das geht so:
Die Signale sind alle am anfang von dem Signal, das erste nach der langen Pause ist also kanal 1 usw...Code:$regfile = "m644def.dat" $framesize = 32 $swstack = 32 $hwstack = 32 $crystal = 20000000 $baud = 9600 ' ----- Empfänger ----- Dim Kanal_nick As Integer Dim Kanal_roll As Integer Dim Kanal_yaw As Integer Dim Kanal_pitch As Integer Dim Kanal_nick_check(3) As Integer Dim Kanal_roll_check(3) As Integer Dim Kanal_yaw_check(3) As Integer Dim Kanal_pitch_check(3) As Integer Dim Kanal_nick_init As Integer Dim Kanal_roll_init As Integer Dim Kanal_yaw_init As Integer Dim Kanal_pitch_init As Integer Dim Puls(8) As Integer Dim Kanal As Byte Dim Empfaenger_ok(4) As Byte '-----------Interupts---------- On Icp1 Get_empfaenger Nosave ' ICP fuer Funke On Ovf1 Kanal_reset Nosave Config Timer1 = Timer , Prescale = 8 , Capture Edge = Falling Enable Ovf1 Enable Icp1 Enable Interrupts '... 'blablablabalbal... codecode '... '------------Interupts--------------- ' FUnke am ICP interrup Get_empfaenger: push r10 push r11 push r24 push r25 push r26 push r27 in r24,sreg push r24 Puls(kanal) = Timer1 Timer1 = 40000 Incr Kanal pop r24 !Out Sreg , R24 pop r27 pop r26 pop r25 pop r24 pop r11 pop r10 Return Kanal_reset: push r24 in r24,sreg push r24 Kanal = 1 pop r24 !Out sreg,r24 pop r24 Return End
[/code]
Zitieren
