oder als Subroutine:
einmal der headerfile
und die sub:Code:$nocompile 'Adjust Length for length of dataarray Const Kal_length = 70 Const Kal_q = 1 'Adjust R for Degree of Damping Const Kal_r = 3 Dim Kal_noisysen(kal_length) As Integer ' Sensordata Dim Kal_z(kal_length) As Byte 'Dim Index(70) As Integer Dim Kal_x_hat(kal_length) As Integer Dim Kal_x_hat_min(kal_length) As Integer Declare Sub Kalman_filter()
Code:$nocompile '%************************************************************ '% Marko Hoerner, 2009 '% '% Kalman Filter For 1st Order System Sensor Input '% ported to Bascom AVR '% '%************************************************************ Sub Kalman_filter() Local Kal_tempsingle_1 As Single Local Kal_tempsingle_2 As Single Local Kal_n As Byte Local Kal_n2 As Byte Local Kal_pmin1 As Single Local Kal_p As Single Local Kal_k As Single Local Kal_pmin As Single Local Kal_tempbyte As Byte For Kal_n = 1 To Kal_length Kal_z(kal_n) = Kal_noisysen(kal_n) Next Kal_pmin1 = 0 Kal_tempsingle_1 = Kal_pmin1 + Kal_r Kal_k = Kal_pmin1 / Kal_tempsingle_1 Kal_tempsingle_1 = Kal_z(1) - Kal_noisysen(1) Kal_tempsingle_1 = Kal_k * Kal_tempsingle_1 Kal_x_hat(1) = Kal_tempsingle_1 + Kal_noisysen(1) Kal_p = 1 - Kal_k Kal_p = Kal_p * Kal_pmin1 Kal_pmin = Kal_p + Kal_q Kal_x_hat_min(1) = Kal_x_hat(1) For Kal_n = 2 To Kal_length Kal_k = Kal_pmin + Kal_r Kal_k = Kal_pmin / Kal_k Kal_n2 = Kal_n - 1 Kal_x_hat(kal_n) = Kal_z(kal_n) - Kal_x_hat_min(kal_n2) Kal_x_hat(kal_n) = Kal_k * Kal_x_hat(kal_n) Kal_x_hat(kal_n) = Kal_x_hat_min(kal_n2) + Kal_x_hat(kal_n) Kal_p = 1 - Kal_k Kal_p = Kal_p * Kal_pmin Kal_pmin = Kal_p + Kal_q Kal_x_hat_min(kal_n) = Kal_x_hat(kal_n) Next End Sub
Zitieren
