Ergebnis 1 bis 10 von 40
Thema: linker Antrieb klemmt + Base stürzt ab
    Erfahrener Benutzer Fleißiges Mitglied Avatar von I♥ROBOTIC
    Fürstenstein
    hmm. ich kann beim besten willen den fehler nicht finden...
    #include "RP6ControlLib.h"
    #include "RP6I2CmasterTWI.h"
    #include "RP6Control_I2CMasterLib.h"
    void I2C_requestedDataReady(uint8_t dataRequestID)
       checkRP6Status(dataRequestID);
    void I2C_transmissionError(uint8_t errorState)
       writeString_P("\nI2C ERROR - TWI STATE: 0x");
       writeInteger(errorState, HEX);
       writeChar('\n');
    volatile uint16_t speed=0;
    volatile uint16_t dir=0;
    volatile uint16_t speedcount=0;
    volatile uint16_t dircount=0;
    ISR(TIMER1_COMPA_vect)
    	if (PINA & ADC5)
    		speedcount++;
    	else
    		if (speedcount > 0)
    			speed=speedcount;
    		speedcount=0;
    	if (PINA & ADC3)
    		dircount++;
    	else
    		if (dircount > 0)
    			dir=dircount;
    		dircount=0;
    void initRC(void)
    	TCCR1A = (0 << WGM11) | (0 << WGM10) | (0 << COM1A0) | (0 << COM1A1);	// CTC-Mode4, ohne OCR-Pin
    	TCCR1B = (0 << WGM13) | (1 << WGM12) | (0 << CS12)  | (1 << CS11) | (0 << CS10); // CTC und prescaler /8
    	TIMSK |= (1 << OCIE1A); 										// Interrupt ein
    	OCR1A  = 20; // 100kHz?
    	DDRA &= ~ADC5;
    	PORTA &= ~ADC5;
    	DDRA &= ~ADC3;
    	PORTA &= ~ADC3;
    int main(void)
    	initRP6Control();
    	initLCD();
    	initRC();
    	startStopwatch1();
    	mSleep(1000);
    	I2CTWI_initMaster(100);
    	I2CTWI_setRequestedDataReadyHandler(I2C_requestedDataReady);
    	I2CTWI_setTransmissionErrorHandler(I2C_transmissionError);
    	uint16_t speed1, dir1;
    while(1)
    	cli(); // Interrupts verbieten
    	speed1=speed;
    	dir1=dir;
    	sei(); // Interrupts wieder zulassen
    	if (speed1 < 150 && speed1 > 140)
    		if (dir1 > 180){ setMotorDir(BWD,FWD); setMotorPower(150,150); }
    		if (dir1 < 120){ setMotorDir(FWD,BWD); setMotorPower(150,150); }
    	if (speed1 < 140)
    		setMotorDir(BWD, BWD);
    		if(dir1 < 140){ setMotorPower((300-speed1),(300-speed1)-dir1); }
    		if(dir1 > 150){ setMotorPower((300-speed1)-(300-dir1),(300-speed1)); }
    		if(dir1 < 150 && dir1 > 140) { setMotorPower(300-speed1, 300-speed1); }
    	if (speed1 > 150)
    		setMotorDir(FWD, FWD);
    		if(dir1 < 140){ setMotorPower(speed1+dir1,speed1-dir1); }
    		if(dir1 > 150){ setMotorPower(speed1-(300-dir1), speed1+(300-dir1)); }
    		if(dir1 < 150 && dir1 > 140) { setMotorPower(speed1, speed1); }
    	if(adcLSL < 500 || adcLSR < 500) { PORTA |= ADC7; }
    	if(adcLSL > 500 && adcLSR > 500) { PORTA &= ~ADC7; }
    	task_checkINT0();
    	task_I2CTWI();
    	return 0;
    bin ich blind oder was -.- ?
    Paderborn
    Du könntest an der falschen Stelle schauen.
    Eine setMotorPower Funktion ist in der normalen I2C Lib nicht enthalten - die hast Du ja selbst geschrieben also liegt vermutlich dort bzw. eher in Deinem Slave Programm der Fehler.
    Vielleicht ist es auch einfach das hier:
    >... uint16_t ...
    und alles was damit zusammenhängt.
    Ich kenne natürlich den Rest der ZWEI Programme nicht (bzw. den Teil den Du geändert hast), aber 300 sieht auf den ersten Blick problematisch aus.
    Der maximale PWM Wert ist mit den Timer Einstellungen auf der Base 210.
    Für die PWM Werte eine 16 Bit Variable zu verwenden dürfte problematisch sein, das sollten 8 Bit sein.
    MfG,
    SlyD
    Erfahrener Benutzer Fleißiges Mitglied Avatar von I&amp;#9829;ROBOTIC
    Fürstenstein
    ich kanns gerade nicht testen, da mein akkupack leer ist, und wenn ich den rc empfänger am RP6 anstecke geht er aus, aber nicht nur ein Reset, sonder ganz aus, das LCD wird schwarz. der rp6 geht erst wieda an wenn ich den RC-empfänger anstecke... entweder er zieht viel zu viel Strom, oder er ist kaputt (dann könnte ich mir auch erklären, warum der RP6 bei den letzten versuchen nicht auf die fernsteuerung reagiert hat, das kann aber auch an dem fast leeren akkupack gelegen haben.)
    MfG Julian
    8
    Die Akkus sollte man gelegentlich auch mal einzeln in einem Ladegerät nachladen. Durch das dauernde serielle Laden aller Zellen im RP6 werden die Zellen ungleich aufgeladen. Auf Dauer schadet dies dem Akkus und die Gesamtkapazität nimmt drastisch ab.
    Fürstenstein
    ich hab die akkus immer einzeln geladen nur 1 mal mit einem 9,8V ladegerät, das aber tatsächlich nur mit 7,2 V lädt..
    Fürstenstein
    woran könnte es liegen, dass der RP6 beim anstecken des RC-empfängers im Reset gehalten wird (wenn das so ist ) oder bricht die spannung nur so stark ein ??
    MFG Julian
    Paderborn
    Da musst Du schon etwas mehr Infos liefern. Was ist wo und wie angeschlossen? Funktioniert der RC Empfänger für sich alleine? Hast Du ein Multimeter? Falls ja miss die Stromaufnahme... usw.
  1. LCD an RP6-Base
    Von radbruch im Forum Robby RP6
    Letzter Beitrag: 09.11.2010, 21:11
  2. Zusammenspiel der BASE und M32 Control
    Von inka im Forum Robby RP6
    Letzter Beitrag: 01.09.2010, 12:04
  3. bascom und ATTINY 85 PB0 klemmt
    Von kolisson im Forum Basic-Programmierung (Bascom-Compiler)
    Letzter Beitrag: 12.05.2009, 02:33
  4. RP6 Robot Base Hardware
    Von Dirk im Forum Robby RP6
    Antworten: 27
    Letzter Beitrag: 19.10.2007, 17:00
  5. Uart zwischen zwei Megas klemmt - - wieder einmal
    Von Murus im Forum Basic-Programmierung (Bascom-Compiler)
    Antworten: 7
    Letzter Beitrag: 06.05.2007, 16:12
