Thema: Bascom zeigt Errors nicht an
    Dortmund
    Hi Leute..
    Erstmal poste ich jetzt hier meinen Code :
    $regfile = "m16def.dat"
    $crystal = 4000000
    $hwstack = 32
    Config Porta = Output
    Config Portc = Output
    Config Portd.4 = Output
    Config Portd.5 = Output
    Config Portd.6 = Output
    Config Portd.7 = Output
    Config Portb.0 = Output
    Config Portb.1 = Output
    Config Portb.4 = Output
    Config Portd.2 = Input
    Config Portd.3 = Input
    Config Portb.2 = Input
    Ledr1 Alias Porta.0
    Ledr2 Alias Porta.1
    Ledr3 Alias Porta.2
    Ledr4 Alias Porta.3
    Ledr5 Alias Porta.4
    Ledr6 Alias Porta.5
    Ledr7 Alias Porta.6
    Ledl1 Alias Portc.0
    Ledl2 Alias Portc.1
    Ledl3 Alias Portc.2
    Ledl4 Alias Portc.3
    Ledl5 Alias Portc.4
    Ledl6 Alias Portc.5
    Ledl7 Alias Portc.6
    Ledrstrip Alias Porta.7
    Ledlstrip Alias Portc.7
    Striprot Alias Portb.0
    Stripgruen Alias Portb.1
    Striporange Alias Portb.4
    Stripweiss1 Alias Portd.4
    Stripweiss2 Alias Portd.5
    Stripblau1 Alias Portd.6
    Stripblau2 Alias Portd.7
    Dim Lesen1 As Bit
    Dim Lesen2 As Bit
    Dim Lesen3 As Bit
    Dim Empf_wert1 As Byte
    Dim Empf_wert2 As Byte
    Dim Empf_wert3 As Byte
    Dim Test As Bit
    Dim Test2 As Bit
    Lesen1 = 0
    Lesen2 = 0
    Lesen3 = 0
    Config Timer0 = Timer , Prescale = 64
    Enable Timer0
    Stop Timer0
    On Timer0 Error
    Config Timer1 = Timer , Prescale = 64
    Enable Timer1
    Stop Timer1
    On Timer1 Error
    Config Timer2 = Timer , Prescale = 64
    Enable Timer2
    Stop Timer2
    On Timer2 Error
    Config Int0 = Change
    On Int0 Messen1
    Config Int1 = Change
    On Int1 Messen2
    On Int2 Messen3
    Enable Interrupts
    Enable Int0
    Enable Int1
    Enable Int2
       Gosub Hauptprogramm
    End
    Hauptprogramm:
       If Empf_wert3 > 104 Then
          Gosub Flash_all2
       End If
       If Empf_wert3 > 83 Then
          Gosub Flash_all1
       End If
       If Empf_wert2 > 94 Then
          Striprot = 1
          Stripgruen = 1
          Striporange = 1
          Stripweiss1 = 1
          Stripweiss2 = 1
          Stripblau1 = 1
          Stripblau2 = 1
       Else
          Striprot = 0
          Stripgruen = 0
          Striporange = 0
          Stripweiss1 = 0
          Stripweiss2 = 0
          Stripblau1 = 0
          Stripblau2 = 0
       End If
       If Empf_wert1 > 104 Then
          Gosub Blinken
       End If
       If Empf_wert1 > 94 Then
          Gosub Lauflicht2
       End If
       If Empf_wert1 > 83 Then
          Gosub Lauflicht1
       End If
       If Empf_wert1 > 73 Then
          Gosub Led_an
       Else
          Gosub Led_aus
       End If
    Return
    Messen1:
       If Lesen1 = 0 Then
          Start Timer0
          Lesen1 = 1
       Else
          Stop Timer0
          Empf_wert1 = Timer0
          Timer0 = 0
          Lesen1 = 0
       End If
       If Empf_wert1 >= Test And Empf_wert1 <= Test2 Then
          Test = Empf_wert1 - 5
          Test2 = Empf_wert1 + 5
          Return
       End If
       If Empf_wert1 <= Test Or >= Test2 Then
          Gosub Hauptprogramm
       End If
    Return
    Messen2:
       If Lesen2 = 0 Then
          Start Timer1
          Lesen2 = 1
       Else
          Stop Timer1
          Empf_wert2 = Timer1
          Lesen2 = 0
       End If
    Return
    Messen3:
       If Lesen3 = 0 Then
          Start Timer2
          Lesen3 = 1
       Else
          Stop Timer2
          Empf_wert3 = Timer2
          Lesen3 = 0
       End If
    Return
    Error:
    Stop Timer0
       Ledr1 = 1
       Ledr2 = 1
       Ledr3 = 1
       Ledr4 = 1
       Ledr5 = 1
       Ledr6 = 1
       Ledr7 = 1
       Ledl1 = 1
       Ledl2 = 1
       Ledl3 = 1
       Ledl4 = 1
       Ledl5 = 1
       Ledl6 = 1
       Ledl7 = 1
       Ledrstrip = 1
       Ledlstrip = 1
       Striprot = 1
       Stripgruen = 1
       Striporange = 1
       Stripweiss1 = 1
       Stripweiss2 = 1
       Stripblau1 = 1
       Stripblau2 = 1
    Return
    Led_an:
       Ledr1 = 1
       Ledr2 = 1
       Ledr3 = 1
       Ledr4 = 1
       Ledr5 = 1
       Ledr6 = 1
       Ledr7 = 1
       Ledl1 = 1
       Ledl2 = 1
       Ledl3 = 1
       Ledl4 = 1
       Ledl5 = 1
       Ledl6 = 1
       Ledl7 = 1
       Ledrstrip = 1
       Ledlstrip = 1
    Gosub Hauptprogramm
    Return
    Led_aus:
       Ledr1 = 0
       Ledr2 = 0
       Ledr3 = 0
       Ledr4 = 0
       Ledr5 = 0
       Ledr6 = 0
       Ledr7 = 0
       Ledl1 = 0
       Ledl2 = 0
       Ledl3 = 0
       Ledl4 = 0
       Ledl5 = 0
       Ledl6 = 0
       Ledl7 = 0
       Ledrstrip = 0
       Ledlstrip = 0
    Gosub Hauptprogramm
    Return
    Lauflicht1:
       Ledr1 = 1
       Ledr2 = 1
       Ledr3 = 1
       Ledr4 = 1
       Ledr5 = 1
       Ledr6 = 1
       Ledr7 = 0
       Ledl1 = 1
       Ledl2 = 1
       Ledl3 = 1
       Ledl4 = 1
       Ledl5 = 1
       Ledl6 = 1
       Ledl7 = 1
       Ledrstrip = 1
       Ledlstrip = 1
       Waitms 65
       Ledr7 = 1
       Ledr6 = 0
       Waitms 65
       Ledr6 = 1
       Ledr5 = 0
       Waitms 65
       Ledr5 = 1
       Ledr4 = 0
       Waitms 65
       Ledr4 = 1
       Ledr3 = 0
       Waitms 65
       Ledr3 = 1
       Ledr2 = 0
       Waitms 65
       Ledr2 = 1
       Ledr1 = 0
       Waitms 65
       Ledr1 = 1
       Waitms 65
       Ledl1 = 0
       Waitms 65
       Ledl1 = 1
       Ledl2 = 0
       Waitms 65
       Ledl2 = 1
       Ledl3 = 0
       Waitms 65
       Ledl3 = 1
       Ledl4 = 0
       Waitms 65
       Ledl4 = 1
       Ledl5 = 0
       Waitms 65
       Ledl5 = 1
       Ledl6 = 0
       Waitms 65
       Ledl6 = 1
       Ledl7 = 0
       Waitms 65
       Ledl7 = 1
       Waitms 65
       Ledl7 = 0
       Waitms 65
       Ledl7 = 1
       Ledl6 = 0
       Waitms 65
       Ledl6 = 1
       Ledl5 = 0
       Waitms 65
       Ledl5 = 1
       Ledl4 = 0
       Waitms 65
       Ledl4 = 1
       Ledl3 = 0
       Waitms 65
       Ledl3 = 1
       Ledl2 = 0
       Waitms 65
       Ledl2 = 1
       Ledl1 = 0
       Waitms 65
       Ledl1 = 1
       Waitms 65
       Ledr1 = 0
       Waitms 65
       Ledr1 = 1
       Ledr2 = 0
       Waitms 65
       Ledr2 = 1
       Ledr3 = 0
       Waitms 65
       Ledr3 = 1
       Ledr4 = 0
       Waitms 65
       Ledr4 = 1
       Ledr5 = 0
       Waitms 65
       Ledr5 = 1
       Ledr6 = 0
       Waitms 65
       Ledr6 = 1
       Ledr7 = 0
       Waitms 65
       Ledr7 = 1
    Gosub Hauptprogramm
    Return
    Lauflicht2:
       Ledr1 = 1
       Ledr2 = 1
       Ledr3 = 1
       Ledr4 = 1
       Ledr5 = 1
       Ledr6 = 1
       Ledr7 = 0
       Ledl1 = 1
       Ledl2 = 1
       Ledl3 = 1
       Ledl4 = 1
       Ledl5 = 1
       Ledl6 = 1
       Ledl7 = 0
       Ledrstrip = 1
       Ledlstrip = 1
       Waitms 65
       Ledr7 = 1
       Ledl7 = 1
       Ledr6 = 0
       Ledl6 = 0
       Waitms 65
       Ledr6 = 1
       Ledl6 = 1
       Ledr5 = 0
       Ledl5 = 0
       Waitms 65
       Ledr5 = 1
       Ledl5 = 1
       Ledr4 = 0
       Ledl4 = 0
       Waitms 65
       Ledr4 = 1
       Ledl4 = 1
       Ledr3 = 0
       Ledl3 = 0
       Waitms 65
       Ledr3 = 1
       Ledl3 = 1
       Ledr2 = 0
       Ledl2 = 0
       Waitms 65
       Ledr2 = 1
       Ledl2 = 1
       Ledr1 = 0
       Ledl1 = 0
       Waitms 65
       Ledr1 = 1
       Ledl1 = 1
       Waitms 65
       Ledr1 = 0
       Ledl1 = 0
       Waitms 65
       Ledr1 = 1
       Ledl1 = 1
       Ledr2 = 0
       Ledl2 = 0
       Waitms 65
       Ledr2 = 1
       Ledl2 = 1
       Ledr3 = 0
       Ledl3 = 0
       Waitms 65
       Ledr3 = 1
       Ledl3 = 1
       Ledr4 = 0
       Ledl4 = 0
       Waitms 65
       Ledr4 = 1
       Ledl4 = 1
       Ledr5 = 0
       Ledl5 = 0
       Waitms 65
       Ledr5 = 1
       Ledl5 = 1
       Ledr6 = 0
       Ledl6 = 0
       Waitms 65
       Ledr6 = 1
       Ledl6 = 1
       Ledr7 = 0
       Ledl7 = 0
       Waitms 65
       Ledr7 = 1
       Ledl7 = 1
    Gosub Hauptprogramm
    Return
    Blinken:
       Ledr1 = 1
       Ledr2 = 0
       Ledr3 = 1
       Ledr4 = 0
       Ledr5 = 1
       Ledr6 = 0
       Ledr7 = 1
       Ledl1 = 0
       Ledl2 = 1
       Ledl3 = 0
       Ledl4 = 1
       Ledl5 = 0
       Ledl6 = 1
       Ledl7 = 0
       Ledrstrip = 1
       Ledlstrip = 1
       Waitms 100
       Ledr1 = 0
       Ledr2 = 1
       Ledr3 = 0
       Ledr4 = 1
       Ledr5 = 0
       Ledr6 = 1
       Ledr7 = 0
       Ledl1 = 1
       Ledl2 = 0
       Ledl3 = 1
       Ledl4 = 0
       Ledl5 = 1
       Ledl6 = 0
       Ledl7 = 1
       Waitms 100
    Gosub Hauptprogramm
    Return
    Flash_all1:
       Ledr1 = 1
       Ledr2 = 1
       Ledr3 = 1
       Ledr4 = 1
       Ledr5 = 1
       Ledr6 = 1
       Ledr7 = 1
       Ledl1 = 1
       Ledl2 = 1
       Ledl3 = 1
       Ledl4 = 1
       Ledl5 = 1
       Ledl6 = 1
       Ledl7 = 1
       Ledrstrip = 1
       Ledlstrip = 1
       Striprot = 1
       Stripgruen = 1
       Striporange = 1
       Stripweiss1 = 1
       Stripweiss2 = 1
       Stripblau1 = 1
       Stripblau2 = 1
       Waitms 125
       Ledr1 = 0
       Ledr2 = 0
       Ledr3 = 0
       Ledr4 = 0
       Ledr5 = 0
       Ledr6 = 0
       Ledr7 = 0
       Ledl1 = 0
       Ledl2 = 0
       Ledl3 = 0
       Ledl4 = 0
       Ledl5 = 0
       Ledl6 = 0
       Ledl7 = 0
       Ledrstrip = 0
       Ledlstrip = 0
       Striprot = 0
       Stripgruen = 0
       Striporange = 0
       Stripweiss1 = 0
       Stripweiss2 = 0
       Stripblau1 = 0
       Stripblau2 = 0
       Waitms 125
    Gosub Hauptprogramm
    Return
    Flash_all2:
       Ledr1 = 1
       Ledr2 = 0
       Ledr3 = 1
       Ledr4 = 0
       Ledr5 = 1
       Ledr6 = 0
       Ledr7 = 1
       Ledl1 = 0
       Ledl2 = 1
       Ledl3 = 0
       Ledl4 = 1
       Ledl5 = 0
       Ledl6 = 1
       Ledl7 = 0
       Ledrstrip = 0
       Ledlstrip = 1
       Striprot = 1
       Stripgruen = 0
       Striporange = 1
       Stripweiss1 = 0
       Stripweiss2 = 1
       Stripblau1 = 0
       Stripblau2 = 1
       Waitms 100
       Ledr1 = 0
       Ledr2 = 1
       Ledr3 = 0
       Ledr4 = 1
       Ledr5 = 0
       Ledr6 = 1
       Ledr7 = 0
       Ledl1 = 1
       Ledl2 = 0
       Ledl3 = 1
       Ledl4 = 0
       Ledl5 = 1
       Ledl6 = 0
       Ledl7 = 1
       Ledrstrip = 1
       Ledlstrip = 0
       Striprot = 0
       Stripgruen = 1
       Striporange = 0
       Stripweiss1 = 1
       Stripweiss2 = 0
       Stripblau1 = 1
       Stripblau2 = 0
    Gosub Hauptprogramm
    Return
    Wenn ich den versuche zu compilieren steht unten in der Leiste :
    "Errors : 5 found"
    Es steht nicht da um welche Errors es sich handelt und sobald ich die Maus bewege verschwindet die Textzeile auch.. Aber die Hex wurde nicht compiliert..
    Also, die Errors müssen sich im folgenden Abschnitt befinden :
    Messen1:
       If Lesen1 = 0 Then
          Start Timer0
          Lesen1 = 1
       Else
          Stop Timer0
          Empf_wert1 = Timer0
          Timer0 = 0
          Lesen1 = 0
       End If
          Return
       End If
          Gosub Hauptprogramm
       End If
    Return
    Und in dieser ISR können die Fehler auch nur in dem unteren Teil sein, also :
          Return
       End If
          Gosub Hauptprogramm
       End If
    Return
    Ddenn wenn ich diesen Teil weglasse, gehts ohne Errors...
    Um mal kurz zu erklären, was dieser Teil machen soll :
    Also in der ISR wird das PWM Signal eines RC-Empfängers gemessen um im Wert "Empf_wert1" gespeichert..
    Das Hauptprogramm fragt verschiedene Empf_werte ab und startet je nachdem eine andere Subroutine.. In diesem Subroutinen wird teilweise mit Wait befehlen gearbeitet, also können diese auch mal ein paar sekunden dauern.. wenn sich nun der Empf_wert1 geänder hätte, würde trotzdem noch die "alte" Subroutine zu Ende laufen, was ich aber nciht wollte..
    was ich erreichen wollte war : wenn sich der Empf_wert1 (bis auf geringe Schwankungen) nicht geändert hatte soll mit Return wieder dahin gesprungen werden, wo vorher aufgehört wurde.. Wenn sich der Wert aber ändert, soll wieder das Hauptprogramm ausgewählt werden um die zu dem neuen Wert passende Subroutine zu starten..
    Ich finde in diesem Codeabschnitt keine Fehler und da Bascom sie nciht anzeigt weiß ich auch nicht wie ichs beheben soll...
    Weiß einer woran das liegt, dass Bascom nciht die genauen Fehler anzeigt???
    Und/Oder weiß jemand, was in dem Abschnitt falsch ist???
    Danke im Vorraus Bild
    Mfg Yannik
    Wer Rechtschreibfehler findet, darf sie behalten!
    Zeile 151: If Empf_wert1 >= Test And Empf_wert1 <= Test2 Then
    Aha, so funktioniert das Übersetzen:
    Dim Test As Byte
    Dim Test2 As Byte
    empf_wert1 und test/test2 sind nicht der selbe Datentyp
    Und das ist wohl noch ein Bug:
    ____________________^____________
    Miniaturansichten angehängter Grafiken Miniaturansichten angehängter Grafiken temp_687.jpg
    Dortmund
    Merci Bild   Jetzt geht es \ Bild  /
