Ergebnis 11 bis 20 von 26
Thema: Fehler in For-Schleife mit I2C Kommunikation
Baum-Darstellung
  1. #15
    Der fehlerbehaftete Code entspricht noch dem aus dem Anhang "Problem.zip", außer dass buffer[4] statt buffer[3] deklariert wurde.
    Der fehlerfreie Code sieht so aus (FOR-Schleife aufgelöst):
      // select display
      lcd_select(0);
      // check if ultrasonic sensor is busy
       busy_US[0] = i2c_start(US_left + I2C_READ);
       // address I2C device ultrasonic sensor with read access
       if (busy_US[0] == 0)
        distance[0] = i2c_readNak(); // read one byte
        i2c_stop(); // release I2C bus
        utoa(distance[0], buffer, 10);
        // move cursor to position on line 0
        lcd_gotoxy(10,0);
        // put string to display (line 0)
        lcd_puts(buffer);
        lcd_puts("  ");
       else
       busy_US[1] = i2c_start(US_front + I2C_READ);
       if (busy_US[1] == 0)
        distance[1] = i2c_readNak(); // read one byte
        utoa(distance[1], buffer, 10);
        lcd_gotoxy(14,0);
        lcd_puts(buffer);
        lcd_puts("  ");
       else
       busy_US[2] = i2c_start(US_right + I2C_READ);
       if (busy_US[2] == 0)
        distance[2] = i2c_readNak(); // read one byte
        utoa(distance[2], buffer, 10);
        lcd_gotoxy(18,0);
        lcd_puts(buffer);
        lcd_puts("  ");
       else
         i2c_start(US_general + I2C_WRITE);
         // address I2C device ultrasonic sensor with write access
         i2c_write(Start_US); //start new ultrasonic measurement
    Geändert von uffi (18.03.2011 um 12:06 Uhr)
