Das roten Kabel des RC-Akkus sind nur mit den roten Kabeln der Servos verbunden.
Hier wäre das (bestimmt unübersichtliche) Programm:
Code:///Hindernisausweichen mit Ultraschallsensor #include "RP6RobotBaseLib.h" #define pos1 320 #define pos2 410 #define pos3 600 void usleep(unsigned char usec); extern uint8_t acs_state; uint16_t servo_pos, servo_pos2, servo_timer, servo_dummy, Zeit; int16_t Dist, Dist_left, Dist_right, Dist_front; int8_t x, z, a, Dist_3; int main(void) { initRobotBase(); powerON(); startStopwatch3(); startStopwatch2(); servo_pos2=pos2; a=0; x=1; z=0; Dist_3=1; servo_pos=1000; setACSPwrLow(); while(true) { if ((getStopwatch2() > 20) && (acs_state < 2)) { servo_timer = servo_pos; extIntON(); while(servo_timer--) servo_dummy ^= servo_timer; extIntOFF(); servo_timer = servo_pos2; setLEDs(0b010000); while(servo_timer--) servo_dummy ^= servo_timer; setLEDs(0b000000); z=z+1; setStopwatch2(0); } if(z>3) { Dist=0; DDRC|=(SDA); PORTC&=~SDA; PORTC|=SDA; usleep(10); PORTC&=~SDA; DDRC&=~(SCL); while(!(PINC& SCL)) { setLEDs(0b000000); } while(PINC& SCL) { Dist=Dist+1; usleep(1); } if(PINC&=~SCL) { if(Dist<23) { if(Dist<12) { servo_pos2=pos1; startStopwatch4(); if(servo_pos<920) { a=0; changeDirection(LEFT); moveAtSpeed(50,50); } else { if(servo_pos>1150) { a=0; changeDirection(RIGHT); moveAtSpeed(50,50); } else { a=1; stopStopwatch3(); setStopwatch3(1030); if(adcLSL>adcLSR) {changeDirection(LEFT); moveAtSpeed(100,100);} else {changeDirection(RIGHT); moveAtSpeed(100,100);} } } } else { servo_pos2=pos2; a=0; stopStopwatch4(); setStopwatch4(0); changeDirection(FWD); if(servo_pos<1050) { moveAtSpeed(15,100); } else { moveAtSpeed(100,15); } } } else { servo_pos2=pos3; a=0; stopStopwatch4(); setStopwatch4(0); changeDirection(FWD); if(Dist_left-Dist_right>10) { moveAtSpeed(110,45); } else { if(Dist_right-Dist_left>10) { moveAtSpeed(45,110); } else { moveAtSpeed(100,100); } } } } setStopwatch1(0); z=0; } if(getBumperLeft()) {move(100, BWD, DIST_MM(150), true); rotate(100, RIGHT, 70, true);} if(getBumperRight()) {move(100, BWD, DIST_MM(150), true); rotate(100, LEFT, 70, true);} if(getStopwatch4()>2000) { if(adcLSL>adcLSR) {rotate(100, LEFT, 175, true);} else {rotate(100, RIGHT, 175, true);} stopStopwatch4(); setStopwatch4(0); } if(servo_pos<700 && servo_pos>600) Dist_right=Dist; if(servo_pos<1000 && servo_pos>1060) Dist_front=Dist; if(servo_pos<1550 && servo_pos>1450) Dist_left=Dist; if(a==0) startStopwatch3(); Zeit=getStopwatch3(); if(getStopwatch3()>1700) { if(x==0) { x=1; setStopwatch3(0); } else { x=0; setStopwatch3(0); } } if(a==0) { if(x==0) { servo_pos=600+Zeit/2; } if(x==1) { servo_pos=1550-Zeit/2; } } else { servo_pos=1030; } //task_RP6System(); task_ADC(); task_ACS(); task_Bumpers(); task_motionControl(); } return 0; } void usleep(unsigned char usec) { for (int s=0; s<usec; s++) { for (long int i=0; i<140; i++) { asm volatile("nop"); asm volatile("nop"); } } }
Zitieren
