Ergebnis 1 bis 10 von 13
Thema: SFR05 an RP6Base
    Neuer Benutzer Öfters hier Avatar von BeWe
    Leipzig
    Das roten Kabel des RC-Akkus sind nur mit den roten Kabeln der Servos verbunden.
    Hier wäre das (bestimmt unübersichtliche) Programm:
    ///Hindernisausweichen mit Ultraschallsensor
    #include "RP6RobotBaseLib.h"
    #define pos1 320
    #define pos2 410
    #define pos3 600
    void usleep(unsigned char usec);
    extern uint8_t acs_state;
    uint16_t servo_pos, servo_pos2, servo_timer, servo_dummy, Zeit;
    int16_t Dist, Dist_left, Dist_right, Dist_front;
    int8_t x, z, a, Dist_3;
    int main(void)
     initRobotBase();
     powerON();
     startStopwatch3();
     startStopwatch2();
     servo_pos2=pos2;
     a=0;
     x=1;
     z=0;
     Dist_3=1;
     servo_pos=1000;
     setACSPwrLow();
     while(true)
      if ((getStopwatch2() > 20) && (acs_state < 2))
       servo_timer = servo_pos;
       extIntON();
       while(servo_timer--) servo_dummy ^= servo_timer;
       extIntOFF();
       servo_timer = servo_pos2;
       setLEDs(0b010000);
       setLEDs(0b000000);
       z=z+1;
       setStopwatch2(0);
      if(z>3)
       Dist=0;
       DDRC|=(SDA);
       PORTC&=~SDA;
       PORTC|=SDA;
       usleep(10);
       PORTC&=~SDA;
       DDRC&=~(SCL);
       while(!(PINC& SCL))
        setLEDs(0b000000);
       while(PINC& SCL)
        Dist=Dist+1;
        usleep(1);
       if(PINC&=~SCL)
        if(Dist<23)
         if(Dist<12)
          servo_pos2=pos1;
          startStopwatch4();
          if(servo_pos<920)
           a=0;
           changeDirection(LEFT);
           moveAtSpeed(50,50);
          else
           if(servo_pos>1150)
            a=0;
            changeDirection(RIGHT);
            moveAtSpeed(50,50);
           else
            a=1;
            stopStopwatch3();
            setStopwatch3(1030);
            if(adcLSL>adcLSR) {changeDirection(LEFT); moveAtSpeed(100,100);} else {changeDirection(RIGHT); moveAtSpeed(100,100);}
         else
          servo_pos2=pos2;
          a=0;
          stopStopwatch4();
          setStopwatch4(0);
          changeDirection(FWD);
          if(servo_pos<1050)
           moveAtSpeed(15,100);
          else
           moveAtSpeed(100,15);
        else
         servo_pos2=pos3;
         a=0;
         stopStopwatch4();
         setStopwatch4(0);
         if(Dist_left-Dist_right>10)
          moveAtSpeed(110,45);
         else
          if(Dist_right-Dist_left>10)
           moveAtSpeed(45,110);
          else
       setStopwatch1(0);
       z=0;
      if(getBumperLeft()) {move(100, BWD, DIST_MM(150), true); rotate(100, RIGHT, 70, true);}
      if(getBumperRight()) {move(100, BWD, DIST_MM(150), true); rotate(100, LEFT, 70, true);}
      if(getStopwatch4()>2000)
       if(adcLSL>adcLSR) {rotate(100, LEFT, 175, true);} else {rotate(100, RIGHT, 175, true);}
       stopStopwatch4();
       setStopwatch4(0);
      if(servo_pos<700 && servo_pos>600) Dist_right=Dist;
      if(servo_pos<1000 && servo_pos>1060) Dist_front=Dist;
      if(servo_pos<1550 && servo_pos>1450) Dist_left=Dist;
      if(a==0) startStopwatch3();
      Zeit=getStopwatch3();
      if(getStopwatch3()>1700)
       if(x==0)
        x=1;
        setStopwatch3(0);
       else
        x=0;
        setStopwatch3(0);
      if(a==0)
       if(x==0)
        servo_pos=600+Zeit/2;
       if(x==1)
        servo_pos=1550-Zeit/2;
      else
       servo_pos=1030;
      //task_RP6System();
      task_ADC();
      task_ACS();
      task_Bumpers();
      task_motionControl();
     return 0;
      for (int s=0; s<usec; s++) {
        for (long int i=0; i<140; i++) {
          asm volatile("nop");
    Erfahrener Benutzer Roboter-Spezialist Avatar von RolfD
    Manchmal versteh ich die Leute in meinem Umfeld nicht... Du benennst ein Problem sogar selbst und löst es nicht... statt dessen erwartest Du, das wir dein Problem zu unserem machen und es für dich lösen? Und das obwohl wir alle sicher eigene Aufgaben haben und kein SRF5 zum testen vorliegt. SO... wird das nix...
    Vielleicht räumst Du erst mal dein ganz sicher unübersichtliches Programm auf, unterteilst es in Funktionen und logische Blöcke, (die man dann auch einzeln debuggen kann), kommentierst den Code anständig (ca. 50% des Textes sollte Docu sein) und versuchst damit schon selbst Lösungen zu erarbeiten? Meist findet man schon dabei die Probleme - wir helfen Dir gern wenn es dann noch klemmt - aber hier wird bestimmt keiner aus heiterem Himmel diesen endlos-Spagetticode debuggen!
    Es gibt ein paar gute Faustregeln zum Thema Programmieren - die z.B. auch in den RP6Libs weitgehend umgesetzt sind - und diese Regeln wurden nicht erdacht, damit Hinz und Kunz Mainloops über sagenhafte 190 Zeilen schreiben und sich dann wundern wenn es irgendwo klemmt !
    Du verstößt gegen allereinfachste Grundsätze wie aussagekräftige Variablennamen, Funktionen nicht länger als 1. Bildschirmseite, Constanten statt Zahlen usw... 190 zusammenhängende Zeilen nur und ausschließlich über Einrückungen lesbar zu machen ist heftig.
    Beschäftige dich doch vielleicht mal mit "Brainfuck" - eine Bytecode Programmiersprache, die Deinen Arbeitsstil perfektioniert hat. Dort kannst Du schon mit 8 einfachen Befehlen vergleichbare Verwirrung stiften und Du sparst sogar das Einrücken der Befehle. Bild
    http://de.wikipedia.org/wiki/Brainfuck
    Für mehr visuell denkende Menschen und Mausschubser ist vielleicht besser "Piet" und ein Malprogramm geeignet...
    http://de.wikipedia.org/wiki/Piet
    Sehr schön, aber eher konventionell ist auch:
    http://de.wikipedia.org/wiki/INTERCAL
    ... würde dein Zeichensalat da oben wenigstens fehlerfrei laufen - so wie diese wirklich abgedrehten 3 Beispiele - würde ich sagen.. "ok.. Genie und Wahnsinn liegen oft dicht beisammen" ... aber so ist das ein alphanumerischer Schrotthaufen und kein Programm! Tut mir leid wenn ich das so hart formuliere, ich hoffe Du lernst draus, machst es besser und nimmst es mir nicht übel.
    LG Rolf
    Geändert von RolfD (19.03.2011 um 04:00 Uhr)
    Sind Sie auch ambivalent?
