so funkts bei mir - zum testen
Code:#define OC1A_PIN PB1 // OC1A pin (ATmega8 use PB1) #define OC1A_DDR DDRB // OC1A DDR (ATmega8 use DDRB) int main(void) { uint8_t i = 0; // set OC1A pin as output, required for output toggling OC1A_DDR |= (1<<OC1A_PIN); // enable 8 bit PWM, select inverted PWM TCCR1A = (1<<WGM10) | (1<<COM1A1) | (1<<COM1A0); // timer1 running on 1/8MCU clock with clear timer/counter1 on Compare Match // PWM frequency will be MCU clock / 8 / 510, e.g. with 8Mhz Crystal 1960 Hz. TCCR1B = (1<<CS11) | (1<<CS10); /* * Dimm LED on and off in interval of 2.5 seconds */ for (;;) { /* dimm LED on */ for (i=0; i<255; i++) { OCR1AL = i; _delay_ms(40); // delay 10 ms } /* dimm LED off */ for( i=255; i>0; i--) { OCR1AL = i; _delay_ms(40); // delay 10 ms } } }
Zitieren
