Schaltplan:
Quellcode:
 * Copyright (C) 2010 by Tom Vincent Peters
 * code@vincent-peters.de
 * This program is free software; you can redistribute it and/or modify
 * it under the terms of the GNU General Public License as published by
 * the Free Software Foundation; either version 2 of the License, or
 * (at your option) any later version.
 * This program is distributed in the hope that it will be useful,
 * but WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 * GNU General Public License for more details.
 * You should have received a copy of the GNU General Public License
 * along with this program; if not, write to the
 * Free Software Foundation, Inc.,
 * 59 Temple Place - Suite 330, Boston, MA  02111-1307, USA.
#include "config.h"
#include <avr/io.h>
#include <util/delay.h>
#include <avr/pgmspace.h>
#include "usart.h"
#define VCCBRD_RSCK_DDR		DDRC
#define VCCBRD_RSCK_PORT	PORTC
#define VCCBRD_RSCK_BIT		0x01 /* 00 00  00 01 */
#define VCCBRD_D1_DDR	DDRB
#define VCCBRD_D1_PORT	PORTB
#define VCCBRD_D1_BIT	0x01 /* 00 00  00 01 */
#define VCCBRD_D2_DDR	DDRB
#define VCCBRD_D2_PORT	PORTB
#define VCCBRD_D2_BIT	0x02 /* 00 00  00 10 */
#define VCCBRD_D3_DDR	DDRB
#define VCCBRD_D3_PORT	PORTB
#define VCCBRD_D3_BIT	0x04 /* 00 00  01 00 */
#define VCCBRD_D4_DDR	DDRB
#define VCCBRD_D4_PORT	PORTB
#define VCCBRD_D4_BIT	0x08 /* 00 00  10 00 */
static uint8_t verbose;
char str_action[] PROGMEM = "action (help=h): ";
char str_help[] PROGMEM = "h: help\r\n"
			  "p: tootle pulsing (only test leds with pulsing turned on!)\r\n"
			  "s: set data which will be sent to the board\r\n"
			  "i: print data, pulse state and other stuff\r\n"
			  "r: resend data (in pulsing mode data is resend automatically)\r\n"
			  "v: verbose messages (clutters display with pulsing on!)\r\n"
			  "k: send one low bit on D1 (triggers RSCK)\r\n"
			  "K: send one high bit on D1 (triggers RSCK)\r\n"
			  "a,b,c,d,e: set D1,D2,D3,D4,RSCK to high\r\n"
			  "A,B,C,D,E: set D1,D2,D3,D4,RSCK to low\r\n"
			  "use arrow keys to manipulate data:\r\n"
			  "LEFT: <<=1 on all bytes of data\r\n"
			  "RIGHT: >>=1 on all bytes of data\r\n"
			  "UP: +=1 on all bytes of data\r\n"
			  "DOWN: -=1 on all bytes of data\r\n"
			  "pulsing is turned on by default\r\n"
			  "data is initialized to zero\r\n";
char str_data[] PROGMEM = "data: ";
char str_input[] PROGMEM = "pls write 32 bit hex val: ";
char str_flush[] PROGMEM = "data written to vccbrd...";
char str_unkown[] PROGMEM = "dunno what to do!";
char str_pulse[] PROGMEM = "pulse: ";
char str_verbose[] PROGMEM = "verbose: ";
char str_pins[] PROGMEM = "vccbrd_d[1-4]: ";
char str_left[] PROGMEM = "<<=1 on every byte of data results in: 0x";
char str_right[] PROGMEM = ">>=1 on every byte of data results in: 0x";
char str_up[] PROGMEM = "+=1 on every byte of data results in: 0x";
char str_down[] PROGMEM = "-=1 on every byte of data results in: 0x";
char str_hex[] PROGMEM = "0x";
char str_sep[] PROGMEM = ", ";
char str_nl[] PROGMEM = "\r\n";
void send_data(uint8_t data[4]) {
	uint8_t i;
	uint8_t cmp;
	uint8_t out;
	cmp=0x80;
	while (cmp) {
		if (data[0]&cmp) {
			VCCBRD_D1_PORT |= VCCBRD_D1_BIT;
			out|=VCCBRD_D1_BIT;
		} else {
			VCCBRD_D1_PORT &= ~(VCCBRD_D1_BIT);
			out&=~(VCCBRD_D1_BIT);
		if (data[1]&cmp) {
			VCCBRD_D2_PORT |= VCCBRD_D2_BIT;
			out|=VCCBRD_D2_BIT;
		} else {
			VCCBRD_D2_PORT &= ~(VCCBRD_D2_BIT);
			out&=~(VCCBRD_D2_BIT);
		if (data[2]&cmp) {
			VCCBRD_D3_PORT |= VCCBRD_D3_BIT;
			out|=VCCBRD_D3_BIT;
		} else {
			VCCBRD_D3_PORT &= ~(VCCBRD_D3_BIT);
			out&=~(VCCBRD_D3_BIT);
		if (data[3]&cmp) {
			VCCBRD_D4_PORT |= VCCBRD_D4_BIT;
			out|=VCCBRD_D4_BIT;
		} else {
			VCCBRD_D4_PORT &= ~(VCCBRD_D4_BIT);
			out&=~(VCCBRD_D4_BIT);
		if (verbose) {
			usart_write_hex(out);
			usart_progprint(str_sep);
		VCCBRD_RSCK_PORT |= VCCBRD_RSCK_BIT;
		_delay_us(5);
		VCCBRD_RSCK_PORT &= ~(VCCBRD_RSCK_BIT);
		cmp>>=1;
	if (verbose) {
		usart_progprint(str_nl);
	_delay_us(5);
int main() {
	uint8_t in;
	uint8_t data[4];
	uint8_t off_data[4];
	uint8_t i;
	uint8_t pulse;
	uint8_t print_action;
	VCCBRD_RSCK_DDR |= VCCBRD_RSCK_BIT;
	VCCBRD_D1_DDR |= VCCBRD_D1_BIT;
	VCCBRD_D2_DDR |= VCCBRD_D2_BIT;
	VCCBRD_D3_DDR |= VCCBRD_D3_BIT;
	VCCBRD_D4_DDR |= VCCBRD_D4_BIT;
	for (i=0;i<4;i++) {
		data[i]=0x00;
		off_data[i]=0x00;
	print_action=1;
	pulse=1;
	usart_init(9600);
	while (1) {
		if (print_action) {
			usart_progprint(str_action);
			print_action=0;
		in=usart_read_noblock();
		if (in!=0) {
			usart_write(in);
		if (in=='h') {
			usart_progprint(str_help);
		} else if (in=='k') {
			VCCBRD_D1_PORT&=~(VCCBRD_D1_BIT);
			_delay_us(5);
		} else if (in=='K') {
			VCCBRD_D1_PORT|=VCCBRD_D1_BIT;
			_delay_us(5);
		} else if (in=='v') {
			verbose=verbose?0:1;
			usart_progprint(str_verbose);
			usart_write_hex(verbose);
		} else if (in=='a') {
		} else if (in=='b') {
		} else if (in=='c') {
		} else if (in=='d') {
		} else if (in=='e') {
		} else if (in=='A') {
		} else if (in=='B') {
		} else if (in=='C') {
		} else if (in=='D') {
		} else if (in=='E') {
		} else if (in=='i') {
			usart_progprint(str_data);
			usart_progprint(str_hex);
			for (i=0;i<4;i++) {
				usart_write_hex(data[i]);
			usart_progprint(str_pulse);
			usart_write_hex(pulse);
		} else if (in=='s') {
			usart_progprint(str_input);
			for (i=0;i<4;i++) {
				data[i]=usart_read_hex();
			send_data(data);
			for (i=0;i<4;i++) {
			usart_progprint(str_flush);
		} else if (in=='r') {
			for (i=0;i<4;i++) {
			send_data(data);
		} else if (in==0x1B) { /* arrow keys: 0x1b 0x5b [0x41-0x44] */
			_delay_ms(5);
			if (usart_read_noblock()==0x5B) {
				_delay_ms(5);
				if (in==0x44) {
					usart_progprint(str_left);
					for (i=0;i<4;i++) {
						data[i]<<=1;
				if (in==0x43) {
					usart_progprint(str_right);
					for (i=0;i<4;i++) {
						data[i]>>=1;
				}if (in==0x41) {
					usart_progprint(str_up);
					for (i=0;i<4;i++) {
						data[i]+=1;
				if (in==0x42) {
					usart_progprint(str_down);
					for (i=0;i<4;i++) {
						data[i]-=1;
		} else if (in=='p') {
			pulse=pulse?0:1;
		} else if (in!=0) {
			usart_progprint(str_unkown);
		if (in!=0) {
			print_action=1;
		if (pulse) {
			send_data(off_data);
			_delay_us(27);
			send_data(data);
			_delay_us(3);
Quellcode in Aktion:
action (help=h): h
h: help
r: resend data (in pulsing mode data is resent automatically)
action (help=h): i
data: 0x00000000
pulse: 01
verbose: 00
action (help=h): p
pulse: 00
action (help=h): v
verbose: 01
action (help=h): r
data: 0x00000000
00, 00, 00, 00, 00, 00, 00, 00,
action (help=h): a // das hier funktioniert: 1 high bit auf U1
action (help=h): e
action (help=h): E
action (help=h): e
action (help=h): E
action (help=h): s // auch hier wird erfolgreich 1 high bit zu U1 gesendet
pls write 32 bit hex val: 01000000
00, 00, 00, 00, 00, 00, 00, 01,
data: 0x01000000
action (help=h): s // man kann auch beliebige bitfolgen setzen
pls write 32 bit hex val: 99000000
01, 00, 00, 01, 01, 00, 00, 01,
data: 0x99000000
action (help=h): s // geht ohne probleme
pls write 32 bit hex val: 00ff00ff
0A, 0A, 0A, 0A, 0A, 0A, 0A, 0A,
data: 0x00FF00FF
pls write 32 bit hex val: ffff00ff
0B, 0B, 0B, 0B, 0B, 0B, 0B, 0B,
data: 0xFFFF00FF
pls write 32 bit hex val: 00ffffff
0E, 0E, 0E, 0E, 0E, 0E, 0E, 0E,
data: 0x00FFFFFF
action (help=h): s // geht gar nicht! (alles 0x00)
pls write 32 bit hex val: ffffffff
0F, 0F, 0F, 0F, 0F, 0F, 0F, 0F,
data: 0xFFFFFFFF
action (help=h): s // funktioniert halb: U1:0x88, U2:0xff, U3:0xff, U4:0x00
pls write 32 bit hex val: ffffff00
07, 07, 07, 07, 07, 07, 07, 07,
data: 0xFFFFFF00
action (help=h): s // aufraeumen...
pls write 32 bit hex val: 00000000
data: 0x00000000
action (help=h): a // U1 bis U3 erhalten 3 high bits, von denen 2
action (help=h): b // ausgegeben werden sollten
action (help=h): c // Messungen ergeben leider folgendes:
action (help=h): e // U1: 0x00, U2: 0x03, U3: 0x03, U4: 0x00
action (help=h): E // das Problem: U1 sollte 0x03 sein
action (help=h): e // wenn ich am U1 Ser Pin messe, werden konstant 5v angezeigt
action (help=h): E
action (help=h): e
action (help=h): E
action (help=h): r // ordnung schaffen
data: 0x00000000
action (help=h): a // hier soll an alle chips ein high signal uebertragen werden
action (help=h): b // alle Ser Pins sind durchgehend auf 5v und die anderen Pins
action (help=h): c // ebenfalls sind richtig beschaltet (wurde nachgemessen)
action (help=h): d // jedoch sind U1 bis U4 alle 0x00
action (help=h): e // sobald alle 4 pins gleichzeitig aktiviert werden,
action (help=h): E // wird eine 0 ins register gelesen
action (help=h): e // dies ist scheinbar unabhaengig von den chips,
action (help=h): E // da ich mehrere getestet habe
action (help=h): e // der AVR steckt auf einem Arduino board
action (help=h): E
