Ergebnis 1 bis 1 von 1
Thema: SAA anstatt BEAM ?
Baum-Darstellung
    SAA anstatt BEAM ?
    Weil ich mich zukünftig sehr gerne mit sölarbetriebenen künstlichen Tieren beschäftigen möchte, die wegen steuernden µC laut bisheriger Definition nicht mehr BEAM-er heissen dürfen, möchte ich eigene Abkürzung dafür: SAA ("solar artificial animal") benutzen.
    BEAM is an acronym standing for Biology, Electronics, Aesthetics, Mechanics:
    Biology -- It's tough to beat 4 billion years of evolution; the world around us is a wonderful source of inspiration and education. Bear in mind, of course, that unlike Mother Nature, you also have the advantage of gears, motors, bearings, and good glues!
    Electronics -- It kind of goes without saying, but this is what we'll use to drive our creations. BEAM robotics, though, strives for rich behaviors from simple circuits. Here's the key: simple and understandable circuits, surprisingly complex in behavior.
    Aesthetics -- This just means your creations should look good. I'm an engineer, but even I appreciate a good-looking design. Besides, if a design looks "clean," it's more likely to work (and easier to test / debug) than a design that's tangled and unruly.
    Mechanics -- This is the less-than-obvious secret of many successful BEAMbots -- with a clever mechanical design, you can reduce the complexity of the rest of your robot (reducing the number of motors and sensors, for example).
    BEAM robotics basically starts from 3 philosophical tenets:
    Use minimalist electronics
    This keeps complexity from "snowballing", and keeps costs down
    Recycle & reuse components out of technoscrap
    This keeps things cheap, and avoids a lot of trips to parts stores; virtually all the parts required to make a BEAM robot can be found in broken electronics (ovens, walkman's, CD players, VCRs, pagers...).
    Solar power your critter if possible
    While less powerful than even a small battery (and, up-front, more expensive), solar cell s last for years; solar-powered BEAMbots don't require constant battery replacements or down-time for battery recharging.
    While BEAM robots are often simple (consisting of a solar cell , motor, 2 transistors , and capacitor ), robots as complicated as 8-jointed, 4-legged walking spiders have been built using the principles of BEAM.
    Was denkt Ihr darüber ? Vorschläge ?
    Schönen Dank für Eure Meinungen im voraus. Bild
    Geändert von PICture (24.09.2013 um 11:55 Uhr)
  1. [ERLEDIGT] Mignon Li-Ion anstatt Ni-MH ?
    Von PICture im Forum Elektronik
    Letzter Beitrag: 18.07.2011, 19:28
  2. Anstatt Relais...
    Von oratus sum im Forum Elektronik
    Antworten: 8
    Letzter Beitrag: 04.03.2007, 15:23
  3. Welchen T. anstatt BD434?
    Von markus1990 im Forum Elektronik
    Letzter Beitrag: 11.12.2005, 17:07
  4. Transportkugeln anstatt Transportrollen
    Von the_real_didi im Forum Mechanik
    Letzter Beitrag: 28.07.2005, 14:06
  5. Variablendefinition mit char anstatt int ?!
    Von bewild im Forum C - Programmierung (GCC u.a.)
    Letzter Beitrag: 30.09.2004, 08:11
