Eclipse & OpenOCD: AHBAP; Sticky und Mem Read Error
Hallo erstmal,
Ich benutze Eclipse, OpenOCD 0.2.0, arm-none-eabi 4.2.3. und das Board
STM32-P103
Mein Problem ist folgendes, sobald ich versuche mit GDB zu debuggen,
bekomme ich eine Reihe von Fehlermeldungen und zwar folgende:
Open On-Chip Debugger 0.2.0 (2009-10-13-15:06) Release
$URL:
http://svn.berlios.de/svnroot/repos/openocd/tags/o...
For bug reports, read
http://svn.berlios.de/svnroot/repos/openocd/trunk/BUGS
jtag_speed: 3
jtag_nsrst_delay: 100
jtag_ntrst_delay: 100
Info : device: 4
Info : deviceID: 364511236
Info : SerialNumber: FTS92Y5TA
Info : Description: Olimex OpenOCD JTAG TINY A
Info : JTAG tap: stm32.cpu tap/device found: 0x3ba00477 (mfg: 0x23b,
part: 0xba00, ver: 0x3)
Info : JTAG Tap/device matched
Info : JTAG tap: stm32.bs tap/device found: 0x16410041 (mfg: 0x020,
part: 0x6410, ver: 0x1)
target state: halted
target halted due to debug-request, current mode: Thread
xPSR: 0x01000000 pc: 0x20000010
Info : accepting 'gdb' connection from 0
Warn : acknowledgment received, but no packet pending
Info : device id = 0x20036410
Info : flash size = 128kbytes
Error: AHBAP Cached values: dp_select 0x0, ap_csw 0xa2000010, ap_tar
0xffffffff
Error: SWJ-DP STICKY ERROR
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f64f
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f650
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x202d0dd3
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x202d0dd4
0xffffffff
0xffffffff
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f653
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f654
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f657
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f658
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f65b
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f65c
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f65f
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f660
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f663
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f664
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f667
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f668
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f66b
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f66c
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f66f
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f670
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f673
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f674
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f677
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f678
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f67b
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f67c
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f67f
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f680
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f683
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f684
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f687
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f688
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f68b
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f68c
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f68f
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f690
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f693
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f694
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f697
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f698
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f69b
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f69c
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f69f
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f6a0
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f6a3
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f6a4
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f6a7
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f6a8
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f6ab
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f6ac
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f6af
0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f6b0
Hier ein Einblick in meine cfg:
# Olimex STM32-H103 eval board
# http://olimex.com/dev/stm32-h103.html
gdb_port 3333
# Work-area size (RAM size) = 20kB for STM32F103RB device
set _WORKAREASIZE 0x5000
interface ft2232
ft2232_device_desc "Olimex OpenOCD JTAG TINY A"
ft2232_layout "olimex-jtag"
ft2232_vid_pid 0x15BA 0x0003
# script for stm32
if { [info exists CHIPNAME] } {
set _CHIPNAME $CHIPNAME
} else {
set _CHIPNAME stm32
if { [info exists ENDIAN] } {
set _ENDIAN $ENDIAN
} else {
set _ENDIAN little
# JTAG speed should be <= F_CPU/6. F_CPU after reset is 8MHz, so use
F_JTAG = 1MHz
#jtag_khz 1000
jtag_speed 3
#jtag_device 4 0x1 0xf 0xe
jtag_nsrst_delay 100
jtag_ntrst_delay 100
#use combined on interfaces or targets that can't set TRST/SRST
separately
reset_config trst_and_srst
#jtag scan chain
if { [info exists CPUTAPID ] } {
set _CPUTAPID $CPUTAPID
} else {
# See STM Document RM0008
# Section 26.6.3
set _CPUTAPID 0x3ba00477
jtag newtap $_CHIPNAME cpu -irlen 4 -ircapture 0x1 -irmask 0xf
-expected-id $_CPUTAPID
if { [info exists BSTAPID ] } {
set _BSTAPID $BSTAPID
} else {
# Section 26.6.2
# Low density devices, Rev A
set _BSTAPID1 0x06412041
# Medium density devices, Rev A
set _BSTAPID2 0x06410041
# Medium density devices, Rev B and Rev Z
set _BSTAPID3 0x16410041
# High density devices, Rev A
set _BSTAPID4 0x06414041
# Connectivity line devices, Rev A and Rev Z
set _BSTAPID5 0x06418041
jtag newtap $_CHIPNAME bs -irlen 5 -ircapture 0x1 -irmask 0x1
-expected-id $_BSTAPID1 -expected-id $_BSTAPID2 -expected-id $_BSTAPID3
-expected-id $_BSTAPID4 -expected-id $_BSTAPID5
set _TARGETNAME [format "%s.cpu" $_CHIPNAME]
target create $_TARGETNAME cortex_m3 -endian $_ENDIAN -chain-position
$_TARGETNAME
$_TARGETNAME configure -work-area-virt 0 -work-area-phys 0x20000000
-work-area-size $_WORKAREASIZE -work-area-backup 0
flash bank stm32x 0 0 0 0 0
#flash bank <driver> <base> <size> <chip_width> <bus_width>
flash bank stm32x 0x08000000 0x00010000 0 0 0
init
reset halt
# For more information about the configuration files, take a look at:
# openocd.texi
für GDB:
target remote localhost:3333
break main
Würde mich freuen wenn ihr mir weiterhelfen könntet.
Danke schonmal im Vorraus
- Neue Themen erstellen: Nein
- Themen beantworten: Nein
- Anhänge hochladen: Nein
- Beiträge bearbeiten: Nein
Foren-Regeln
