mal ein zwischenstand:
Code:$regfile = "m8def.dat" $crystal = 8000000 $hwstack = 70 ' default use 32 for the hardware stack $swstack = 250 ' default use 10 for the SW stack $framesize = 80 $baud = 19200 ' Konfiguration zum Kompilieren Const Max_framelen = 32 Dim Slaveaddress As Byte ' dim slaveaddress as word Slaveaddress = &B00000011 Dim Tx_data(max_framelen) As Byte Dim Tx_string As String * Max_framelen At Tx_data Overlay #if Max_framelen > 255 Dim Tx_pointer As Word #else Dim Tx_pointer As Byte #endif Dim Rx_data(max_framelen) As Byte Dim Rx_string As String * Max_framelen At Rx_data Overlay #if Max_framelen > 255 Dim Rx_pointer As Word #else Dim Rx_pointer As Byte #endif Dim Data_array(max_framelen) As Byte Dim Flag_array(3) As Byte Dim Rx_flag As Byte Dim Timerflag As Byte Dim Frame_receive_flag As Byte Declare Sub Rx_verarbeitung() ' Interrupts initialisieren On Urxc Zeichenempfang Enable Urxc Config Timer0 = Timer , Prescale = 1024 On Timer0 Timer_irq Const Timervorgabe = 178 Disable Timer0 Enable Interrupts ' Mainloop Do 'Hier könnte Ihr Hauptprogramm stehen If Timerflag = 1 Then Timerflag = 0 ' verarbeitung Print Rx_string Call Rx_verarbeitung() Rx_pointer = 0 Rx_flag = 0 End If If Rx_flag = 1 And Rx_data(1) = &B01010100 And Rx_pointer > 3 Then Call Rx_verarbeitung() End If Loop Timer_irq: Timer0 = 0 Timerflag = 1 Disable Timer0 Incr Rx_pointer Rx_data(rx_pointer) = 0 Return Zeichenempfang: Timer0 = Timervorgabe Enable Timer0 Rx_flag = 1 If Rx_pointer < 19 Then Incr Rx_pointer Rx_data(rx_pointer) = Udr End If Return Sub Rx_verarbeitung() Local Hdb2_rx As Byte Local Hdb1_rx As Byte Local Dd_num As Byte Local Ss_num As Byte Local Pp_num As Byte Local Aa_num As Byte Local Eee_num As Byte Local Checksum_var As Word Local Checksum_byte_1 As Byte Local Checksum_byte_2 As Byte Local Checksum_check_flag As Byte Local Checksum_long As Long Local Temp_variable_1 As Word Local Temp_variable_2 As Word Local Temp_variable_3 As Word Local Temp_variable_4 As Word Local Nnnn_num As Word Local Rx_bytes_to_load As Word Local Slaveaddress_check_flag As Byte ' für test: Rx_pointer = 8 Rx_data(1) = &B01010100 Rx_data(2) = &B01010001 Rx_data(3) = &B01000001 Rx_data(4) = &B00000011 Rx_data(5) = &B00000001 Rx_data(6) = &B11110000 Rx_data(7) = &B00100010 Rx_data(8) = &B00110101 ' hdb2 Dd_num = Rx_data(2) Shift Dd_num , Right , 6 Ss_num = Rx_data(2) Ss_num = Ss_num And &B00110000 Shift Ss_num , Right , 4 Pp_num = Rx_data(2) Pp_num = Pp_num And &B00001100 Shift Pp_num , Right , 2 Aa_num = Rx_data(2) Aa_num = Aa_num And &B00000011 ' hdb1 Eee_num = Rx_data(3) Eee_num = Eee_num And &B01110000 Shift Eee_num , Right , 4 Nnnn_num = Rx_data(3) Nnnn_num = Nnnn_num And &B00001111 ' add framelength Select Case Nnnn_num Case &B00000000 Rx_bytes_to_load = 0 Case &B00000001 Rx_bytes_to_load = 1 Case &B00000010 Rx_bytes_to_load = 2 Case &B00000011 Rx_bytes_to_load = 3 Case &B00000100 Rx_bytes_to_load = 4 Case &B00000101 Rx_bytes_to_load = 5 Case &B00000110 Rx_bytes_to_load = 6 Case &B00000111 Rx_bytes_to_load = 7 Case &B00001000 Rx_bytes_to_load = 8 Case &B00001001 Rx_bytes_to_load = 16 #if Max_framelen > 16 Case &B00001010 Rx_bytes_to_load = 32 #endif #if Max_framelen > 32 Case &B00001011 Rx_bytes_to_load = 64 #endif #if Max_framelen > 64 Case &B00001100 Rx_bytes_to_load = 128 #endif #if Max_framelen > 128 Case &B00001101 Rx_bytes_to_load = 256 #endif #if Max_framelen > 256 Case &B00001110 Rx_bytes_to_load = 512 #endif Case Else Rx_bytes_to_load = 0 End Select ' add checksumlength Select Case Eee_num Case &B00000010 Rx_bytes_to_load = Rx_bytes_to_load + 1 Case &B00000011 Rx_bytes_to_load = Rx_bytes_to_load + 1 Case &B00000100 Rx_bytes_to_load = Rx_bytes_to_load + 2 Case &B00000101 Rx_bytes_to_load = Rx_bytes_to_load + 4 Case Else ' nix machen nop End Select Rx_bytes_to_load = Rx_bytes_to_load + Ss_num ' source adress bytes Rx_bytes_to_load = Rx_bytes_to_load + Dd_num ' destination adress bytes Rx_bytes_to_load = Rx_bytes_to_load + Pp_num ' protokoll spec. flag bytes Rx_bytes_to_load = Rx_bytes_to_load + 3 ' Sync, HDB2, HDB1 ' Auf Adresse prüfen, geht im Moment nur auf 1 und 2 Byte Adresse Temp_variable_1 = 3 + Dd_num Temp_variable_2 = 3 Temp_variable_3 = 0 While Temp_variable_2 < Temp_variable_1 Incr Temp_variable_2 Shift Temp_variable_3 , Left , 1 Temp_variable_3 = Temp_variable_3 + Rx_data(temp_variable_2) Wend If Temp_variable_3 = Slaveaddress Then Slaveaddress_check_flag = 1 Else Slaveaddress_check_flag = 0 End If ' Checksumme prüfen Checksum_check_flag = 0 If Rx_bytes_to_load = Rx_pointer And Slaveaddress_check_flag = 1 Then ' Frame ist ganz empfangen, Adresse stimmt Checksum_var = 0 Checksum_byte_1 = 0 Checksum_byte_2 = 0 Select Case Eee_num Case &B00000010 ' 8-bit checksum Temp_variable_1 = Rx_bytes_to_load - 2 For Temp_variable_2 = 2 To Temp_variable_1 Checksum_var = Checksum_var + Rx_data(temp_variable_2) Next Checksum_byte_1 = Low(checksum_var) If Rx_data(rx_bytes_to_load) = Checksum_byte_1 Then Checksum_check_flag = 1 Else Checksum_check_flag = 0 End If Case &B00000011 ' 8-bit crc Temp_variable_1 = Rx_bytes_to_load - 2 Checksum_byte_1 = Crc8(rx_data(2) , Temp_variable_1) If Rx_data(rx_bytes_to_load) = Checksum_byte_1 Then Checksum_check_flag = 1 Else Checksum_check_flag = 0 End If Case &B00000100 ' 16-bit crc Temp_variable_1 = Rx_bytes_to_load - 3 Checksum_var = Crc16(rx_data(2) , Temp_variable_1) Checksum_byte_1 = Low(checksum_var) Checksum_byte_2 = High(checksum_var) Temp_variable_1 = Rx_bytes_to_load - 1 If Rx_data(rx_bytes_to_load) = Checksum_byte_1 And Rx_data(temp_variable_1) = Checksum_byte_2 Then Checksum_check_flag = 1 Else Checksum_check_flag = 0 End If Case &B00000101 ' 32-bit crc Temp_variable_1 = Rx_bytes_to_load - 5 Checksum_long = Crc32(rx_data(2) , Temp_variable_1) End Select End If ' Frame war komplett, Adresse und Checksumme stimmt ' Daten in Datenarray kopieren und Flag setzen If Checksum_check_flag = 1 Then ' And Aa_num > 0 Frame_receive_flag = 1 ' Frame ist komplett und kann in der Mainloop verarbeitet werden Temp_variable_1 = 3 Temp_variable_1 = Temp_variable_1 + Dd_num Temp_variable_1 = Temp_variable_1 + Ss_num If Pp_num > 0 Then Incr Temp_variable_1 Flag_array(1) = Rx_data(temp_variable_1) If Pp_num > 1 Then Incr Temp_variable_1 Flag_array(1) = Rx_data(temp_variable_1) If Pp_num > 2 Then Incr Temp_variable_1 Flag_array(1) = Rx_data(temp_variable_1) End If End If End If Temp_variable_2 = Temp_variable_1 + Nnnn_num Temp_variable_3 = 0 While Temp_variable_1 < Temp_variable_2 Incr Temp_variable_1 Incr Temp_variable_3 Data_array(temp_variable_3) = Rx_data(temp_variable_1) Wend End If ' Frame gesetzt, acknowledge erzeugen wenn gebraucht If Frame_receive_flag = 1 And Aa_num > 0 Then Tx_data(1) = &B01010100 ' Preamble Shift Dd_num , Left , 6 Shift Ss_num , Left , 4 Shift Pp_num , Left , 2 If Checksum_check_flag = 1 Then Aa_num = &B00000010 ' Ackn Else Aa_num = &B00000011 ' Nack End If Tx_data(2) = Dd_num Tx_data(2) = Tx_data(2) Or Ss_num Tx_data(2) = Tx_data(2) Or Pp_num Shift Eee_num , Left , 4 Tx_data(3) = Eee_num Tx_data(3) = Tx_data(3) Or Nnnn_num End If End Sub
Zitieren
