Ergebnis 11 bis 20 von 24
Thema: Wo krieg ich BASCOM Basic her?
    Mein Vorposter hat doch schon geschrieben :
    Unter http://www.rowalt.de/mc/ gibts ne kleine Einführung in Bascom!
    Wer lesen kann ist besser dran. Lese die Seiten durch und melde dich d a n n nochmal. Bild
    Gruss
    ok danke jetzt hab ich das endlich gefunden
    mit freundlichen Grüßen
    zwerg1
    Zitat Zitat von vish
    Ja, kannst du.
    Allerdings hast du dann eine Beschränkung von 2 Kilobyte, was aber normalerweise ausreicht.
    Hallo Vish!
    Ich habe mir Bascom einmal in der Demo-Version heruntergeladen, es gehen neuerdings anscheinend auch 4kB Code.
    Auszug aus der Lizenzvereinbarung:
    Thank you for trying this DEMO of BASCOM-AVR
    This file contains some additional info on BASCOM-AVR.
    This demo can compile up to 4096 bytes of code, when you have more code, you
    will receive an error.
    The commercial version is available for : 79 euro.
    Support and updates are free for the commercial version.
    It is the intention of MCS Electronics to keep updates free.
    In the future, support might be a paid service, while updates remain free.
    But again, the intention is to keep it free.
    There is no support for this DEMO other than when you encounter
    problems during installation.
    There is a forum at www.mcselec.com/forum with members that can help you.
    The DEMO may not be used to created commercial devices.
    Have fun,
    Mark Alberts
    MCS Electronics
    ***************             IMPORTANT            ***********************
    When you don't see the pictures of the buttons in the IDE you need to install
    a newer version of the comctl32.dll.
    You can download the file  40comupd.exe from microsoft,or from MCS.
    When you get an Error 123 you probably don't have a printer installed
    Install a printer driver (HP Laserjet 4 for example) and run again.
    There does not need to be a printer connected, only as printer created.
    When you get an OleSysError, reboot Windows and run SETUP again.
    After rebooting again, run Bascom again.
    When you install the software on a NT machine you need administrator rights
    during SETUP. You also must run Bascom once as an administrator so that the
    ioport.sys driver will be setup. After this you can use the software logged on
    as a normal user without administation rights.
    - If you run into problems send an email to support@mcselec.com
      with the problem and all the generated file of your project(rpt,cfg,bas,bin,etc.)
      Please specify that your version is the DEMO version.
    - Check out the sample files which contain info on the syntax.
      The samples are a bit simple and only intended to show the syntax of the commands.
    Some samples require a specific chip or more code then the DEMO can create.
    You will get errors then at compile time.
    While the demo is restricted, it allows you to work with the smaller chips and to try
    all functions.
    The DEMO is ideal for educational institutes as you only need some cheap hardware.
    As we do not earn money on the demo, we do not give support, or limited support.
    Customers are helped first, then DEMO users are helped if there is time.
    The last restriction on the DEMO is that it does not come with the LIB Assembler code.
    The LIB assem code only comes with the full version.
    Grüsse Wolfgang
    PB
    Hallo Wolfgang!
    Davon weiß ich ja noch gar nichts! Welche Version benutzt du denn?
    Ich habe Version 1.11.7.4, dort bin ich noch auf 2048 Bytes beschränkt.
    Grüsse zurück,
    Jonas
    Hallo Wolfgang!
    Grüsse zurück,
    Jonas
    Ich hab die aktuellste Version 1.11.7.7 downgeloadet, da sind es dann 4kB Code anstatt der bisherigen 2kB...
    Also holen! Bild
    Grüsse Wolfgang
    Aachen
    Was hat sich denn noch mit den neueren Versionen geändert?
    MFG Moritz
    Hallo RCO!
    Das kann ich dir nicht genau sagen, ich habe mir nur aus Interesse Bascom geladen, ich programmier AVR oder andere Dinge auser der CC nicht in BASIC, wollte es mir nur auch einmal mit ansehen. Aber was brauchst du für Informationen? Frag einfach mal wichtige Dinge, ich kanns ja nachsehen, einen Vergleich kann ich selbst jedoch nicht durchführen da ich eine alte Version nicht besitze.
    Grüsse Wolfgang
    Nachtrag: Die Samples als Info?
     Datentr„ger in Laufwerk C: SYSTEM
     Seriennummer des Datentr„gers: 1946-16D4
     Verzeichnis von C:\Programme\MCS Electronics\BASCOM-AVR\SAMPLES
    .              <DIR>        05.01.05  21:18 .
    ..             <DIR>        05.01.05  21:18 ..
    LAWICEL        <DIR>        05.01.05  21:18 Lawicel
    123      BAS           287  09.04.00  23:07 123.BAS
    BOOT128  INC        10.014  29.05.03  23:52 boot128.inc
    SMALLF~1 FON           834  16.08.02   0:34 smallfont8x8.font
    FONT8X~1 FON         6.547  03.10.03  15:04 font8x8.font
    CHR      BAS           406  05.01.03   2:02 CHR.BAS
    APN3     BAS         3.678  05.01.03   1:59 APN3.BAS
    $INC     BAS           784  21.07.03  12:47 $inc.bas
    $SERIA~1 BAS         2.268  05.01.03   1:58 $serialinput.bas
    1200     BAS           318  05.07.03  16:02 1200.bas
    1WIRE    BAS         2.362  05.01.03   1:58 1wire.bas
    1WIRED~1 BAS        10.642  03.02.03  15:26 1wireDS2450.bas
    1WIRES~1 BAS         2.237  05.01.03   1:58 1wireSearch.bas
    A_RENAME BAS            22  09.04.00  20:28 a_rename.bas
    ADC      BAS         1.531  02.05.04  21:52 adc.bas
    ADC_INT  BAS         1.745  02.05.04  21:52 adc_int.bas
    APPNT1   BAS         1.435  05.01.03   1:59 APPNT1.BAS
    ARRAY    BAS           936  05.01.03   1:59 Array.bas
    AT86RF~1 BAS         2.022  03.07.03  11:54 AT86RF401_1.bas
    AT86RF~2 BAS         1.325  03.07.03  23:54 AT86RF401_2.bas
    AT86RF~3 BAS         1.953  01.07.03  13:10 AT86RF401_3.bas
    BIN2BC~1 BAS           640  31.10.00   0:58 bin2bcd16.bas
    ATTINY13 BAS           119  28.09.04  21:26 attiny13.bas
    BARCODE  BAS         3.739  05.01.03   1:59 barcode.bas
    BASMON   BAS         3.876  24.08.04  21:50 basmon.bas
    BCD      BAS         2.119  05.12.02  23:33 bcd.bas
    BCH_FN~1 BAS        17.455  06.05.02   0:33 bch_fnc_zeh.bas
    BG30DB~1 BAS         8.831  03.07.01  23:29 BG30dB_LCD.bas
    BG30DB~2 BAS         8.052  03.07.01  23:29 BG30dB_LED.bas
    BITS-N~1 BAS           712  09.10.04  22:31 bits-nbits.bas
    BOOLEAN  BAS         1.654  05.01.03   2:01 Boolean.bas
    BOOT     BAS         7.920  08.01.02   0:20 boot.bas
    BOOT128  BAS         9.750  28.07.02  12:00 boot128.bas
    BOOT128X BAS         1.624  30.05.03   0:18 boot128x.bas
    BOOTM8   BAS        13.910  24.01.03  16:04 BootM8.bas
    BOOTM8V  BAS        16.343  29.04.04  21:29 BootM8V.bas
    BOOTNEW  BAS           564  30.05.03   0:10 bootnew.bas
    DELAY    BAS           629  05.01.03   2:03 DELAY.BAS
    CONST    BAS           975  05.01.03   2:02 CONST.BAS
    CAPTURE  BAS         2.922  14.09.02  17:05 capture.bas
    CASE     BAS           630  05.01.03   2:01 Case.bas
    CIRCLE   BAS         1.106  16.04.02  13:19 circle.bas
    CLIENT~1 BAS         4.206  01.01.03  23:26 clienttest.bas
    CLOCK    BAS         3.895  18.10.02   0:41 Clock.bas
    CLOCKENG BAS        14.048  24.04.03  10:18 clockeng.bas
    CONFIG~1 BAS         6.207  20.05.03   9:51 CONFIG_AVR-DOS.bas
    CONFIG~2 BAS         2.278  01.05.03   0:03 Config_FlashCardDrive.bas
    CONFIG~3 BAS         1.931  02.05.03   8:43 Config_FlashCardDrive_EL_PIN.bas
    CONFIG~4 BAS           365  02.05.03   8:43 Config_XRAMDrive.bas
    DATETI~1 BAS        13.448  08.12.02  21:49 DateTime_Test1.bas
    DEBOUN   BAS           967  07.10.99   0:59 Deboun.bas
    DECLARE  BAS         3.883  05.01.03   2:02 Declare.bas
    DECR     BAS           519  05.01.03   2:02 DECR.BAS
    STRINGS  BAS         3.732  05.01.03   2:16 STRINGS.BAS
    SINGLE   BAS         1.636  05.01.03   2:15 SINGLE.BAS
    DIM      BAS         1.156  05.01.03   2:03 DIM.BAS
    DO_LOOP  BAS           795  05.01.03   2:03 DO_LOOP.BAS
    DOUBLE1  BAS         4.645  27.11.04  22:41 double1.bas
    DOUBLE2  BAS         1.779  27.11.04  22:54 double2.bas
    DS1307   BAS         3.455  13.11.02  23:29 ds1307.bas
    DS1620   BAS         9.790  05.01.03   2:03 DS1620.BAS
    DS2405   BAS         1.268  05.01.03   2:04 ds2405.bas
    DT006_1  BAS         1.989  05.01.03   2:04 DT006_1.bas
    DT104    BAS           793  22.12.99   0:57 dt104.bas
    DTMFOUT  BAS         1.731  01.09.01   1:05 dtmfout.bas
    EEPROM   BAS         2.078  18.11.00   0:54 EEPROM.BAS
    EEPROM2  BAS         1.995  01.10.03  21:45 EEPROM2.bas
    ENCODER  BAS         1.382  14.03.04  22:42 Encoder.bas
    EXIT     BAS           684  05.01.03   2:04 EXIT.BAS
    FLASHC~1 BAS        12.488  29.05.03   2:15 FlashCard-demo.bas
    FLASHD~1 BAS         2.634  11.05.03   2:43 FlashDisk.bas
    FOR_NEXT BAS           745  05.01.03   2:04 FOR_NEXT.BAS
    FORMAT   BAS           479  05.01.03   2:05 format.bas
    FS_SUB~1 BAS         8.142  07.05.03   9:00 FS_SubFunc_Decl_lib.bas
    FUNCTION BAS         1.182  05.01.03   2:05 Function.bas
    FUSING   BAS           962  05.01.03   2:05 fusing.bas
    FUTUTE~1 BAS           833  07.02.02   0:20 fututelec8535.bas
    GETATKBD BAS         3.711  13.09.03  22:09 getatkbd.bas
    GETATK~1 BAS         4.844  28.08.03  14:24 getatkbd_int.bas
    GETKBD   BAS           794  05.01.03   2:05 getkbd.bas
    GETRC    BAS         1.200  05.03.00   2:46 getrc.bas
    GOSUB    BAS           675  05.01.03   2:06 GOSUB.BAS
    GREYCODE BAS           769  05.01.03   2:06 greycode.bas
    I2C      BAS         3.309  05.01.03   2:06 I2C.BAS
    I2CSLA~1 BAS         5.039  14.02.03  23:38 i2cslave_pcf8574.bas
    IDLE     BAS         1.227  05.01.03   2:06 idle.bas
    IF_THEN  BAS         1.123  05.01.03   2:06 IF_THEN.BAS
    INCLUDE  BAS           462  05.01.03   2:06 INCLUDE.BAS
    INCR     BAS           465  05.01.03   2:06 INCR.BAS
    INITMI~1 BAS           780  09.10.04  22:25 initmicro.bas
    INKEY    BAS         1.047  05.01.03   2:07 Inkey.bas
    INPUT    BAS         1.141  05.01.03   2:07 INPUT.BAS
    INSTR    BAS           698  05.01.03   2:07 instr.bas
    INT0     BAS         1.318  05.01.03   2:07 INT0.BAS
    INTERP~1 BAS        51.171  12.05.03  13:42 Interpreter.bas
    KS108    BAS         2.565  03.10.03  14:56 KS108.bas
    LCD      BAS         4.803  07.05.04  22:53 LCD.BAS
    LCD_I2~1 BAS         5.915  06.08.02  19:22 lcd_i2c_demo.bas
    LCD4     BAS           113  29.07.01   1:09 lcd4.bas
    LCD4BUSY BAS           767  05.01.03   2:09 lcd4busy.bas
    LCDCUS~1 BAS           412  16.03.01  23:28 lcdcustom4bit.bas
    LCDCUS~2 BAS           651  17.03.01   0:15 lcdcustom4bit2e.bas
    LCDSTK~1 BAS         4.566  05.01.03   2:09 LcdSTK200.bas
    LIBDEMO  BAS           692  05.01.03   2:09 libDEMO.bas
    LONG     BAS         1.238  05.01.03   2:09 LONG.BAS
    LOOKDOWN BAS           996  05.01.03   2:10 lookdown.bas
    LTC1257  BAS           593  05.01.03   2:10 ltc1257.bas
    M128     BAS         1.693  13.05.03  23:17 m128.bas
    M128103  BAS           649  30.03.02   0:44 m128103.bas
    M128CAN  BAS           572  24.11.04  23:28 m128CAN.bas
    M16      BAS         1.969  18.11.02   0:58 M16.bas
    M161     BAS         1.006  05.01.03   2:10 M161.bas
    M162     BAS         1.691  10.10.03   0:02 M162.bas
    M163     BAS           524  13.03.03   0:12 M163.bas
    M169_LCD BAS         3.050  29.09.04  21:11 m169_LCD.bas
    M32      BAS           976  20.07.04  22:50 m32.bas
    M323     BAS           413  16.04.02  12:26 m323.bas
    M64      BAS         1.519  31.05.03  22:27 m64.bas
    M8515    BAS           524  13.03.03   0:13 M8515.bas
    M8535    BAS           554  13.03.03   0:26 M8535.bas
    M8-TWI~1 BAS         2.365  10.07.04  22:14 M8-TWI-master.bas
    M8-TWI~2 BAS         3.322  07.11.04   1:05 M8-TWI-slave.bas
    MAGCARD  BAS         2.062  05.01.03   2:11 magcard.bas
    MEGA48   BAS         1.365  22.11.04   0:42 mega48.bas
    MEGA8    BAS           575  04.11.03   0:21 mega8.bas
    MEGA88   BAS         1.709  23.11.04  23:42 mega88.bas
    MEGACL~1 BAS         2.144  02.06.03  22:06 megaclock.bas
    MINMAX   BAS           818  07.05.04  21:59 minmax.bas
    MODBUS~1 BAS         4.378  05.01.03   2:11 modbus slave.bas
    ONGOSUB  BAS           738  05.01.03   2:12 ONGOSUB.BAS
    OPEN     BAS         2.209  05.01.03   2:12 open.bas
    PEEK     BAS         1.050  05.01.03   2:12 PEEK.BAS
    PORT     BAS         2.001  05.01.03   2:12 PORT.BAS
    POWER    BAS           465  05.01.03   2:12 POWER.BAS
    PRINT    BAS         1.231  05.01.03   2:12 PRINT.BAS
    PS2_EMUL BAS         1.684  18.03.03   0:01 ps2_emul.bas
    PS2_KB~1 BAS         1.640  30.12.02  23:29 ps2_kbdemul.bas
    RC5      BAS         1.533  05.01.03   2:12 rc5.bas
    READDATA BAS         1.639  05.01.03   2:13 READDATA.BAS
    RND      BAS           585  13.02.00  23:19 rnd.bas
    ROTATE   BAS         1.131  20.06.99   2:44 rotate.bas
    ROUND_~1 BAS           347  05.05.02   1:52 round_fix_int.bas
    RS232B~1 BAS         1.846  05.01.03   2:13 rs232buffer.bas
    RS232B~2 BAS         1.953  05.01.03   2:13 RS232BUFFER1.BAS
    RS232B~3 BAS           723  05.05.02  23:52 rs232bufferOut.bas
    RS232B~4 BAS           904  05.05.02  23:54 RS232BUFFEROUT1.BAS
    SED      BAS         2.318  20.06.04  22:56 sed.bas
    SED1520  BAS         2.024  20.06.04  22:56 SED1520.bas
    SENDRC5  BAS           819  05.01.03   2:13 sendrc5.bas
    SENDRC6  BAS           987  05.01.03   2:14 sendrc6.bas
    SENDSPI  BAS         1.153  27.04.02  22:52 sendspi.bas
    SERIN_~1 BAS         1.444  10.10.04  21:31 serin_out.bas
    SERINT   BAS         2.580  05.01.03   2:14 serint.bas
    SERVER~1 BAS         4.881  01.01.03  23:34 servertest.bas
    Servos   BAS         1.426  09.04.03  16:22 servos.bas
    SHIFT    BAS         1.665  12.02.00   0:49 shift.bas
    SHOWPICE BAS         1.362  16.04.02  10:50 showpicE.bas
    SHT11_~1 BAS         3.893  08.06.02   3:51 SHT11_Bascom.bas
    SIMM100  BAS           914  30.10.00   1:20 simm100.bas
    SINGLE~1 BAS         7.363  06.05.01  12:58 SinglePID.bas
    SMS      BAS         6.087  05.01.03   2:15 sms.bas
    SONYSEND BAS           558  05.01.03   2:15 sonysend.bas
    SOUND    BAS           666  05.01.03   2:15 Sound.bas
    SPI      BAS           142  27.01.04   0:22 spi.bas
    SPI-SL~1 BAS         1.812  11.11.01  18:01 spi-slave.bas
    PS2_EMUL ERR           195  05.01.05  21:22 PS2_EMUL.ERR
    EEPROM   EEP             5  22.02.01   1:25 EEPROM.EEP
    SPI-SO~1 BAS         2.412  05.01.03   2:15 spi-softslave.bas
    STACK    BAS         1.487  03.02.02  22:51 stack.bas
    STK500~1 BAS           332  29.07.01   0:56 stk500print.bas
    SWAP     BAS           710  05.01.03   2:16 SWAP.BAS
    T6963_~1 BAS         3.870  05.01.03   2:16 t6963_240_128.bas
    T6963V3  BAS         2.538  14.05.03   8:28 t6963v3.bas
    TCPIP    BAS         2.679  25.12.02   1:25 tcpip.bas
    TEST_F~1 BAS         4.156  05.07.03  16:08 Test_FPTrig2.bas
    TIMEOUT  BAS           770  10.10.04  22:13 timeout.bas
    TIMER0   BAS         2.198  09.07.00   0:25 timer0.bas
    TIMER1   BAS         2.545  14.09.02  17:06 timer1.bas
    TINY15   BAS           121  16.08.03  22:09 tiny15.bas
    TINY26   BAS           479  26.09.04   0:16 tiny26.bas
    TWI-MA~1 BAS         2.014  11.10.04   0:16 TWI-master.bas
    TWI-SL~1 BAS         3.260  11.10.04   0:33 TWI-slave.bas
    UDPTEST  BAS         5.336  01.01.03  23:13 udptest.bas
    WATCHD   BAS           696  03.05.04  22:23 WATCHD.BAS
    WEBSER~1 BAS        11.005  03.01.03   3:42 webserver.bas
    WHILE_W  BAS           694  05.01.03   2:17 WHILE_W.BAS
    X10      BAS         1.495  06.06.03   0:11 x10.bas
    XRAM     BAS         1.075  05.01.03   2:17 XRAM.BAS
    KS108    BGF           570  28.09.03  16:22 KS108.bgf
    MCS      BGF         1.086  02.12.02  20:50 mcs.bgf
    SMILE    BGF           145  11.08.02  22:17 smile.bgf
    MCS      BMP         2.110  14.10.00   1:49 mcs.bmp
    EEPROM2  EEP            46  01.10.03  21:44 EEPROM2.EEP
    SHOWPICE EEP           621  16.04.02  10:44 SHOWPICE.EEP
    FONT16~1 FON         8.688  03.10.03  14:54 font16x16.font
    BASAVR   LOG            37  05.01.05  21:22 basavr.log
    SINGLE~1 OBJ         8.558  05.01.05  21:24 SINGLEPID.OBJ
    SINGLE~1 RPT        49.646  05.01.05  21:24 SINGLEPID.RPT
    SINGLE~1 SMX            13  05.01.05  21:24 SINGLEPID.SMX
    SINGLE~1 HEX         5.311  05.01.05  21:24 SINGLEPID.HEX
    SINGLE~1 BIN         1.882  05.01.05  21:24 SINGLEPID.BIN
    SINGLE~1 DBG         8.828  05.01.05  21:24 SINGLEPID.DBG
    SINGLE~1 SIM           324  05.01.05  21:25 SINGLEPID.SIM
    INFO     TXT             0  06.01.05   9:50 info.txt
    DIT      BAT            16  06.01.05   9:50 dit.bat
           204 Datei(en)               611.724 Bytes
             3 Verzeichnis(se)       15.979,28 MB frei
    Die Libraries:
     Verzeichnis von C:\Programme\MCS Electronics\BASCOM-AVR\LIB
    AVR-DOS  LBX        62.638  26.11.04  17:35 AVR-DOS.LBX
    CF_EMB~1 LIB         9.768  20.04.04  10:31 CF_EmbedSysXRAM.LIB
    CF_EMB~1 LBX         6.004  20.04.04  10:32 CF_EmbedSysXRAM.LBX
    SQR      LBX         2.573  06.05.02   0:50 SQR.LBX
    BCD      LBX           736  11.03.02  21:46 bcd.LBX
    DATETIME LBX        11.090  26.06.04  21:53 datetime.LBX
    DOUBLE   LBX        36.221  20.10.04  10:55 Double.LBX
    EDTP_X~1 LBX         6.130  03.11.03   0:19 EDTP_XRAMDrive0.LBX
    EDTP_X~1 LIB        10.165  15.10.03   9:07 EDTP_XRAMDrive0.lib
    EUROTI~1 LBX         1.182  07.05.02  22:36 eurotimedate.LBX
    FLASHC~1 LBX         3.680  21.06.03  14:08 FlashCardDrive.LBX
    FLASHC~1 LIB         8.227  21.06.03  14:08 FlashCardDrive.lib
    FLASHC~2 LBX         4.937  21.06.03  14:08 FlashCardDrive_EL_PIN.LBX
    FLASHC~2 LIB         9.925  21.06.03  14:08 FlashCardDrive_EL_PIN.lib
    FLASHC~3 LBX         4.082  26.11.04  17:33 FlashCardDrive_MMC.LBX
    FP_TRIG  LBX        15.752  14.11.04  11:42 FP_Trig.LBX
    GLCD     LBX         7.673  02.12.02  20:48 glcd.LBX
    GLCDKS~1 LBX         5.541  03.10.03  15:15 glcdKS108.LBX
    GLCDSED  LBX         5.288  17.05.03  17:21 glcdSED.LBX
    GLCDSE~1 LBX         5.271  29.10.03  22:39 glcdSED1520.LBX
    I2C      LBX         3.509  24.12.04  23:44 i2c.LBX
    I2C_TWI  LBX         2.421  04.07.04  11:18 i2c_TWI.LBX
    LCD_BU~1 LBX         1.604  11.05.04  23:46 lcd_butterfly.LBX
    LCD4     LBX         1.235  11.03.02  21:47 lcd4.LBX
    LCD4BUSY LBX         2.236  06.05.02   0:54 lcd4busy.LBX
    LCD4E2   LBX         1.604  11.03.02  21:48 lcd4e2.LBX
    MCS      LBX        54.355  13.12.04  23:28 mcs.lbx
    MCSBYTE  LBX         1.673  06.05.02   0:50 mcsbyte.LBX
    MCSBYT~1 LBX         2.680  06.05.02   0:50 mcsbyteint.LBX
    MODBUS   LBX           339  11.03.02  21:48 modbus.LBX
    MYLIB    LBX           241  11.03.02  21:48 mylib.LBX
    MYLIB    LIB         3.150  10.03.02   1:46 mylib.lib
    NE2000   LBX        11.694  02.02.03  22:43 ne2000.LBX
    SPISLAVE LBX         1.390  27.04.02  23:53 spislave.LBX
    TCPIP    LBX        18.576  05.07.04  21:42 tcpip.LBX
    X10      LBX         3.908  08.06.03  20:59 x10.LBX
    XRAMDR~1 LBX         6.790  02.05.03   7:07 XRAMDrive.LBX
    XRAMDR~1 LIB         7.958  02.05.03   7:07 XRAMDrive.lib
    INFO     TXT             0  06.01.05   9:54 info.txt
            40 Datei(en)               342.262 Bytes
             2 Verzeichnis(se)       15.978,17 MB frei
    hi jungs,
    ich habe versucht, mit der Bascom Version 1.11.7.7 das Programm "rncontroltest.bas" zu bearbeiten, Dabei gibt es Probleme.
    Gruß stupsi
    -thomas.n-
    Ich habe auch mal versucht mit der neuen Version das rncontroltest.bas zu übersetzen. Bei mir meckert er über die lokale Stringvariable "Zustand", was wohl an der fehlenden Längenangabe liegt. Wenn ich die Länge angebe und neu übersetze hat er am Quelltext erst mal nichts zu meckern aber es kommt die Fehlermeldung "File not found" ohne eine Angabe welches File er denn sucht. Danach kann ich auch nicht neu übersetzen da die Schaltflächen nicht aktivierbar sind. Muß die Datei erst schließen und wieder öffnen???
    PB
    Bei mir meckert Bascom auch ständig das er eine nicht näher beschriebene Datei nicht gefunden hätte. Etwas verwirrend das ganze.
    Grüsse,
    Jonas
