Ergebnis 1 bis 10 von 25
Thema: I2C Verständnisprobleme
    @Rolf
    Ja, danke. Kannst dich erstmal um deine Baustelle kümmern. Ich habe da nicht so ein stress.
    Also, zum Problem ADC. In meinem Programm steht das hier so:
    void task_test(void)
        I2CTWI_transmitByte(10, 23); Also hier erfolgt die Anfrage an das Register 23 von Slave(adresse 10)
        uint8_t result1 = I2CTWI_readByte(10);   und hier wird es eingelesen
        writeString_P("\n ADC0 High :   ");
        writeIntegerLength(result1, DEC, 3);  Und hier wird er über die serielle Schnittstelle ausgegeben.
        mSleep(500);
        I2CTWI_transmitByte(10, 25);
        uint8_t ergebnis = I2CTWI_readByte(10);
        writeString_P("\n ADC1 High :   ");
        writeIntegerLength(ergebnis, DEC, 3);
        mSleep(500);
            I2CTWI_transmitByte(10, 22);
        uint8_t ergebniss = I2CTWI_readByte(10);
        writeString_P("\n Batterie High :   ");
        writeIntegerLength(ergebniss, DEC, 3);
        mSleep(500);
        writeString_P(" | BAT:");writeIntegerLength(adcBat,DEC,4);
        writeString_P(" | AD0:");writeIntegerLength(adc0,DEC,4);
        writeString_P(" | AD1:");writeIntegerLength(adc1,DEC,4);
        writeChar('\n');
     * Timed Watchdog display only - the other heartbeat function
     * does not work in this example as we use blocked moving functions here.
    void watchDogRequest(void)
        static uint8_t heartbeat2 = false;
        if(heartbeat2)
            clearPosLCD(0, 14, 1);
            heartbeat2 = false;
        else
            setCursorPosLCD(0, 14);
            writeStringLCD_P("#");
            heartbeat2 = true;
    // I2C Requests:
     * The I2C_requestedDataReady Event Handler
    void I2C_requestedDataReady(uint8_t dataRequestID)
        checkRP6Status(dataRequestID);
    // I2C Error handler
     * This function gets called automatically if there was an I2C Error like
     * the slave sent a "not acknowledge" (NACK, error codes e.g. 0x20 or 0x30).
    void I2C_transmissionError(uint8_t errorState)
        writeString_P("\nI2C ERROR - TWI STATE: 0x");
        writeInteger(errorState, HEX);
        writeChar('\n');
        // We need to check if this is an INT0 Request from the Robot Base unit.
        // The Function call inside the if condition returns true if it was an
        // interrupt request, so we have to negate it here and if it was NOT
        // an interrupt request from the Robot base we can check any other sensors
        // from which you may have requested data...
        if(!checkRP6Status(dataRequestID))
            // Here you can Check other sensors/microcontrollers with their own
            // request IDs - if there are any...
    // Main function - The program starts here:
    int main(void)
        initRP6Control();
        initLCD();
        writeString_P("\n\nRP6 CONTROL M32 I2C Master Example Program!\n");
        writeString_P("\nMoving...\n");
        WDT_setRequestHandler(watchDogRequest);
        // Init TWI Interface:
        I2CTWI_initMaster(100);
        I2CTWI_setRequestedDataReadyHandler(I2C_requestedDataReady);
        I2CTWI_setTransmissionErrorHandler(I2C_transmissionError);
        sound(180,80,25);
        sound(220,80,25);
        setLEDs(0b1111);
        showScreenLCD("################", "################");
        mSleep(500);
        showScreenLCD("I2C-Master", "Movement...");
        mSleep(1000);
        setLEDs(0b0000);
        //I2CTWI_transmit3Bytes(I2C_RP6_BASE_ADR, 0, CMD_SET_ACS_POWER, ACS_PWR_MED);
        //writeString_P("ACS Power ist medium\n");
        //mSleep(500);
        I2CTWI_transmit3Bytes(I2C_RP6_BASE_ADR, 0, CMD_SET_WDT, true);
        writeString_P("WDT ist true\n");
        mSleep(500);
        I2CTWI_transmit3Bytes(I2C_RP6_BASE_ADR, 0, CMD_SET_WDT_RQ, true);
        writeString_P("WDT-RQ ist true\n");
        mSleep(500);
            //I2CTWI_transmit3Bytes(10, 0, 6, FWD);
        while(true)
        task_I2CTWI();
        task_test();
        return 0;
    Das Problem ist jetzt, dass der Wert diese ADC0 normal (durch Lichtsensor) 780 ist, aber über das M32 sind dass nur 230 ungefähr. mache ich da noch was falsch?
    Und beu ubat zeigt er mir 000 an.
    Und dann würde ich noch gern wissen wollen, was das wdt und wdt_RQ ist.
    LG
    Geändert von RP6fahrer (21.04.2011 um 16:32 Uhr)
    NRW
    Wenn du diese 2 Funktionen benutzt, liest du adc0 und adc1 richtig ein.
    void getADC0(void)
     I2CTWI_readRegisters(I2C_RP6_BASE_ADR, I2C_REG_ADC_ADC0_L, RP6data, 2);
     adc0 = RP6data[0] + (RP6data[1]<<8);
    void getADC1(void)
     I2CTWI_readRegisters(I2C_RP6_BASE_ADR, I2C_REG_ADC_ADC1_L, RP6data, 2);
     adc1 = RP6data[0] + (RP6data[1]<<8);
    RP6data müßtest du als uint8_t RP6data[2] deklarieren.
    Für Ubat sieht die Funktion genauso aus. Der 2. Parameter in der I2C-Lesefunktion wäre dann I2C_REG_ADC_UBAT_L.
    Dirk
    Erfahrener Benutzer Roboter-Spezialist Avatar von RolfD
    Ich bin mir sehr sicher, das dies Übertragungsfehler verursacht durch I2C sind. Genau solche Fehler treten z.B. auch mit Remotrol auf, einer Steuersoftware für den RP6. Wenn es dich wirklich interssiert, schau mal in den Thread:
    https://www.roboternetz.de/community...-RP6Lib-Bugfix
    LG Rolf
    Geändert von RolfD (21.04.2011 um 17:09 Uhr)
    Sind Sie auch ambivalent?
    NRW
    Bevor man das sagen kann, muss das Testprog erst mal funktionieren:
    1. Von Ubat wird nur das Highbyte gelesen und das sollte zwar auch nicht 0 sein, aber das müßte man noch checken.
    2. Von ADC0 und ADC1 wird nur das Lowbyte gelesen, da kann man nicht mit den direkt ermittelten 16-Bit-Werten vergleichen.
    Dirk
    @Dirk
    Welchen Grund sollte es sonst haben das Werte bei der Übertragung ab und zu verloren gehen.. und zwar ausgerechnet die spät gelesenen Register so ca. ab pos 20?
    Ausserdem funktioniert das Testprogramm schon was länger.
    Is aber auch egal. Mein Bot macht was er soll...
    Edit: Sorry, das war wohl ein Missverständnis zwischen mir und Dirk
    Geändert von RolfD (21.04.2011 um 22:11 Uhr)
    NRW
    Ich habe vom Testprog von RP6fahrer (17:25) "task_test" gesprochen.
    Dirk
    @Dirk
    Ja, dein Vorschlag hat funktioniert. Jetzt zeigt er die richtigen Werte an. Ich habe allerdings dazu noch ein paar fragen
    I2CTWI_readRegisters(10, I2C_REG_ADC_ADC0_L, RP6data, 2);
    I2CTWI_readRegisters ist der Befehl zum Lesen der Register
    10 die Adresse des Slave
    I2C_REG_ADC_ADC0_L das Register zum Lesen des Adc0 Registers -- Warum nicht I2C_REG_ADC_ADC0_H?
    RP6data ne Variable?
    2 wozu ist die gut?
    RP6data[0] + (RP6data[1]<< Bild   und was hat das im einzelnen zu sagen?
    Ich hoffe ich nerve euch nicht damit. Aber ich finde irgendwie nirgendwo eine einfache Erklärung zu den ganzen Aufrufen.
    Naja, denn noch nen schönen Abend und schöne Ostern
    LG RP6fahrer
    NRW
    @RP6fahrer:
    I2C_REG_ADC_ADC0_L ist nur eine Konstante, die ist in der RP6Control_I2CMasterLib.h als 23 definiert.
    Du könntest also auch I2CTWI_readRegisters(10, 23, RP6data, 2); schreiben.
    Damit liest du 2 Bytes, das erste ist der Low Wert von ADC0 (aus Register 23), der wird in RP6data[0] gespeichert.
    Das 2. Byte ist der High Wert von ADC0 (aus Register 24), der wird in RP6data[1] gespeichert.
    I2C_REG_ADC_ADC0_H braucht man nicht, weil das 2. Byte automatisch aus Register 24 gelesen wird, wenn man 2 Bytes einliest.
    Der komplette adc0-Wert errechnet sich als: adc0 = Low Wert + (256 * High Wert), also:
    adc0 = RP6data[0] + (RP6data[1] * 256);
    Anstelle von *256 kann man auch achtmal nach links schieben: <<8
    RP6data iat eine Variable.
    Dirk
  1. Verständnisprobleme -> Drehmomentrechner
    Von selan im Forum Motoren
    Antworten: 9
    Letzter Beitrag: 13.11.2006, 14:25
  2. Verständnisprobleme über die Funktionsweise eines Interrupts
    Von electrofux im Forum Basic-Programmierung (Bascom-Compiler)
    Letzter Beitrag: 31.10.2006, 16:14
  3. Syntax - Verständnisprobleme
    Von R2D3212 im Forum C - Programmierung (GCC u.a.)
    Antworten: 8
    Letzter Beitrag: 05.07.2006, 01:41
  4. Serielle Verständnisprobleme
    Von steffenvogel im Forum Software, Algorithmen und KI
    Letzter Beitrag: 09.04.2006, 13:23
  5. Antworten: 17
    Letzter Beitrag: 01.01.2006, 17:33
