Gosub Max7219_setup
   Main:
   Disp_num = 3                                             '  Ausgabe Digit
   Disp_data = Wr1                                          '  Zähler var
   Gosub Disp_write
     ' setup max7219 config. registers
   Max7219_setup:
      Disp_num = &H0C : Disp_data = 0                       ' Shutdown On
      Gosub Disp_write
      Disp_num = 9 : Disp_data = &B0011_0111                ' Decode "B" For 1st 6
      Gosub Disp_write
      Disp_num = &H0A : Disp_data = &H0F                    ' Brightness Full
      Gosub Disp_write
      Disp_num = &H0B : Disp_data = 7                       ' # Digits 8
      Gosub Disp_write
      Disp_num = &H0F : Disp_data = 0                       ' Test Off
      Gosub Disp_write
      Disp_num = &H0C : Disp_data = 1                       ' Shutdown Off
      Gosub Disp_write
   Return
' Sends data to the Max7219 display driver
      Disp_write:
      Disable Interrupts
      Reset Ser_data
      Reset Ser_clk
      Reset Disp_en
      Shiftout Ser_data , Ser_clk , Disp_num , 1
      Shiftout Ser_data , Ser_clk , Disp_data , 1
      Set Disp_en
      Enable Interrupts
   Return
