Ergebnis 11 bis 20 von 32
Thema: RC-gesteuerter RP6
    Erde
    ok
    die fehlermeldung sieh jetzt so aus
    > "make.exe" all
    -------- begin --------
    avr-gcc (WinAVR 20081124rc3) 4.3.2
    Copyright (C) 2008 Free Software Foundation, Inc.
    This is free software; see the source for copying conditions.  There is NO
    warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
    Compiling: RP6Base_LEDs.c
    avr-gcc -c -mmcu=atmega32 -I. -gdwarf-2   -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=RP6Base_LEDs.lst -I../../RP6Lib -I../../RP6Lib/RP6base -I../../RP6Lib/RP6common -std=gnu99 -MD -MP -MF .dep/RP6Base_LEDs.o.d RP6Base_LEDs.c -o RP6Base_LEDs.o
    In file included from RP6Base_LEDs.c:6:
    ../../RP6Lib/RP6base/RP6RobotBaseLib.h:77: error: two or more data types in declaration specifiers
    make.exe: *** [RP6Base_LEDs.o] Error 1
    > Process Exit Code: 2
    > Time Taken: 00:00
    und jetzt ???
    danke
    Jetzt solltest du uns mal dein Programm zeigen :)
    Erde
    dann tuh ich das mal
    // RC-RP6 erster Versuch  18.11.07 mic
    #include "rblib.h"
    #include "rblib.c"
    #include "RP6RobotBaseLib.h"
    #define RP6BASELIB_H // zusäzliche Definition
    uint8_t y, z;
    uint8_t rc_input_pwr, rc_input_dir;
    uint8_t rc_pwr, rc_dir;
    ISR(TIMER0_COMP_vect)
       //static uint16_t count=0;
       static uint16_t rc_temp_pwr=0;
       static uint16_t rc_temp_dir=0;
       //if(count>x) PORTA &= ~16; else PORTA |= 16;   // E_INT1 (Pin8)
       //if(count>y) PORTC &= ~1;  else PORTC |= 1;   // SCL (Pin10)
       //if(count>z) PORTC &= ~2;  else PORTC |= 2;   // SDA (Pin12)
       //if(count<1000)count++; else count=0;
       if (PINC & 1) rc_temp_dir++; else
          if (rc_temp_dir) { rc_input_dir=rc_temp_dir-1; rc_temp_dir=0; }
       if (PINC & 2) rc_temp_pwr++; else
          if (rc_temp_pwr) { rc_input_pwr=rc_temp_pwr-1; rc_temp_pwr=0; }
    void servo_init(void)
       //DDRA |= 16;            // E_INT1 als Ausgang
       //DDRC |= 3;            // SCL und SDA als Ausgang
       TCCR0 =  (0 << WGM00) | (1 << WGM01);               // CTC-Mode
       TCCR0 |= (0 << COM00) | (0 << COM01);               // ohne OCR-Pin
       TCCR0 |=   (0 << CS02)  | (1 << CS01) | (0 << CS00);   // prescaler /8
       TIMSK =  (1 << OCIE0);                               // Interrupt ein
       OCR0  = 9; // 100kHz?
    int main(void)
       rblib_init();
       servo_init();
       setLEDs(0b1001);
       setMotorDir(FWD,FWD);
       setMotorPWM(0,0);
    while(1)
       rc_pwr=0;
       rc_dir=0;
       if (rc_input_dir<120) { rc_dir=150-rc_input_dir; setMotorDir(BWD,FWD); }
       if (rc_input_dir>140) { rc_dir=rc_input_dir-110; setMotorDir(FWD,BWD); }
       if (rc_input_pwr<120) { rc_pwr=150-rc_input_pwr; setMotorDir(FWD,FWD); }
       if (rc_input_pwr>140) { rc_pwr=rc_input_pwr-110; setMotorDir(BWD,BWD); }
       rc_pwr*=3;
       if (rc_pwr)
          if (rc_input_dir<120) setMotorPWM(rc_pwr-rc_dir,rc_pwr+rc_dir);
          else if (rc_input_dir>140) setMotorPWM(rc_pwr+rc_dir,rc_pwr-rc_dir);
          else setMotorPWM(rc_pwr,rc_pwr);
        else
          setMotorPWM(rc_dir*3, rc_dir*3);
       return 0;
    das ist das program aus einem der ersten beiträge.
    *lol* Na klasse, das sollte ich ja kennen.
    Übrigends sind diese Zeilen hier natürlich völlig falsch und absolut überflüssig:
    Das Programm verwendet meine Mini-Library weil die orginale Lib alle Timer belegt. Was meldet denn dein Kompiler wenn du das orginale Programm nur mit
    #include "rblib.h"
    #include "rblib.c"
    übersetzen willst?
    Erde
    dann gibt er wieder mehr fehler aus
    > "make.exe" all
    Linking: RP6Base_LEDs.elf
    avr-gcc -mmcu=atmega32 -I. -gdwarf-2   -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=RP6Base_LEDs.o -I../../RP6Lib -I../../RP6Lib/RP6base -I../../RP6Lib/RP6common -std=gnu99 -MD -MP -MF .dep/RP6Base_LEDs.elf.d RP6Base_LEDs.o ../../RP6Lib/RP6base/RP6RobotBaseLib.o ../../RP6Lib/RP6common/RP6uart.o --output RP6Base_LEDs.elf -Wl,-Map=RP6Base_LEDs.map,--cref    -lm
    ../../RP6Lib/RP6base/RP6RobotBaseLib.o: In function `updateStatusLEDs':
    E:\technik\RP6\RP6Examples_20080915\RP6BASE_EXAMPLES\Example_01_LEDs/../../RP6Lib/RP6base/RP6RobotBaseLib.c:129: multiple definition of `updateStatusLEDs'
    RP6Base_LEDs.o:E:\technik\RP6\RP6Examples_20080915\RP6BASE_EXAMPLES\Example_01_LEDs/../../RP6Lib/rblib.c:37: first defined here
    ../../RP6Lib/RP6base/RP6RobotBaseLib.o: In function `readADC':
    E:\technik\RP6\RP6Examples_20080915\RP6BASE_EXAMPLES\Example_01_LEDs/../../RP6Lib/RP6base/RP6RobotBaseLib.c:272: multiple definition of `readADC'
    RP6Base_LEDs.o:E:\technik\RP6\RP6Examples_20080915\RP6BASE_EXAMPLES\Example_01_LEDs/../../RP6Lib/rblib.c:28: first defined here
    ../../RP6Lib/RP6base/RP6RobotBaseLib.o: In function `startADC':
    E:\technik\RP6\RP6Examples_20080915\RP6BASE_EXAMPLES\Example_01_LEDs/../../RP6Lib/RP6base/RP6RobotBaseLib.c:288: multiple definition of `startADC'
    RP6Base_LEDs.o:E:\technik\RP6\RP6Examples_20080915\RP6BASE_EXAMPLES\Example_01_LEDs/../../RP6Lib/rblib.c:23: first defined here
    ../../RP6Lib/RP6base/RP6RobotBaseLib.o: In function `setMotorDir':
    E:\technik\RP6\RP6Examples_20080915\RP6BASE_EXAMPLES\Example_01_LEDs/../../RP6Lib/RP6base/RP6RobotBaseLib.c:948: multiple definition of `setMotorDir'
    RP6Base_LEDs.o:E:\technik\RP6\RP6Examples_20080915\RP6BASE_EXAMPLES\Example_01_LEDs/../../RP6Lib/rblib.c:18: first defined here
    ../../RP6Lib/RP6base/RP6RobotBaseLib.o: In function `__vector_10':
    E:\technik\RP6\RP6Examples_20080915\RP6BASE_EXAMPLES\Example_01_LEDs/../../RP6Lib/RP6base/RP6RobotBaseLib.c:1463: multiple definition of `__vector_10'
    RP6Base_LEDs.o:E:\technik\RP6\RP6Examples_20080915\RP6BASE_EXAMPLES\Example_01_LEDs/RP6Base_LEDs.c:13: first defined here
    ../../RP6Lib/RP6common/RP6uart.o: In function `writeChar':
    E:\technik\RP6\RP6Examples_20080915\RP6BASE_EXAMPLES\Example_01_LEDs/../../RP6Lib/RP6common/RP6uart.c:73: multiple definition of `writeChar'
    RP6Base_LEDs.o:E:\technik\RP6\RP6Examples_20080915\RP6BASE_EXAMPLES\Example_01_LEDs/../../RP6Lib/rblib.c:57: first defined here
    ../../RP6Lib/RP6common/RP6uart.o: In function `writeString':
    E:\technik\RP6\RP6Examples_20080915\RP6BASE_EXAMPLES\Example_01_LEDs/../../RP6Lib/RP6common/RP6uart.c:97: multiple definition of `writeString'
    RP6Base_LEDs.o:E:\technik\RP6\RP6Examples_20080915\RP6BASE_EXAMPLES\Example_01_LEDs/../../RP6Lib/rblib.c:61: first defined here
    ../../RP6Lib/RP6common/RP6uart.o: In function `writeInteger':
    E:\technik\RP6\RP6Examples_20080915\RP6BASE_EXAMPLES\Example_01_LEDs/../../RP6Lib/RP6common/RP6uart.c:165: multiple definition of `writeInteger'
    RP6Base_LEDs.o:E:\technik\RP6\RP6Examples_20080915\RP6BASE_EXAMPLES\Example_01_LEDs/../../RP6Lib/rblib.c:66: first defined here
    make.exe: *** [RP6Base_LEDs.elf] Error 1
    > Time Taken: 00:00
    danke übrigents für die mühe.
    Es ist für mich keine Mühe. Ich bewundere vielmehr deine Hartnäckigkeit mit der du am Ball bleibst. Ein Problem ist einfach, dass ich mich mit den internen Vorgängen beim Kompilieren nicht so gut auskenne. Und dass ich nicht das Notepad/Avrstudio verwende. Denn hier scheint mir das eigentliche Problem zu liegen. Irgendwie wird trotz allem ein Teil der orginalen RP6-Lib eingebunden. Deshalb habe ich auch nicht erkannt, dass du versuchst mein Programm zu kompilieren.
    Was mich dabei sehr verwirrt: Hast du das RC-Programm als "RP6Base_LEDs" gespeichert? Ich habe das Gefühl, irgendwie scheinen da zwei Programme in einem Projekt verbunden. Ob das aber am Makefile, an den geöffneten Dateien im Notepad oder sonstwas verursacht wird kann ich nicht sagen. Ich würde deshalb vorschlagen, dass wir mal eine kleine Pause machen und bis morgen abwarten. Möglicherweise meldet sich jemand der sich besser auskennt.
    Erde
    ja, ich have es als RP6_LEDs gespeichert weil mir in diesem projekt bisher nur das kompilimieren gelungen ist wenn ich das in einem seperatem projekt speicher kommt immer eine fehlemeldung
    no rule to make target *.elf
    und deswegen ist das unter RP6_LEDs gespeichert.
    Paderborn
    Habe leider keine Zeit ausführlich zu antworten, aber es gibt hier schon viele viele Threads zu dem Thema! Einfach mal die SuFu benutzen.
    #include "rblib.h"
    #include "rblib.c" <<<<<------ lösch das mal
    Man included keine C Dateien das ist böse! Bild
    Und das hier:
    http://www.arexx.com/rp6/downloads/R...t_template.zip
    hernehmen als Template für eigene Projekte und entsprechend umbennenen. (aber die alte RP6 Library Version die noch dabei ist bitte durch die aktuelle Version ersetzen! )
    MfG,
    SlyD
    PS:
    Im Makefile muss immer der Name des Haupt Quelldatei angegeben werden! TARGET = RP6Base_LEDs z.B. wenn die Datei RP6Base_LEDs.c heisst...
    Erde
    das mit dem *c file includen hat schonmal geholfen aber komplett kompilimieren konnte ich das imer noch nicht
    > "make.exe" all
    RP6Base_LEDs.o:e:\technik\rp6\rp6examples_20080915\rp6base_examples\Example_01_LEDs/RP6Base_LEDs.c:13: first defined here
    RP6Base_LEDs.o: In function `main':
    RP6Base_LEDs.c:(.text+0x8c): undefined reference to `rblib_init'
    RP6Base_LEDs.c:(.text+0xb6): undefined reference to `setMotorPWM'
    RP6Base_LEDs.c:(.text+0x164): undefined reference to `setMotorPWM'
    > Time Taken: 00:02
    diese fehlermeldung habe ich jetzt
    danke für eure hilfe
    Nein, es hat überhaupt nicht geholfen. Das eigentliche Problem besteht nach wie vor: Die orginale RP6-Library wird eingebunden obwohl wir das nicht wollen. Ohne rblib.c werden die doppelten Definitionen der Funktionen nicht mehr gemeldet, allerdings fehlen dann auch diejenigen Funktionen die in rblib.c definiert sind: rblib_init() und setMotorPWM():
    Das in der RP6-Lib die ISR des Timer0 belegt ist, diese aber auch im RC-Steuerprogram neu definiert wird (ISR(TIMER0_COMP_vect) ) erkennt der Kompiler natürlich auch:
    Das ist letzlich auch der Grund warum ich mir damals eine eigene abgespeckte Lib zusammenkopiert habe. (Bei einem Microprozessor ala z80 oder 6809 würde ich zur Laufzeit einfach die Sprungtabellen manipulieren, bei den AVRs habe ich eine vergleichbare Möglichkeit bisher noch nicht gefunden)
    Warum das includen von C-Dateien "böse" ist kann ich als C-Neulich nicht sagen. Ich war bisher der Meinung, eine mit #include eingefügte Datei wird eben schlicht an der Stelle eingesetzt, an der man sie includet. Ob das nun #defines einer h-Datei sind, oder Arrays für eine Zeichensatzdefinition oder eben zusätzliche Funktionen in einer Datei mit Endung .c
    Aber ich schweife mal wieder ab, zurück zum eigentlichen Problem: Die Datei rblib.c muss unbedingt includet werden und die Datei RP6RobotBaseLib.c darf es auf gar keinen Fall sonst funtzt das nicht mit dem RC-Programm. Die Frage ist deshalb: Wo und wieso wird die RP6-Lib eingebunden?
    [Edit]
    Ich habe mir nun (zum ersten mal) ein RP6-Makefile angeschaut. Es stammt aus den Beispielen, Nr.1: LEDs Datei: makefile
    Und siehe da, hier scheint unser Problem zu schlummern:
    # If there is more than one source file, append them here separated by spaces.
    # Usually you have to add the Library files here! (ONLY add c files "*.c" here,
    # NO header files "*.h"!)
    # Don't forget to add relative paths!
    SRC += $(RP6_LIB_PATH)/RP6base/RP6RobotBaseLib.c
    SRC += $(RP6_LIB_PATH)/RP6common/RP6uart.c
    #SRC += $(RP6_LIB_PATH)/RP6common/RP6I2CslaveTWI.c
    #SRC += $(RP6_LIB_PATH)/RP6common/RP6I2CmasterTWI.c
    Hier werden die Dateien RP6RobotBaseLib.c (und RP6uart.c) in ein Projekt eingebunden. Das # ist wohl der Start eines Kommentars, dann sollten diese Änderungen unser Problem lösen:
    #SRC += $(RP6_LIB_PATH)/RP6base/RP6RobotBaseLib.c
    #SRC += $(RP6_LIB_PATH)/RP6common/RP6uart.c
    Die orginale Version meines Progamms
    #include "rblib.h"
    #include "rblib.c"
    uint8_t y, z;
    zusammen mit den Dateien rblib.h und rblib.c im selben Verzeichniss (das hast du ja schon) sollte nun endlich fehlerfrei kompilierbar sein. Hoffe ich zumindest ;)
