Hab den Treiber aktualisiert, leider ohne Erfolg![]()
Code:RobotLoader log file SystemLogger started at: Sat Mar 26 21:35:50 CET 2011 (1301171750293) JVM System Information: java.runtime.name = Java(TM) SE Runtime Environment sun.boot.library.path = C:\Program Files (x86)\Java\jre6\bin java.vm.version = 19.1-b02 java.vm.vendor = Sun Microsystems Inc. java.vendor.url = http://java.sun.com/ path.separator = ; java.vm.name = Java HotSpot(TM) Client VM file.encoding.pkg = sun.io sun.java.launcher = SUN_STANDARD user.country = DE sun.os.patch.level = Service Pack 3 java.vm.specification.name = Java Virtual Machine Specification user.dir = C:\Program Files\RP6 Loader java.runtime.version = 1.6.0_24-b07 java.awt.graphicsenv = sun.awt.Win32GraphicsEnvironment java.endorsed.dirs = C:\Program Files (x86)\Java\jre6\lib\endorsed os.arch = x86 java.io.tmpdir = C:\Users\Admin\AppData\Local\Temp\ line.separator = java.vm.specification.vendor = Sun Microsystems Inc. user.variant = os.name = Windows XP sun.jnu.encoding = Cp1252 java.library.path = .;.\lib java.specification.name = Java Platform API Specification java.class.version = 50.0 sun.management.compiler = HotSpot Client Compiler os.version = 5.1 user.home = C:\Users\Admin user.timezone = Europe/Berlin java.awt.printerjob = sun.awt.windows.WPrinterJob file.encoding = Cp1252 java.specification.version = 1.6 java.class.path = RobotLoader_lib.jar;lib\jd2xx.jar;lib\RXTXcomm.jar;lib\comm.jar user.name = Admin java.vm.specification.version = 1.0 java.home = C:\Program Files (x86)\Java\jre6 sun.arch.data.model = 32 user.language = de java.specification.vendor = Sun Microsystems Inc. awt.toolkit = sun.awt.windows.WToolkit java.vm.info = mixed mode, sharing java.version = 1.6.0_24 java.ext.dirs = C:\Program Files (x86)\Java\jre6\lib\ext;C:\Windows\Sun\Java\lib\ext sun.boot.class.path = C:\Program Files (x86)\Java\jre6\lib\resources.jar;C:\Program Files (x86)\Java\jre6\lib\rt.jar;C:\Program Files (x86)\Java\jre6\lib\sunrsasign.jar;C:\Program Files (x86)\Java\jre6\lib\jsse.jar;C:\Program Files (x86)\Java\jre6\lib\jce.jar;C:\Program Files (x86)\Java\jre6\lib\charsets.jar;C:\Program Files (x86)\Java\jre6\lib\modules\jdk.boot.jar;C:\Program Files (x86)\Java\jre6\classes java.vendor = Sun Microsystems Inc. file.separator = \ java.vendor.url.bug = http://java.sun.com/cgi-bin/bugreport.cgi sun.io.unicode.encoding = UnicodeLittle sun.cpu.endian = little sun.desktop = windows sun.cpu.isalist = pentium_pro+mmx pentium_pro pentium+mmx pentium i486 i386 i86 JVM Memory Information: Free: 14633752 (14290 Kb) Max: 259522560 (253440 Kb) Total: 16252928 (15872 Kb) Initializing... RobotLoader Version: 1.5h Last build: 12.07.2010 Loading Configuration... Done! Global->loadLocalizedText Loading Board Library... Done! OS:WIN Initializing native communication library: JD2XX TERMINAL: RobotLoader Terminal TERMINAL: - type ".help" for command list! Loading File List... Done! Global->Enabling log panel... RobotLoader is ready to go. Message (Sat Mar 26 21:35:57 CET 2011) : RP6Main.actionPerformed: CONNECT Trying to open port: USB0 | FT232R USB UART | A7004RrJ Portlist: USB0 | FT232R USB UART | A7004RrJ Open Port failed! Got IO Exception! java.io.IOException: io error (4) at jd2xx.JD2XX.registerEvent(Native Method) at jd2xx.JD2XX.notifyOnEvent(JD2XX.java:709) at cls.d.a(Unknown Source) at cls.E.c(Unknown Source) at cls.E.actionPerformed(Unknown Source) at javax.swing.AbstractButton.fireActionPerformed(Unknown Source) at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source) at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source) at javax.swing.DefaultButtonModel.setPressed(Unknown Source) at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source) at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source) at java.awt.Component.processMouseEvent(Unknown Source) at javax.swing.JComponent.processMouseEvent(Unknown Source) at java.awt.Component.processEvent(Unknown Source) at java.awt.Container.processEvent(Unknown Source) at java.awt.Component.dispatchEventImpl(Unknown Source) at java.awt.Container.dispatchEventImpl(Unknown Source) at java.awt.Component.dispatchEvent(Unknown Source) at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source) at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source) at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source) at java.awt.Container.dispatchEventImpl(Unknown Source) at java.awt.Window.dispatchEventImpl(Unknown Source) at java.awt.Component.dispatchEvent(Unknown Source) at java.awt.EventQueue.dispatchEventImpl(Unknown Source) at java.awt.EventQueue.access$000(Unknown Source) at java.awt.EventQueue$1.run(Unknown Source) at java.awt.EventQueue$1.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at java.security.AccessControlContext$1.doIntersectionPrivilege(Unknown Source) at java.security.AccessControlContext$1.doIntersectionPrivilege(Unknown Source) at java.awt.EventQueue$2.run(Unknown Source) at java.awt.EventQueue$2.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at java.security.AccessControlContext$1.doIntersectionPrivilege(Unknown Source) at java.awt.EventQueue.dispatchEvent(Unknown Source) at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.run(Unknown Source) FEHLER (9) ||| Konnte den Comport nicht öffnen! In der Logdatei finden Sie weitere Informationen! Message (Sat Mar 26 21:36:02 CET 2011) : RP6Main.actionPerformed: CONNECT Trying to open port: USB0 | FT232R USB UART | A7004RrJ PORT ERROR (118) ||| Could not get USB information - please try again! JD2XX GET_PORTS EXCEPTION java.io.IOException: ???lid handle (5434515 at jd2xx.JD2XX.listDevices(Native Method) at jd2xx.JD2XX.listDevicesByDescription(JD2XX.java:642) at cls.d.c(Unknown Source) at cls.d.a(Unknown Source) at cls.E.c(Unknown Source) at cls.E.actionPerformed(Unknown Source) at javax.swing.AbstractButton.fireActionPerformed(Unknown Source) at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source) at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source) at javax.swing.DefaultButtonModel.setPressed(Unknown Source) at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source) at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source) at java.awt.Component.processMouseEvent(Unknown Source) at javax.swing.JComponent.processMouseEvent(Unknown Source) at java.awt.Component.processEvent(Unknown Source) at java.awt.Container.processEvent(Unknown Source) at java.awt.Component.dispatchEventImpl(Unknown Source) at java.awt.Container.dispatchEventImpl(Unknown Source) at java.awt.Component.dispatchEvent(Unknown Source) at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source) at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source) at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source) at java.awt.Container.dispatchEventImpl(Unknown Source) at java.awt.Window.dispatchEventImpl(Unknown Source) at java.awt.Component.dispatchEvent(Unknown Source) at java.awt.EventQueue.dispatchEventImpl(Unknown Source) at java.awt.EventQueue.access$000(Unknown Source) at java.awt.EventQueue$1.run(Unknown Source) at java.awt.EventQueue$1.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at java.security.AccessControlContext$1.doIntersectionPrivilege(Unknown Source) at java.security.AccessControlContext$1.doIntersectionPrivilege(Unknown Source) at java.awt.EventQueue$2.run(Unknown Source) at java.awt.EventQueue$2.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at java.security.AccessControlContext$1.doIntersectionPrivilege(Unknown Source) at java.awt.EventQueue.dispatchEvent(Unknown Source) at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.run(Unknown Source) FEHLER (8) ||| Konnte den Comport nicht öffnen! Vielleicht wird er schon von einer anderen Applikation verwendet? Aktualisieren Sie bitte die Portliste, evtl. ist der USB Port auch nicht mehr am Computer angeschlossen?
Zitieren
