Thema: LCD Anzeige in FemtoOS (P. Fleury)
    Erfahrener Benutzer Begeisterter Techniker Avatar von Jacob2
    Berlin
    Hi!
    Ich habe mich ein bisschen mit FemtoOS beschäftigt, d.h. ich habe es immerhin schonmal geschafft ein Beispielprogramm (LED Flash) auf einem ATmega48 zum Laufen zu bringen.
    Jetzt wollte ich gerne ein LCD steuern, was ich bisher immer mit P. Fleury's Bibliothek gemacht habe, aber nun bekomme ich 31 Warnungen und das LCD bleibt leer (der schwarze Balken ist aber weg -> vielleicht hat lcd_init() zumindest funktioniert...).
    Build started 21.8.2011 at 10:24:05
    ../lcdlibrary/lcd.c: In function 'lcd_waitbusy':
    ../lcdlibrary/lcd.c:294: warning: integer constant is too large for 'long' type
    ../lcdlibrary/lcd.c: In function 'lcd_init':
    ../lcdlibrary/lcd.c:556: warning: integer constant is too large for 'long' type
    ../lcdlibrary/lcd.c:556: warning: large integer implicitly truncated to unsigned type
    ../lcdlibrary/lcd.c:562: warning: integer constant is too large for 'long' type
    ../lcdlibrary/lcd.c:562: warning: large integer implicitly truncated to unsigned type
    ../lcdlibrary/lcd.c:566: warning: integer constant is too large for 'long' type
    ../lcdlibrary/lcd.c:570: warning: integer constant is too large for 'long' type
    ../lcdlibrary/lcd.c:575: warning: integer constant is too large for 'long' type
    ../lcdlibrary/lcd.c:596:5: warning: "KS0073_4LINES_MODE" is not defined
    ../lcdlibrary/lcd.c:96: warning: inlining failed in call to '_delayFourCycles': optimizing for size and code size would grow
    ../lcdlibrary/lcd.c:294: warning: called from here
    ../lcdlibrary/lcd.c:556: warning: called from here
    ../lcdlibrary/lcd.c:562: warning: called from here
    ../lcdlibrary/lcd.c:566: warning: called from here
    ../lcdlibrary/lcd.c:570: warning: called from here
    ../lcdlibrary/lcd.c:575: warning: called from here
    avr-gcc -mmcu=atmega48 -mint8  -Wl,--defsym=__stack=xOS+xOSstackShift  --param inline-call-cost=2  -ffunction-sections  -Wl,--gc-sections  -Wl,--relax  -Wno-main  -Winline  -Wundef  -fomit-frame-pointer -Wl,-Map=FemtoOS_FlashLeds.map femtoos_startup.o femt
    oos_port.o femtoos_shared.o femtoos_core.o code_TestFlashLeds.o lcd.o     -o FemtoOS_FlashLeds.elf
    avr-objcopy -O ihex -R .eeprom -R .fuse -R .lock -R .signature  FemtoOS_FlashLeds.elf FemtoOS_FlashLeds.hex
    avr-objcopy -j .eeprom --set-section-flags=.eeprom="alloc,load" --change-section-lma .eeprom=0 --no-change-warnings -O ihex FemtoOS_FlashLeds.elf FemtoOS_FlashLeds.eep || exit 0
    avr-objdump -h -S FemtoOS_FlashLeds.elf > FemtoOS_FlashLeds.lss
    AVR Memory Usage
    Device: atmega48
    Program:    2266 bytes (55.3% Full)
    (.text + .data + .bootloader)
    Data:        104 bytes (20.3% Full)
    (.data + .bss + .noinit)
    Build succeeded with 21 Warnings...
    Irgendwie scheint er Probleme mit den Integer-Konstanten zu haben, in solchen Zeilen:
    294: delay(2);
    556: delay(16000);
    usw.
    Verändert FemtoOS da irgendwelche Einstellungen (kann mir aber keine Vorstellen), weil außerhalb von FemtoOS funktioniert die LCD-Library einwandfrei (ohne Warnungen)...
    Roboter, CNC Fräse, Elektronik und Basteleien stelle ich auf meiner Website vor...
    avr-gcc ... -mint8 ...
    Stefan
    Berlin
    Vielen Dank sternst!
    Der Link hier erklärt einiges, muss ich jetzt einfach an den gegebenen Stellen mit einem Postfix 'L' arbeiten? Die Warnung heißt ja aber eigentlich, dass die Werte selbst für long zu groß sind... Oder?
    Das beste wäre es, das -mint8 komplett rauszuschmeißen. Dieser Schalter ist sehr problematisch, und wird von neueren GCC-Versionen auch gar nicht mehr unterstützt. Ob und welche Auswirkungen das dann allerdings auf FemtoOS hat, kann ich dir nicht sagen.
    Stefan
    Berlin
    Wo würde ich denn sowas abschalten im AVR Studio? Einfach mal sehen ob FemtoOS dann noch funktioniert...
    Berlin
    Ich habe es mittlerweile geschafft, -mint8 auszuschalten, was die Warnungsanzahl etwas reduziert hat:
    avr-gcc -I"W:\Ich\Roboter\FemtoOS_0.92\IDE\studioprojects\FemtoOS_Staubsaugerroboter\..\..\..\MainCode\femtoos_headers" -I"W:\Ich\Roboter\FemtoOS_0.92\IDE\studioprojects\FemtoOS_Staubsaugerroboter\..\..\..\MainCode\femtoos_devices" -I"W:\Ich\Roboter\FemtoO
    S_0.92\IDE\studioprojects\FemtoOS_Staubsaugerroboter\."  -mmcu=atmega48 -Wall -gdwarf-2 -Wl,--defsym=__stack=xOS+xOSstackShift --param inline-call-cost=2 -ffunction-sections -Wl,--gc-sections -Wl,--relax -Wno-main -Winline -Wundef -fomit-frame-pointer -DF_
    CPU=8000000UL -Os -funsigned-char -fpack-struct -fshort-enums  -MD -MP -MT lcd.o -MF dep/lcd.o.d  -c  ../lcdlibrary/lcd.c
    avr-gcc -mmcu=atmega48 -Wl,--defsym=__stack=xOS+xOSstackShift --param inline-call-cost=2 -ffunction-sections -Wl,--gc-sections -Wl,--relax -Wno-main -Winline -Wundef -fomit-frame-pointer  -Wl,-Map=FemtoOS_FlashLeds.map femtoos_startup.o femtoos_port.o femt
    Build succeeded with 13 Warnings...
    Warum KS0073_4LINES_MODE nicht definiert sein soll, verstehe ich nicht, denn das wird in lcd.c in Zeile 74 eindeutig definiert:
    #define KS0073_4LINES_MODE                    0x09   /* |0|001|0000 4-bit mode, extension-bit RE = 0 */
    Die Boot-Funktion appBoot() sieht so aus:
    void appBoot(void)
        lcd_init(LCD_DISP_ON);
        lcd_puts("Staubsaugerrobot");
        lcd_gotoxy(0, 1);
        lcd_puts("FemtoOS 0.92");
    In jeder Task (8 Stück) wird nur gewartet:
    #if (preTaskDefined(MainTask))
    void appLoop_MainTask(void)
        while(true)
            taskDelayFromNow(430U);
    #endif
    Leider bleibt das LCD immer noch leer, die Anfangsmeldung müsste ja die ganze Zeit zu sehen sein...
    Hat jemand so viel Ahnung von FemtoOS, dass er mir sagen kann, was ich noch falsch mache?
    PS: Sorry für so viel Code, aber ich denke das ist notwendig...
  1. i2c mit fleury lib
    Von hacker im Forum C - Programmierung (GCC u.a.)
    Antworten: 12
    Letzter Beitrag: 01.10.2009, 15:30
  2. Erfahrungen mit FemtoOS?
    Von CopyConstructor im Forum Open Source Software Projekte
    Letzter Beitrag: 28.09.2009, 00:39
  3. LCD mit P. Fleury
    Von chientech im Forum C - Programmierung (GCC u.a.)
    Antworten: 8
    Letzter Beitrag: 21.03.2007, 16:40
  4. LCD mit P. Fleury
    Antworten: 0
    Letzter Beitrag: 12.10.2006, 07:56
  5. LCD von Fleury
    Von Spurius im Forum C - Programmierung (GCC u.a.)
    Letzter Beitrag: 29.04.2006, 13:24
