zuerst mal den Wert in 2 x 2 Byte aufteilen
dann diese 2 Words wieder in je 2 Bytes aufteilen:Code:unsigned short HiWord = (unsigned short)(Data >> 16); unsigned short LoWord = (unsigned short)(Data);
[edit]Code:array[0] = (unsigned char)(LoWord); array[1] = (unsigned char)(LoWord >> 8); array[2] = (unsigned char)(HiWord); array[3] = (unsigned char)(HiWord >> 8);
Hab's gerade mal probiert, geht auch in einem Schritt:
[/edit]Code:array[0] = (unsigned char)(Data); array[1] = (unsigned char)(Data >> 8); array[2] = (unsigned char)(Data >> 16); array[3] = (unsigned char)(Data >> 24);
Gruß,
askazo
Zitieren
