So hab grade mal versucht eine schon erstelte .hex datei zu flachen dabei kam dieser Fehler:
Code:Flashing file C:\ProgramData\AsuroFlash\Projects\AsuroLibTest\AsuroLibTest.hex Open: COM4 Building RAM... Bulding RAM OK Start Page 0 End Page 13 will occupy 848Bytes Try connecting ASURO -- Switch on ASURO now!..................OK ! Flashing Firmware Sending Page 0 of 13 CRC 31901c; * Try 2/10;c; * Try 3/10;c; * Try 4/10;c; * Try 5/10;v; * Try 6/10;v; * Try 7/10;v; * Try 8/10;c; * Try 9/10;c; * Try 10/10;c; ERRORS 7 CRC Fault(s), 3 Errors, 0 Invalid handshake(s), 0 Timeouts ASURO RETURNED MEMORY ERRORS! Flash memory damaged!! (>10000 access cycles?) ASURO dead ?!?! (Firmware damaged try again!)
Zitieren
