Ich habe heute ein C Programm erarbeitet, mit dem man bis zu 12 Servos unter Verwendung eines 8-Bit Timers ansteuern kann.
Code:// Example source code, that may be used to control up to 6 servo // motors using a single 8 bit timer. // On each timer overflow, the next channel is handled, which allows us // to multiplex between 6 channels. The timer compare register A is used // to control the puls width. You could add code to use the timer compare // register B which would allow handling of up to 12 channels. // With a 20Mhz clock, the duty cycle is 19,8ms // and the pulse width is pwm_value*00.128ms. // With a 16Mhz clock, the duty cycle is 25ms // and the pulse width is pwm_value*00.16ms. #include <avr/io.h> #include <avr/interrupt.h> #include <util/delay.h> // Values for up to six PWM channels. // On each channel, the special value 0 can be used to switch the signal off. volatile uint8_t pwm_value[6]; // The timer compare interrupt ends the current PWM pulse ISR(TIMER2_COMPA_vect) { PORTC &= ~(1+2+4+8+16+32); // set all 6 PWM outputs to low PORTB |= 4; // status LED off } // The timer overflow interrupt starts a PWM pulse, // on each interrupt, another channels is handled. ISR(TIMER2_OVF_vect) { static uint8_t channel=0; uint8_t value=pwm_value[channel]; if (value>0) { switch (channel) { // If you need less than 6 channels, then comment out the unused lines below case 0: PORTC |= 1; break; case 1: PORTC |= 2; break; case 2: PORTC |= 4; break; case 3: PORTC |= 8; break; case 4: PORTC |= 16; break; case 5: PORTC |= 32; break; } OCR2A=value; PORTB &= ~4; // status LED on } if (++channel==6) { // Do not change the 6, even when you need less than 6 channels! channel=0; } } int main() { // Initialize I/O Pins DDRB |= 4; // status LED DDRC |= 1+2+4+8+16+32; // six PWM outputs // Initialize timer 2, normal mode, prescaler 256, interrupt on overflow and compare match A. TCCR2A = 0; TCCR2B = (1<<CS22) | (1<<CS21); TIMSK2 = (1<<TOIE2) | (1<<OCIE2A); sei(); // Move servo on channel 5 to three different positions repeatedly. // The following values are designed for the servo ES-05 and 20Mhz CPU clock. while (1) { pwm_value[5]=38; _delay_ms(2000); pwm_value[5]=108; _delay_ms(2000); pwm_value[5]=188; _delay_ms(2000); } return 0; }
Zitieren
