Wenn jemand den Probot128 hat, funktioniert dieser Skript so?:
Code:Dim Klapp As Byte 'Counter variable Dim countdelay As Byte Sub main() 'Main Programm PRO_BOT128_INIT() 'PRO-BOT128 System setup DRIVE_INIT() 'Drive setup ENC_LED_ON() 'Encoder LEDs "ON" Klapp = 0 'Counter Var set To zero BEEP(250,150) 'Play Sound BEEP(100,150) 'Play Sound AbsDelay(500) Do While True 'Endless Loop If SOUND_LEVEL() > 700 Then 'Sound level larger Then value 700 increment Var Klapp +1 Klapp = Klapp + 1 AbsDelay(100) 'Wait 100ms End If Select Case Klapp 'Select Variable count Case 1 'Varibale Klapp is 1 Then LEDs "ON" Beepyfor() Case >=2 'Variable Klapp is 2 Or bigger = "Robo-Dance" Beepy2() End Select End While End Sub Sub Beepyfor() 'All Status LEDs "ON" FLL_ON() AbsDelay(1000) FLR_ON() AbsDelay(1000) BLL_ON() AbsDelay(1000) BLR_ON() AbsDelay(1000) Beepy() End Sub Sub Beepy() BEEP(250,150) BEEP(150,150) BEEP(350,150) BEEP(450,150) BEEP(350,150) BEEP(450,150) BEEP(350,150) BEEP(250,150) BEEP(550,150) BEEP(150,150) AbsDelay(1000) Beepy2() End Sub Sub Beepy2() 'Robo-Dance BEEP(150,150) 'G BEEP(300,150) 'C BEEP(350,150) 'D BEEP(400,150) 'E BEEP(300,150) 'C BEEP(200,150) 'A BEEP(300,150) 'C BEEP(150,150) 'G BEEP(150,150) 'G BEEP(200,150) 'A BEEP(300,150) 'C BEEP(350,150) 'D BEEP(250,150) 'H BEEP(300,150) 'C Endy() End Sub Sub Endy() DRIVE_INIT() DRIVE_ON() MOTOR_DIR(1,1) MOTOR_POWER(220,220) AbsDelay(2000) DRIVE_OFF() MOTOR_STOP() End Sub
Zitieren
