das war mein erster Versuch:
da das icht funktoinierte hat habe ich einfach erstmal probiert den Servo auszulesenCode:#include "asuro.h" int main(void) { unsigned char taste; int i; Init(); StatusLED(GREEN); MotorDir(FWD,FWD); while(1){ taste=PollSwitch; taste=PollSwitch; taste=PollSwitch; taste=PollSwitch; taste=PollSwitch; taste=PollSwitch; taste=PollSwitch; taste=PollSwitch; taste=PollSwitch; taste=PollSwitch; taste=PollSwitch; taste=PollSwitch; taste=PollSwitch; if(taste==12){ BackLED(OFF,ON); MotorDir(BREAK,BREAK); MotorSpeed(0,0); for(i=1;i>200;i++){ Sleep(2);} BackLED(OFF,OFF); MotorDir(FWD,RWD); MotorSpeed(100,100); for(i=1;i>2000;i++);{ Sleep(2);} BackLED(OFF,OFF); MotorDir(FWD,FWD); MotorSpeed(180,180); for(i=1;i>200;i++);{ Sleep(2);} BackLED(OFF,ON); MotorDir(RWD,RWD); MotorSpeed(180,180); for(i=1;i>2000;i++);{ Sleep(2);} BackLED(OFF,OFF); MotorDir(RWD,FWD); MotorSpeed(100,100); for(i=1;i>200;i++);{ Sleep(2);} BackLED(OFF,OFF); MotorDir(FWD,FWD); MotorSpeed(200,200); for(i=1;i>300;i++);{ Sleep(2);} } else if(taste==33){ MotorDir(RWD,RWD); MotorSpeed(100,100); for(i=0;i<9999;i++){ Sleep(10);} MotorDir(BREAK,RWD); MotorSpeed(0,125); for(i=0;i<9999;i++){ Sleep(10);} MotorDir(FWD,FWD); MotorSpeed(150,150); for(i=0;i<9999;i++){ Sleep(10);} } else{ MotorDir(FWD,FWD); MotorSpeed(200,200); } } return 0; }
Code:#include "asuro.h" int main(void) { int i; Init(); BackLED(ON,ON); for(i=1;1>1;i++){Sleep(1);} BackLED(OFF,OFF); while(1); return 0; }
Zitieren
