Ergebnis 1 bis 10 von 12
Thema: Anschluss für i2c-Lcd selbst festelegen
    Wie kann ich hier die Anchlusspins am PCF8574 selber festlegen und wo?
    Gruss
    copyright = Kent Andersson
    www       = none
    email     = kent@smmab.se
    comment   = I2C LCD driver
    libversion   = 1.02
    date         = 31 march 2002
    statement    = You are free to use this code any way you like, if you are able to optimize
    statement    = it better, please send me an update on my e-mail.
    history      = No known bugs.
    ;define a constant named PCF8574_LCD pointing to the I2C address
    ;dimension _lcd_e as byte to control the E-lines (4 lines LCD:s)
    ;_lcd_e should have one of the following values
    ;128 to enable E1, 64 to enable E2, 192 to enable both E1 and E2 (cls, deflcdchar)
    ;Connect the following pins from PCF8574 to LCD
    ;P0 - D4
    ;P1 - D5
    ;P2 - D6
    ;P3 - D7
    ;P4 - RS
    ;P5 - RW (not used, set to 0 to ground for write)
    ;P6 - E2 (on 1 or 2 line display nc)
    ;P7 - E1
    [_Init_LCD]
    _Init_LCD:
     *BASIC: waitms 50
     ldi r16,&hc0       ; this is to make the initialization on both halfs of a 4-line LCD
     Ldi _temp1, &h03   ; at init-time I call all routines before _lcd_e is loaded into r16
     Rcall _Send_to_LCD
     *BASIC: waitms 4
     Rcall _Send_to_LCD
     Rcall _Send_to_LCD
     Ldi _temp1, &h02
     Rcall _Send_to_LCD
     Ldi _temp1, &h28
     Rcall _Write_lcd_byte  ;RS flag should to be 0, so jump directly to write byte
     Ldi _temp1, &h08
     Ldi _temp1, &h0c
     Ldi _temp1, &h01
     Rjmp _Write_lcd_byte
    [END]
    [_Write_lcd]
    _Write_lcd:
    * lds r16,{_lcd_e}
     sbr r16,&h10                         ;set RS flag (4 high bits is used as control)
     rjmp _write_lcd_byte
    _Lcd_Control:
    * lds r16,{_lcd_e}
    _write_lcd_byte:
     push r24
     Swap _temp1
     Rcall _Write_lcd_Nibble
     pop r24
    _Write_lcd_nibble:
     Cbr _temp1,&HF0                      ; E1, E2, RW, RS low
    _Send_to_LCD:
    push r26
    push r27
     ldi r25,3
    _send_3_times:
     *BASIC: i2csend pcf8574_LCD,_temp1
     eor _temp1,R16	                      ; Xor E1 and/or E2 to set them
    ; @genus(250)
     ldi r26,0
    _LCD_delay:
     dec R26
     brne _LCD_delay
     Dec R25
     Brne _send_3_times
     eor _temp1,R16			       ; Xor to restore to initial state (even number of times)
    pop r27
    pop r26
    ret
    [END]
    Meinst du, was du machen musst, um das LCD anders als hier festgelegt anzuschliessen ?
    ;P0 - D4
    ;P1 - D5
    ;P2 - D6
    ;P3 - D7
    ;P4 - RS
    ;P7 - E1
    Die Sache ist in solchen Befehlen versteckt :
    [_Init_LCD]
     ldi r16,       &hc0
     Ldi _temp1, &h03
     Ldi _temp1, &h02
     Ldi _temp1, &h28
     Ldi _temp1, &h08
     Ldi _temp1, &h0c
     Ldi _temp1, &h01
    [_Write_lcd]
    Und dann noch insofern, als davon ausgegangen wird, dass
    D4-D7 an P0-P3 hängt.
    z.B:
    ldi r16, &hc0 ; initialisierung
    ist ja gleich
    ldi r16, &B1100000 ; die Bits P7 ------- P0
    also:
    ldi r16, P7=1, P6=1, P5-P0 = 0
    anders:
    ldi r16, E1=1, E2=1 der Rest=0
    Wenn ich dich überhaupt richtig verstanden habe.
    Man kann leichter konkret helfen, wenn du sagst, WAS von den Pins du anders anschliessen willst.
    mfg robert
    So wollte ich die festlegen:
    #define LD4			0				// Pin to Data Bus 4
    #define LD5			1				// Pin to Data Bus 5
    #define LD6			2				// Pin to Data Bus 6
    #define LD7			3				// Pin to Data Bus 7
    #define LRS			6				// Pin to RS Pin (Register Select)
    #define LRW			5				// Pin to Read/Write Pin
    #define LEN			4				// Pin to Enable Pin
    Re: Anschluss für i2c-Lcd selbst festelegen
    Irgendwie bin ich jetzt etwas irritiert, Was hat ein Busexpander PCF8574
    mit einem LCD zu schaffen?
    Ansonsten lassen sich die Pin`s für ein LCD unter Optionen/compiler/LCD
    festlegen.
    Gruß Richard
    Hast du ein 1-bzw 2-zeiliges Display ? (weil du E2 offenbar nicht brauchst)
    Ich hab versucht, bei den relevanten die Bits/Pins entsprechend zu tauschen.
    Die geänderten Zeilen hab' ich markiert und die ursprünglichen Zeilen als Kommentar stehen lassen.
    Ehrlich gesagt, bei ein paar trickreichen Commands blick' ich im moment nicht ganz durch. Daher logo keine Gewähr
    www       = none
    libversion   = 1.02
    ; ================= original ======
    ;P0 - D4
    ;P1 - D5
    ;P2 - D6
    ;P3 - D7
    ;P4 - RS
    ;P7 - E1
    ; ================= FUNKHELD ======
    ;P0 - D4
    ;P1 - D5
    ;P2 - D6
    ;P3 - D7
    ;P4 - E1
    ;P6 - RS
    ;P7 - nc
    [_Init_LCD]
    _Init_LCD:
     *BASIC: waitms 50
    ;ldi r16,&hc0       ; this is to make the initialization on both halfs of a 4-line LCD 		E1 + E2
    ;------------------------picnick-----------------------------------------
     ldi r16,&h10       ; this is to make the initialization on both halfs of a 4-line LCD
     Rcall _Send_to_LCD
     *BASIC: waitms 4
     Rcall _Send_to_LCD
     Rcall _Send_to_LCD
     Ldi _temp1, &h02
     Rcall _Send_to_LCD
     Ldi _temp1, &h28 										RW + 8
    ;Ldi _temp1, &h08
     Ldi _temp1, &h40
     Ldi _temp1, &h0c
     Ldi _temp1, &h01
    [END]
    [_Write_lcd]
    _Write_lcd:
    * lds r16,{_lcd_e}
    !sbr r16,&h10                         ;set RS flag (4 high bits is used as control) 		RS
     sbr r16,&h40                         ;set RS flag (4 high bits is used as control) 		RS	0x40
    _Lcd_Control:
    * lds r16,{_lcd_e}
    _write_lcd_byte:
     push r24
     Swap _temp1
     pop r24
    _Write_lcd_nibble:
    _Send_to_LCD:
    push r26
    push r27
     ldi r25,3
    _send_3_times:
    ; @genus(250)
     ldi r26,0
    _LCD_delay:
     dec R26
     brne _LCD_delay
     Dec R25
     Brne _send_3_times
    pop r27
    pop r26
    ret
    [END]
    Ich hab nicht gesehen, ob und wie der Herr Andersson
    "_temp1" festlegt ?
    Du weisst eh, dass du irgendwo
    CONST PCF8574_LCD = i2c-addresse
    und
    DIM _lcd_e AS BYTE ' das Byte, das du schreiben willst
    definieren musst ?
    ('tschuldige, wenn das eine überflüssige Frage ist )
    Lass mich hören, ob das funzt oder ob das LCD verdampft ist *g*
    @Richard offenbar will funkheld das LCD über den PCF betreiben und nicht 8 Pins verbraten. Scheint mir nicht aussergewöhnlich. Aber dadurch sind die Bascom -Einstellungen natürlich sinnlos
    mfg robert
    Nicht nur die Einstellungen, die ganzen I²C Bascom Routinen..da ist es doch
    weniger Aufwand man nimmt einen Mega 8 (als I²C slave, und hängt das Display normal daran. Oder gleich ein I²C Display. Ob hier (so) immer das Timing richtig klappt.......?
    Ich kann relativ faul sein und Suche mir immer den Weg das geringsten
    Widerstandes (Arbeit).
    Gruß Richard
    Vielleicht ist das Neuland für dich.
    Ich steuere das nomale LCD-Display(2*20) mit i2c(SDA und SCL) über den PCF8574.
    Alle 7 Datenleitungen gehen an den PCF8574.
    Gruss
    ...immer das Timing richtig klappt.....
    Null problemo.... , das Ding läuft wie Schmitz Katze....mit Winavr-und mit Bascom routinen.
    Warum zweifeln, baue es mal selber nach.
    Man nehme 1 Pfung Mehl, 3 Eier, etwas Wasser und....und....
    Bekommst du Hartz 4...und stehts um 12 Uhr auf...und...
    Man das ist hier ist ein Hobby, wenn du zu faul bist, dann lass es sein.
    Es läuft nocht nicht mit deinem Code.
    Wenn ich es so anklemme wie es im original angegeben ist funktioniert es mit Bascom :
    $regfile = "m32def.dat"
    $framesize = 32
    $swstack = 32
    $hwstack = 64
    $crystal = 16000000
    $baud = 19200
    $lib "Lcd_i2c.lib"
    Config I2cdelay = 1
    Config Sda = Portc.1
    Config Scl = Portc.0
    Const Pcf8574_lcd = 114
    Dim _lcd_e As Byte
    Enable Interrupts
    _lcd_e = 128
    Dim A As Byte
    Cls
    Lcd "hallo...i2c"
    Wait 1
    Locate 2 , 1
    Lcd "shiften."
    Wait 1
    For A = 1 To 10
       Shiftlcd Right                                           '
       Waitms 250
    Next
    For A = 1 To 10
       Shiftlcd Left
       Waitms 250
    Next
    End
