to be put into read-only section by means of '__attribute__((progmem))' ../../RP6Lib/RP6base/RP6RobotBaseLib.c:517:46: error: variable '__c' must be const in order to be put into read-only section by means of '__attribute__((progmem))' ../../RP6Lib/RP6base/RP6RobotBaseLib.c:518:46: error: variable '__c' must be const in order to be put into read-only section by means of '__attribute__((progmem))' ../../RP6Lib/RP6base/RP6RobotBaseLib.c:522:46: error: variable '__c' must be const in order to be put into read-only section by means of '__attribute__((progmem))' ../../RP6Lib/RP6base/RP6RobotBaseLib.c:523:46: error: variable '__c' must be const in order to be put into read-only section by means of '__attribute__((progmem))' ../../RP6Lib/RP6base/RP6RobotBaseLib.c:524:46: error: variable '__c' must be const in order to be put into read-only section by means of '__attribute__((progmem))' ../../RP6Lib/RP6base/RP6RobotBaseLib.c:526:45: error: variable '__c' must be const in order to be put into read-only section by means of '__attribute__((progmem))' make: *** [../../RP6Lib/RP6base/RP6RobotBaseLib.o] Fehler 1 Kompilierung fehlgeschlagen.
System: Fedora 15.
Weis jemand weiter?Code:$ avr-gcc --version avr-gcc (Fedora 4.6.1-2.fc15) 4.6.1
Viele Grüße und vielen Dank schonmal
-schumi-
PS: Eigene Programme (Allgemein für AVRs) konnte ich bisher völlig Problemlos compilieren
Zitieren
