Ok die eine Fehlermeldung ist jetzt weg!!!![]()
So siehts bei mir in den Ordnern aus:
C:\ASURO_src\SelfTest
C:\ASURO_src\FirstTry
C:\ASURO_src\AsuroLib280rc1\lib
Das steht im Makefile
LIBPATH = C:/ASURO_src/AsuroLib280rc1/lib
LIBFILE = asuro
Aber da habe ich jetzt noch ein Problem
Der Code ist sicher richtig
Wenn ich auf make all klicke kommt das:
Aus Code: C:/ASURO_src/AsuroLib280rc1/lib/asuro.c:61:21: error: myasuro.h: No such file or directoryCode:> "make.exe" all set -e; avr-gcc -MM -mmcu=atmega8 -DF_CPU=8000000UL -I. -g -Os -IC:/ASURO_src/AsuroLib280rc1/lib /inc -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=C:/ASURO_src/AsuroLib280rc1/lib/asuro.lst C:/ASURO_src/AsuroLib280rc1/lib/asuro.c \ | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > asuro.d; \ [ -s asuro.d ] || rm -f asuro.d C:/ASURO_src/AsuroLib280rc1/lib/asuro.c:61:21: error: myasuro.h: No such file or directory avr-gcc.exe: E:/utils/inc: No such file or directory set -e; avr-gcc -MM -mmcu=atmega8 -DF_CPU=8000000UL -I. -g -Os -IC:/ASURO_src/AsuroLib280rc1/lib /inc -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=test.lst test.c \ | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > test.d; \ [ -s test.d ] || rm -f test.d avr-gcc.exe: E:/utils/inc: No such file or directory set -e; avr-gcc -MM -mmcu=atmega8 -DF_CPU=8000000UL -I. -g -Os -IC:/ASURO_src/AsuroLib280rc1/lib /inc -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=C:/ASURO_src/AsuroLib280rc1/lib/asuro.lst C:/ASURO_src/AsuroLib280rc1/lib/asuro.c \ | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > asuro.d; \ [ -s asuro.d ] || rm -f asuro.d C:/ASURO_src/AsuroLib280rc1/lib/asuro.c:61:21: error: myasuro.h: No such file or directory avr-gcc.exe: E:/utils/inc: No such file or directory -------- begin -------- avr-gcc --version avr-gcc (WinAVR 20100110) 4.3.3 Copyright (C) 2008 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. avr-gcc -c -mmcu=atmega8 -DF_CPU=8000000UL -I. -g -Os -IC:/ASURO_src/AsuroLib280rc1/lib /inc -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=test.lst test.c -o test.o In file included from asuro.h:34, from test.c:1: e:/lib/gcc/../../avr/include/avr/signal.h:36:2: warning: #warning "This header file is obsolete. Use <avr/interrupt.h>." avr-gcc: /inc: No such file or directory make.exe: *** [test.o] Error 1 > Process Exit Code: 2 > Time Taken: 00:02
Ich habe im Wörterbuch gschaut
such / solch
file / datei, akte
directory/Datenverzeichnis
keine solche Datei oder Datenverzeichnis
Das was ich da mit den Ordnern gemacht habe stimmt oder
Mal schauen das ist sicher kein so großes Problem denke ich![]()
Lg
Edit:
Habe jetzt einfach myasuro.h da reinkopiert wo "er" es haben will da sind zwar sonst nur .c datein aber erwills so![]()
Nur noch der Fehler
from test.c:1:
> Time Taken: 00:01
Der rote teil stört mich noch ein bisschen
Wenn ihr da noch eine Idee habt bitte..........................
Zitieren
