Ergebnis 11 bis 20 von 20
Thema: Timer als Counter zu konfigurieren
    Das Folgende Code habe ich in der STM32F10x_tim.c.
    Ich schätzr mal das ist der Code, das ich Suche oder? nun statt external Clock Mode ist eigentlich external Signal das sind gleich oder?
    * @brief Configures the External clock Mode1
    * @param TIMx: where x can be 1, 2, 3, 4, 5 or 8 to select the TIM peripheral.
    * @param TIM_ExtTRGPrescaler: The external Trigger Prescaler.
    * This parameter can be one of the following values:
    * @arg TIM_ExtTRGPSC_OFF: ETRP Prescaler OFF.
    * @arg TIM_ExtTRGPSC_DIV2: ETRP frequency divided by 2.
    * @arg TIM_ExtTRGPSC_DIV4: ETRP frequency divided by 4.
    * @arg TIM_ExtTRGPSC_DIV8: ETRP frequency divided by 8.
    * @param TIM_ExtTRGPolarity: The external Trigger Polarity.
    * @arg TIM_ExtTRGPolarity_Inverted: active low or falling edge active.
    * @arg TIM_ExtTRGPolarity_NonInverted: active high or rising edge active.
    * @param ExtTRGFilter: External Trigger Filter.
    * This parameter must be a value between 0x00 and 0x0F
    * @retval None
    void TIM_ETRClockMode1Config(TIM_TypeDef* TIMx, uint16_t TIM_ExtTRGPrescaler, uint16_t TIM_ExtTRGPolarity,
    uint16_t ExtTRGFilter)
    uint16_t tmpsmcr = 0;
    /* Check the parameters */
    assert_param(IS_TIM_LIST3_PERIPH(TIMx));
    assert_param(IS_TIM_EXT_PRESCALER(TIM_ExtTRGPresca ler));
    assert_param(IS_TIM_EXT_POLARITY(TIM_ExtTRGPolarit y));
    assert_param(IS_TIM_EXT_FILTER(ExtTRGFilter));
    /* Configure the ETR Clock source */
    TIM_ETRConfig(TIMx, TIM_ExtTRGPrescaler, TIM_ExtTRGPolarity, ExtTRGFilter);
    /* Get the TIMx SMCR register value */
    tmpsmcr = TIMx->SMCR;
    /* Reset the SMS Bits */
    tmpsmcr &= (uint16_t)(~((uint16_t)TIM_SMCR_SMS));
    /* Select the External clock mode1 */
    tmpsmcr |= TIM_SlaveMode_External1;
    /* Select the Trigger selection : ETRF */
    tmpsmcr &= (uint16_t)(~((uint16_t)TIM_SMCR_TS));
    tmpsmcr |= TIM_TS_ETRF;
    /* Write to TIMx SMCR */
    TIMx->SMCR = tmpsmcr;
    Mit dem µC kenn ich mich leider nicht aus. Aber wie schon gesagt:
    Bei den meisten (allen?) AVRs gibt es ein Register für den Timer um diesen zu konfigurieren. Man hat die Wahl zwischen zwei "Zählweisen"
    1. Der Zähler zählt mit dem µC-Takt, evtl. verrechnet mit einem Presceler, hoch, der überwachte Pin für die zweite Zählgeschwindigkeit hat keinen Einfluss
    2. Der Zähler zählt bei jeder steigenden oder fallenden Flanke um jeweils 1 hoch, der µC-Takt hat keinen Einfluss auf die Zählgeschwindigkeit
    Ich schätze mal, so eine Einstellung dürfte es auch bei deinem µC geben.
    Alles ist möglich. Unmögliches dauert nur etwas länger!
    Niklasdorf
    @Arkon Er verwendet keinen AVR sondern einen ARM. Ds ist nicht die gleiche Technik.
    @kmrish: Leider kann ich dir ebenfalls nicht weiterhelfen da ich mit Atmegas/Attinys, also AVR, programmiere.
    MfG Hannes
    Die Initialisierung des TIM1 bis TIM5 und TIM8 als Endcoder ( Endcoder-Mode ) ist relativ einfach. Im Kap. 14.3.12 Manual Rev. 11 steht da alles beschrieben.
    Hier ein Bsp. für TIM3:
    #define ENCODER_TIMER TIM3
    #define C_QA GPIO_Pin_6 //- Input Encoder A
    #define C_QB GPIO_Pin_7 //- Input Encoder B
    void EncoderTimerInit( void )
    TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
    TIM_ICInitTypeDef TIM_ICInitStructure;
    /* Timer configuration in Encoder mode */
    TIM_DeInit(ENCODER_TIMER);
    TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
    TIM_TimeBaseStructure.TIM_Prescaler = 0x0; // No prescaling
    TIM_TimeBaseStructure.TIM_Period = 0xFFFF; //
    TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
    TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
    TIM_TimeBaseInit(ENCODER_TIMER, &TIM_TimeBaseStructure);
    TIM_ICStructInit(&TIM_ICInitStructure);
    TIM_ICInitStructure.TIM_ICFilter = ICx_FILTER;
    TIM_ICInit(ENCODER_TIMER, &TIM_ICInitStructure);
    TIM_EncoderInterfaceConfig(ENCODER_TIMER, TIM_EncoderMode_TI12,
    TIM_ICPolarity_Falling, TIM_ICPolarity_Rising);
    // Clear all pending interrupts
    // TIM_ClearFlag(ENCODER_TIMER, TIM_FLAG_Update);
    // TIM_ITConfig(ENCODER_TIMER, TIM_IT_Update, ENABLE);
    TIM_Cmd(ENCODER_TIMER, ENABLE);
    void init_gpio( void )
    GPIO_InitTypeDef GPIO_InitStructure;
    //- andere Portpins für TIM3 ( GPIO 6 und GPIO 7 )
    GPIO_PinRemapConfig(GPIO_FullRemap_TIM3, ENABLE);
    GPIO_InitStructure.GPIO_Pin = C_QA | C_QB;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
    GPIO_Init(GPIOC, &GPIO_InitStructure);
    void main( void )
    u16 wCounter =0;
    init_gpio( );
    EncoderTimerInit();
    //- Bsp. für das lesen des Encoder-Counter
    wCounter = ENCODER_TIMER->CNT;
    // etc.
    Das sollte so funktionieren. Musst Du halt noch entsprechend erweitern oder abändern ( Timer und Ports z.B. )
    Gruss
    Steffen
    da der Counter in beide Richtung zählen soll, soll als CounterMode das " TIM_CounterMode_CenterAligned3 " ausgewählt werden. stimmt??
    RM0008 steht seite 344 " the counter counts up and down (Center aligned mode 3, CMS ="11"). "
    wenn das richtig ist, soll ich TIM_TimeBaseStructure.TIM_CounterMode verwenden oder soll ich das da verwenden:
    void TIM_CounterModeConfig(TIM_TypeDef* TIMx, uint16_t TIM_CounterMode)
    welche soll ich verwenden um den Counter-Mode einzustellen?
    Niklasdorf
    Kannst du ein Datenblatt posten nach deem du gehst. Dann könnte ich nachlesen.
    MfG Hannes
    Hallo Lieber 021aet04
    Ich danke dir viel mals für deine Bereitschaft mir zu helfen.
    Anbei sende ich dir das Referenz Manual (RM000 Bild  .
    Dieses Datenbaltt besteth aus 1072 Seiten, deswegen möchte ich dir erleichten, die entsprechende Seiten schnell zu finden.
    Encoder Inreface Mode findest du ab Seite 301
    Center-aligned mode (up/down counting) ab Seit 278
    SPI ab Seite 657 (meine Schaltung wird dabei als Slave-Device betrieben)
    Vielen Danke für deine Hilfe.
    LG
    Adam
    So hat er bei mir functioniert mit ein qwadrature encoder !! Beide Eingangen mussen beschaltet sein, und in Fase versetzt. Dan zaehlt den counter hoch oder ab, abhangig welke Flanke erst kommt.
      * @brief  Configures the TIMx Encoder Interface.
      * @param  TIM_EncoderMode: specifies the TIMx Encoder Mode.
      *     @arg TIM_EncoderMode_TI1: Counter counts on TI1FP1 edge depending on TI2FP2 level.
      *     @arg TIM_EncoderMode_TI2: Counter counts on TI2FP2 edge depending on TI1FP1 level.
      *     @arg TIM_EncoderMode_TI12: Counter counts on both TI1FP1 and TI2FP2 edges depending
      *                                on the level of the other input.
      * @param  TIM_IC1Polarity: specifies the IC1 Polarity
      *   This parmeter can be one of the following values:
      *     @arg TIM_ICPolarity_Falling: IC Falling edge.
      *     @arg TIM_ICPolarity_Rising: IC Rising edge.
      * @param  TIM_IC2Polarity: specifies the IC2 Polarity
      * @retval None
    TIM_EncoderInterfaceConfig(TIM2, TIM_EncoderMode_TI12,TIM_ICPolarity_Rising,TIM_ICPolarity_Rising);
    TIM_EncoderInterfaceConfig(TIM4, TIM_EncoderMode_TI12,TIM_ICPolarity_Rising,TIM_ICPolarity_Rising);
      /* TIM enable counter */
      TIM_Cmd(TIM2, ENABLE);
      TIM_Cmd(TIM4, ENABLE);
       /* TIM2 + TIM4 clock enable */
      RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
      RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
      RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
       /* GPIOA, GPIOB and GPIOC clock enable */
      RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB |
                             RCC_APB2Periph_GPIOC | RCC_APB2Periph_AFIO, ENABLE);
       //configure TIM2 CH0/CH1 = A0,A1 alternate function for encoder reading
      GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1| GPIO_Pin_15;
      GPIO_Init(GPIOA, &GPIO_InitStructure);
      //configure TIM4 CH0/CH1 = B6,B7 alternate function for encoder reading
      GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 |GPIO_Pin_6 | GPIO_Pin_7;
      GPIO_Init(GPIOB, &GPIO_InitStructure);
       static int16_t encoder1;
       static int16_t encoder2;
        encoder1=TIM2->CNT; //actuele waarde van encoder1
        encoder2=TIM4->CNT; //actuele waarde van encoder2
    hallo RP6conrad,
    Ich hätte gerne paar Fragen zu deinem Code.
    1) zuerst warum hast zwei Timer TIM2 und TIM4 dafür eingesetzt? wolltest du damit Zwie Drehgebers abtasten?
    2)ich sehe in deinem Code keine Funktion, womit der Counter in beide Richtung zählt() sowohl heruaf als acu heunter. laut der RM0008 stellt man sowas durch die folgende Funktion:
    TIM_CounterModeConfig(TIM1,TIM_CounterMode_CenterA ligned3);
    3) braucht man die Funktion TIM-TimeBseStructure nicht__?????
    4) soweit ich richtig verstsnden habe der Counter bekommt das Signal TI1FP1 und TI2FP2, und die beide Signalen sind Inputcapture. das heisst mann soll auch das Capture/ Compare unti Teilweise einstellen wie folgt:
    TIM_ICInitStructure.TIM_Channel =TIM_Channel_1 |TIM_Channel_2;
    TIM_ICInitStructure.TIM_ICPolarity =TIM_ICPolarity_Rising;
    TIM_ICInitStructure.TIM_ICSelection =TIM_ICSelection_DirectTI;
    TIM_ICInitStructure.TIM_ICPrescaler =TIM_ICPSC_DIV1;
    TIM_ICInitStructure.TIM_ICFilter =0x0;
    TIM_ICInit(TIM1, &TIM_ICInitStructure);
    5)mit was kann man auf die folgende Frage Antworten:
    kann der Counter in eine Sekunde 200.000 Steigende Flanke zählen? bzw. 400.000 steigende und fallende Flanke zählen?
    1. Stimmt, ich habe 2 motoren mit jeden ein kwadrature encoder (ist für eine robby mit differential drive). Damit wirden von beide motoren die exacte position erfasst.
    2. Das schone von diese timer ist das alles komplett in harware verlauft. Ihre C-program muss sich da nicht mehr um kummerm ! Nur eine ueberlauf (16 bit counter) sollen sie noch mit eine interrupt abfangen.
    3. Tim base Structure brauchen sie in diesen Fall nicht.
    4. Auch input capture braucht man nicht. Ein Input Capture macht folgendes : sobald das "Event" (positive flanke, negatieve flanke) passiert, wird die Timer wert in ein Register abgelegt. Den Timer lauft dabei an eine feste Frequenz. Ist forgesehen um Zeiten zwischen zwei "Events" genau zu messen.
    5. Habe ich auch keine Wert gefunden, aber 400 kHz soll eigentlich kein Problem sein, da alles in HW verlauft.
  1. Konfiguration: Timer als Counter gesucht
    Von robodriver im Forum Basic-Programmierung (Bascom-Compiler)
    Letzter Beitrag: 10.02.2008, 11:42
  2. Timer/Counter und PWM Channles
    Von ricola im Forum C - Programmierung (GCC u.a.)
    Antworten: 9
    Letzter Beitrag: 04.07.2007, 19:48
  3. Timer/Counter
    Von Jon im Forum Basic-Programmierung (Bascom-Compiler)
    Antworten: 16
    Letzter Beitrag: 17.05.2007, 18:43
  4. Attiny2313, Timer-Counter-Wie gehts?
    Von sebastian.fr im Forum AVR Hardwarethemen
    Antworten: 13
    Letzter Beitrag: 04.04.2006, 22:48
  5. Externer Timer/Counter um uC aufzuwecken
    Von Whassup im Forum C - Programmierung (GCC u.a.)
    Letzter Beitrag: 21.11.2005, 09:25
