Ergebnis 11 bis 17 von 17
Thema: Include ultrasonic.h
    #include "asuro.h"
    #include "ultrasonic.h"
    int abstand=0;
    int main(void)
    Init();
    SerPrint("\r\n --- ultrasonic test ---");
    Msleep(1000);
    do
    abstand = Chirp();
    SerPrint("\r\n distanz in cm: ");
    Msleep(500);
    PrintInt(abstand);
    while(1);
    return 0;
    Das ist der code den ich verwenden will
    shedepe
    Dann poste mal dein Makefile wie radbruch dich schon zig posts davor gebeten hat.
    Mein Makefile. Vllt versteht ihr ja mehr
    Hoffentlich kann mir jemand helfen ich weiss echt nicht was da falsch ist oder was ich falsch mache.
    # WinAVR Sample makefile written by Eric B. Weddington, Jörg Wunsch, et al.
    # Released to the Public Domain
    # Please read the make user manual!
    # On command line:
    # make all = Make software.
    # make clean = Clean out built project files.
    # make coff = Convert ELF to AVR COFF (for use with AVR Studio 3.x or VMLAB).
    # make extcoff = Convert ELF to AVR Extended COFF (for use with AVR Studio
    #                4.07 or greater).
    # make program = Download the hex file to the device, using avrdude.  Please
    #                customize the avrdude settings below first!
    # make filename.s = Just compile filename.c into the assembler code only
    # To rebuild project do "make clean" then "make all".
    # MCU name
    MCU = atmega8
    F_CPU = 8000000UL
    # Output format. (can be srec, ihex, binary)
    FORMAT = ihex
    # Target file name (without extension).
    TARGET = test
    # Optimization level, can be [0, 1, 2, 3, s]. 0 turns off optimization.
    # (Note: 3 is not always the best optimization level. See avr-libc FAQ.)
    OPT = s
    # additional Include path for libraries
    #LIBPATH = C:/ASURO_SRC/AsuroLib/lib
    LIBPATH = "C:/Dokumente und Einstellungen/dugaj/Desktop/FirstTry/lib"
    LIBFILE = asuro
    # additional include path for header files
    INCPATH = $(LIBPATH)/inc
    # List C source files here. (C dependencies are automatically generated.)
    SRC = $(TARGET).c
    # If there is more than one source file, append them above, or adjust and
    # uncomment the following:
    SRC += asuro.c
    # You can also wrap lines by appending a backslash to the end of the line:
    #SRC += baz.c \
    #xyzzy.c
    # List Assembler source files here.
    # Make them always end in a capital .S.  Files ending in a lowercase .s
    # will not be considered source files but generated files (assembler
    # output from the compiler), and will be deleted upon "make clean"!
    # Even though the DOS/Win* filesystem matches both .s and .S the same,
    # it will preserve the spelling of the filenames, and GCC itself does
    # care about how the name is spelled on its command-line.
    ASRC =
    # Optional compiler flags.
    #  -g:        generate debugging information (for GDB, or for COFF conversion)
    #  -O*:       optimization level
    #  -f...:     tuning, see GCC manual and avr-libc documentation
    #  -Wall...:  warning level
    #  -Wa,...:   tell GCC to pass this to the assembler.
    #    -ahlms:  create assembler listing
    CFLAGS = -g -O$(OPT) -I$(INCPATH) \
    	-funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums \
    	-Wall -Wstrict-prototypes \
    	-Wa,-ahlms=$(<:.c=.lst)
    # Virtual path for Source Files
    VPATH = $(LIBPATH)
    # Optional assembler flags.
    #  -ahlms:    create listing
    #  -gstabs:   have the assembler create line number information; note that
    #             for use in COFF files, additional information about filenames
    #             and function names needs to be present in the assembler source
    #             files -- see avr-libc docs [FIXME: not yet described there]
    ASFLAGS = -Wa,-ahlms=$(<:.S=.lst),-gstabs
    # Optional linker flags.
    #  -Wl,...:   tell GCC to pass this to linker.
    #  -Map:      create map file
    #  --cref:    add cross reference to  map file
    LDFLAGS = -Wl,-Map=$(TARGET).map,--cref
    LDFLAGS += -L$(LIBPATH)
    # Additional libraries
    # Minimalistic printf version
    #LDFLAGS += -Wl,-u,vfprintf -lprintf_min
    # Floating point printf version (requires -lm below)
    #LDFLAGS +=  -Wl,-u,vfprintf -lprintf_flt
    # -lm = math library
    LDFLAGS += -lm
    LDFLAGS += -l$(LIBFILE)
    # Define directories, if needed.
    DIRAVR = c:/winavr
    DIRAVRBIN = $(DIRAVR)/bin
    DIRAVRUTILS = $(DIRAVR)/utils/bin
    DIRINC = .
    DIRLIB = $(DIRAVR)/avr/lib
    # Define programs and commands.
    SHELL = sh
    CC = avr-gcc
    OBJCOPY = avr-objcopy
    OBJDUMP = avr-objdump
    SIZE = avr-size
    REMOVE = rm -f
    COPY = cp
    HEXSIZE = $(SIZE) --target=$(FORMAT) $(TARGET).hex
    ELFSIZE = $(SIZE) -A $(TARGET).elf
    FINISH = echo Errors: none
    BEGIN = echo -------- begin --------
    END = echo --------  end  --------
    # Define all object files.
    OBJ = $(SRC:.c=.o) $(ASRC:.S=.o)
    # Define all listing files.
    LST = $(ASRC:.S=.lst) $(SRC:.c=.lst)
    # Combine all necessary flags and optional flags.
    # Add target processor to flags.
    ALL_CFLAGS = -mmcu=$(MCU) -DF_CPU=$(F_CPU) -I. $(CFLAGS)
    ALL_ASFLAGS = -mmcu=$(MCU) -I. -x assembler-with-cpp $(ASFLAGS)
    # Default target.
    all: begin gccversion sizebefore $(TARGET).elf $(TARGET).hex $(TARGET).eep \
    	$(TARGET).lss sizeafter finished end
    # Eye candy.
    # AVR Studio 3.x does not check make's exit code but relies on
    # the following magic strings to be generated by the compile job.
    begin:
    	@$(BEGIN)
    finished:
    	@$(FINISH)
    end:
    	@$(END)
    # Display size of file.
    sizebefore:
    	@if [ -f $(TARGET).elf ]; then echo Size before:; $(ELFSIZE);fi
    sizeafter:
    	@if [ -f $(TARGET).elf ]; then echo Size after:; $(ELFSIZE);fi
    # Display compiler version information.
    gccversion :
    	$(CC) --version
    # Convert ELF to COFF for use in debugging / simulating in
    # AVR Studio or VMLAB.
    COFFCONVERT=$(OBJCOPY) --debugging \
    	--change-section-address .data-0x800000 \
    	--change-section-address .bss-0x800000 \
    	--change-section-address .noinit-0x800000 \
    	--change-section-address .eeprom-0x810000
    coff: $(TARGET).elf
    	$(COFFCONVERT) -O coff-avr $< $(TARGET).cof
    extcoff: $(TARGET).elf
    	$(COFFCONVERT) -O coff-ext-avr $< $(TARGET).cof
    # Create final output files (.hex, .eep) from ELF output file.
    %.hex: %.elf
    	$(OBJCOPY) -O $(FORMAT) -R .eeprom $< $@
    %.eep: %.elf
    	-$(OBJCOPY) -j .eeprom --set-section-flags=.eeprom="alloc,load" \
    	--change-section-lma .eeprom=0 -O $(FORMAT) $< $@
    # Create extended listing file from ELF output file.
    %.lss: %.elf
    	$(OBJDUMP) -h -S $< > $@
    # Link: create ELF output file from object files.
    .SECONDARY : $(TARGET).elf
    .PRECIOUS : $(OBJ)
    %.elf: $(OBJ)
    	$(CC) $(ALL_CFLAGS) $(OBJ) --output $@ $(LDFLAGS)
    # Compile: create object files from C source files.
    %.o : %.c
    	$(CC) -c $(ALL_CFLAGS) $< -o $@
    # Compile: create assembler files from C source files.
    %.s : %.c
    	$(CC) -S $(ALL_CFLAGS) $< -o $@
    # Assemble: create object files from assembler source files.
    %.o : %.S
    	$(CC) -c $(ALL_ASFLAGS) $< -o $@
    # Target: clean project.
    clean: begin clean_list finished end
    clean_list :
    	$(REMOVE) $(TARGET).hex
    	$(REMOVE) $(TARGET).eep
    	$(REMOVE) $(TARGET).obj
    	$(REMOVE) $(TARGET).cof
    	$(REMOVE) $(TARGET).elf
    	$(REMOVE) $(TARGET).map
    	$(REMOVE) $(TARGET).a90
    	$(REMOVE) $(TARGET).sym
    	$(REMOVE) $(TARGET).lnk
    	$(REMOVE) $(TARGET).lss
    	$(REMOVE) $(OBJ)
    	$(REMOVE) $(LST)
    	$(REMOVE) $(SRC:.c=.s)
    	$(REMOVE) $(SRC:.c=.d)
    # Automatically generate C source code dependencies.
    # (Code originally taken from the GNU make user manual and modified
    # (See README.txt Credits).)
    # Note that this will work with sh (bash) and sed that is shipped with WinAVR
    # (see the SHELL variable defined above).
    # This may not work with other shells or other seds.
    %.d: %.c
    	set -e; $(CC) -MM $(ALL_CFLAGS) $< \
    	| sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > $@; \
    	[ -s $@ ] || rm -f $@
    # Remove the '-' if you want to see the dependency files generated.
    -include $(SRC:.c=.d)
    # Listing of phony targets.
    .PHONY : all begin finish end sizebefore sizeafter gccversion coff extcoff \
    	clean clean_list program
    Leerzeichen im Path sollte man vermeiden:
    https://www.roboternetz.de/phpBB2/ze...ag.php?t=53281
    Da meine Makefiles automatisch erstellt werden, kann ich eigentlich nur raten:
    SRC += asuro.c
    Wenn es mehr als eine zusätzliche Datei einzubinden gibt, hänge sie hier an:
    SRC += asuro.c
    SRC += ultrasonic.c
    Neuer Benutzer
    Guten Tag,ich bin neu hier und möchte mich mit dem Asuro etwas beschäftigen.Ich habe mir den Asuro besorgt,aber ich habe noch Fragen zu der Programmierung..Ich habe ein asuro mit Ultrasonic Modul und ich kriege es nicht hin Bild
    Vielleicht kann jemand mir helfen und mein Programm anschauen?
    so sieht mein Programm aus:
    #include "asuro.h"
    int main(void)
    Ini t () ;
    int abstand=200;
    while (1)
    abstand = Chirp();
    Msleep(50);
    Printlnt(abstand);
    if(abstand>20)
    MotorDir(FWD,FWD);
    MotorSpeed(150,150);
    StatusLED(GREEN);
    else if ((abstand <=20) && (abstand >0) )
    MotorDir(BREAK,BREAK);
    MotorSpeed(O,O);
    MotorDir(RWD,RWD);
    MotorSpeed(120,0);
    BackLED (ON, ON) ;
    StatusLED (RED) ;
    Msleep (1000);
    return 0;
    while (1);
    und das ist meine Fehlermeldung:
    Build started 9.6.2014 at 09:58:15
    mmcu=atmega8 -Wall -gdwarf-2 -Os -std=gnu99 -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -MD -MP -MT Ultraschall_1.o -MF dep/Ultraschall_1.o.d -c ../Ultraschall_1.c
    /usr/bin/sh: -Wall: command not found
    make: [Ultraschall_1.o] Error 127 (ignored)
    mmcu=atmega8 -Wl,-Map=Ultraschall_1.map Ultraschall_1.o -o Ultraschall_1.elf
    /usr/bin/sh: -Wl,-Map=Ultraschall_1.map: command not found
    make: [Ultraschall_1.elf] Error 127 (ignored)
    avr-objcopy -O ihex -R .eeprom -R .fuse -R .lock -R .signature Ultraschall_1.elf Ultraschall_1.hex
    avr-objcopy: 'Ultraschall_1.elf': No such file
    make: *** [Ultraschall_1.hex] Error 1
    Build failed with 1 errors and 0 warnings...
    was fehlt dem Teil???
    - - - Aktualisiert - - -
    wie kann ich eigentlich Dateien als Anhänge hochladen?
    Niederlanden
    Zitat Zitat von VitaliW Beitrag anzeigen
    ...und das ist meine Fehlermeldung:
    Es versteht "-Wall" nicht. Vielleicht soll dort ein Leerzeichen zwischen stehen. Ich bin aber nicht so bekannt mit WinAVR unter Linux/Unix.
    Erweiterte Antwort Bearbeitung. Und dann unten bei Anhänge die Knopf "Anhänge verwalten".
    Benutzer Stammmitglied Avatar von Spacy Bar
    Dein Code hat auch ein paar Fehler: Bei Init() darf kein Leerzeichen drin sein und du musst erst while(1); reinschreiben dann return 0; .
    Hoffe geholfen zu haben!
    LG
    Spacy Bar
