Die ISR macht komische Dinge im Simulator...
Hab die bools mal durch uint8 ersetzt und den Wechsel mit nem xor realisiert.
Zumindest im Simulator tuts jetzt in der ISR.
Code:#include <stdlib.h> #include <avr/io.h> #include <avr/interrupt.h> #include <avr/power.h> #include <avr/sleep.h> #define F_CPU 9.6E6 #include <util/delay.h> #define CLOCK_PRESCALER 256 #define TIMER_PRESCALER 1024 #define TIMER_PERIOD (256 / (F_CPU / CLOCK_PRESCALER / TIMER_PRESCALER)) #define MEDIAN ( 1 * 60) /* 10 minutes */ volatile uint16_t countdown; volatile uint8_t timer_expired; volatile uint8_t on; ISR(TIM0_OVF_vect) { if (--countdown == 0) { TCCR0B = 0; /* turn off timer */ timer_expired = 0x01; clock_prescale_set(clock_div_1); } } ISR(INT0_vect) { on ^= 0x01; if (on) { PORTB |= (1<<PB4); // LED 2*flashing: Off _delay_ms(20); PORTB &= ~(1<<PB4); _delay_ms(20); PORTB |= (1<<PB4); _delay_ms(20); PORTB &= ~(1<<PB4); _delay_ms(20); } else { PORTB |= (1<<PB4); // LED 1*flashing: On _delay_ms(20); PORTB &= ~(1<<PB4); _delay_ms(20); } } static void starttimer(uint16_t timeout) { countdown = timeout; TCNT0 = 0; timer_expired = 0x00; clock_prescale_set(clock_div_256); TCCR0B = _BV(CS02) | _BV(CS00); /* start timer with prescaler 1024 */ } static void ioinit(void) { TIMSK0 = _BV(TOIE0); GIMSK |= (1<<INT0); //MCUCR |= (1<<ISC01); // Falling edge //MCUCR &= ~(1<<ISC00); // INT0 detection MCUCR = 0x02; on = 0x00; sei(); DDRB = _BV(4); /* connection for LED or something else */ } static void signal_event(void) { PORTB |= _BV(4); _delay_ms(1000); PORTB &= ~_BV(4); } int main(void) { ioinit(); while(1) { int r = rand(); uint16_t timeout = (unsigned)r % (unsigned)(2 * MEDIAN / TIMER_PERIOD) + 1; starttimer(timeout); do { sleep_mode(); } while (!timer_expired); if (on) { signal_event(); } } }
Zitieren
