Ergebnis 1 bis 10 von 20
Thema: Servo bewegt sich nicht
    Mithilfe von Dirks Servo Base Bibliothek und dem TV_Remote Bspl habe ich folgendes Programm "geschrieben" :
    // written David Smutny
    // RP6BaseServoLib was written by Dirk
    #include "RP6BaseServoLib.h"
    #include "RP6RobotBaseLib.h"
    #define RC_YOUR_OWN
    #ifdef RC_YOUR_OWN
    	#define RC5_KEY_LEFT 				20
    	#define RC5_KEY_RIGHT 				22
    	#define RC5_KEY_FORWARDS 			18
    	#define RC5_KEY_BACKWARDS 			24
    	#define RC5_KEY_STOP 				32
    	#define RC5_KEY_CURVE_LEFT 			17
    	#define RC5_KEY_CURVE_RIGHT 		19
    	#define RC5_KEY_CURVE_BACK_LEFT 	23
    	#define RC5_KEY_CURVE_BACK_RIGHT 	25
    	#define RC5_KEY_LEFT_MOTOR_FWD 		26
    	#define RC5_KEY_LEFT_MOTOR_BWD 		41
    	#define RC5_KEY_RIGHT_MOTOR_FWD 	42
    	#define RC5_KEY_RIGHT_MOTOR_BWD 	49
    	#define RC5_KEY_SERVO_L             37
    	#define RC5_KEY_SERVO_R				36
    #endif
    #define MAX_SPEED_MOVE 200
    #define MAX_SPEED_TURN 100
    #define MAX_SPEED_CURVE 120
    #define MAX_SPEED_CURVE2 40
    #define ACCELERATE_CURVE 10
    #define ACCELERATE_CURVE2 4
    #define DECELERATE_CURVE 4
    #define DECELERATE_CURVE2 2
    #define MAX_SPEED_1_MOTOR 120
    #define ACCELERATE_VALUE 8
    #define DECELERATE_VALUE 4
    uint8_t max_speed_left;
    uint8_t max_speed_right;
    uint8_t acl_left;
    uint8_t acl_right;
    uint8_t decl_left;
    uint8_t decl_right;
    uint16_t pos = 0;
    uint8_t servorcan = 1;      //rechter Servo
    uint8_t servolcan = 1;		//linker Ser
    void setDefaultSpeedParameters(void)
    	max_speed_left = MAX_SPEED_MOVE;
    	max_speed_right = max_speed_left;
    	acl_left = ACCELERATE_VALUE;
    	acl_right = ACCELERATE_VALUE;
    	decl_left = DECELERATE_VALUE;
    	decl_right = DECELERATE_VALUE;
    	uint16_t tmp = (getDesSpeedLeft() + getDesSpeedRight())/2;
    	moveAtSpeed(tmp , tmp);
    void receiveRC5Data(RC5data_t rc5data)
    	writeString_P("Toggle Bit:");
    	writeChar(rc5data.toggle_bit + '0');
    	writeString_P(" | Device Address:");
    	writeInteger(rc5data.device, DEC);
    	writeString_P(" | Key Code:");
    	writeInteger(rc5data.key_code, DEC);
    	writeChar('\n');
    #ifndef DO_NOT_MOVE
    	uint8_t movement_command = false;
    	switch(rc5data.key_code)
    		case RC5_KEY_LEFT:
    			writeString_P("LEFT\n");
    			setDefaultSpeedParameters();
    			max_speed_left = MAX_SPEED_TURN;
    			changeDirection(LEFT);
    			setLEDs(0b100000);
    			movement_command = true;
    		break;
    		case RC5_KEY_RIGHT:
    			writeString_P("RIGHT\n");
    			changeDirection(RIGHT);
    			setLEDs(0b000100);
    		break;
    		case RC5_KEY_FORWARDS:
    			writeString_P("FORWARDS\n");
    			changeDirection(FWD);
    			setLEDs(0b100100);
    		break;
    		case RC5_KEY_BACKWARDS:
    			writeString_P("BACKWARDS\n");
    			changeDirection(BWD);
    			setLEDs(0b001001);
    		break;
    		case RC5_KEY_STOP:
    			writeString_P("STOP\n");
    			max_speed_left = 0;
    			moveAtSpeed(0,0);
    			setLEDs(0b011011);
    		break;
    		case RC5_KEY_CURVE_LEFT:
    			writeString_P("CURVE LEFT FWD\n");
    			max_speed_left = MAX_SPEED_CURVE2;
    			max_speed_right = MAX_SPEED_CURVE;
    			acl_left = ACCELERATE_CURVE2;
    			acl_right = ACCELERATE_CURVE;
    			decl_left = DECELERATE_CURVE2;
    			decl_right = DECELERATE_CURVE;
    			setLEDs(0b110100);
    		break;
    		case RC5_KEY_CURVE_RIGHT:
    			writeString_P("CURVE RIGHT FWD\n");
    			max_speed_left = MAX_SPEED_CURVE;
    			max_speed_right = MAX_SPEED_CURVE2;
    			acl_left = ACCELERATE_CURVE;
    			acl_right = ACCELERATE_CURVE2;
    			decl_left = DECELERATE_CURVE;
    			decl_right = DECELERATE_CURVE2;
    			setLEDs(0b100110);
    		break;
    		case RC5_KEY_CURVE_BACK_LEFT:
    			writeString_P("CURVE LEFT BWD\n");
    			setLEDs(0b011001);
    		break;
    		case RC5_KEY_CURVE_BACK_RIGHT:
    			writeString_P("CURVE RIGHT BWD\n");
    			setLEDs(0b001011);
    		break;
    		case RC5_KEY_LEFT_MOTOR_FWD:
    			writeString_P("MOTOR LEFT FWD\n");
    			max_speed_left = 0;
    			max_speed_right = MAX_SPEED_1_MOTOR;
    			acl_left = 4;
    			acl_right = 4;
    			decl_left = 4;
    			decl_right = 4;
    			setLEDs(0b110000);
    		break;
    		case RC5_KEY_LEFT_MOTOR_BWD:
    			writeString_P("MOTOR LEFT BWD\n");
    			max_speed_left = 0;
    			acl_left = 4;
    			acl_right = 4;
    			decl_left = 4;
    			decl_right = 4;
    			setLEDs(0b101000);
    		break;
    		case RC5_KEY_RIGHT_MOTOR_FWD:
    			writeString_P("MOTOR RIGHT FWD\n");
    			max_speed_left = MAX_SPEED_1_MOTOR;
    			max_speed_right = 0;
    			acl_left = 4;
    			acl_right = 4;
    			decl_left = 4;
    			decl_right = 4;
    			setLEDs(0b000110);
    		break;
    		case RC5_KEY_RIGHT_MOTOR_BWD:
    			writeString_P("MOTOR RIGHT BWD\n");
    			acl_left = 4;
    			acl_right = 4;
    			decl_left = 4;
    			decl_right = 4;
    			setLEDs(0b000101);
    		break;
    		case RC5_KEY_SERVO_L:
    			writeString_P("Servo nach links\n");
    				pos -= 10;
    		break;
    		case RC5_KEY_SERVO_R:
    			writeString_P("Servo nach rechts\n");
    				pos += 10;
    		break;
    	if(movement_command)
    		if(getDesSpeedLeft() < max_speed_left)
    			moveAtSpeed(getDesSpeedLeft()+acl_left, getDesSpeedRight());
    			if(getDesSpeedLeft() < 10)
    				moveAtSpeed(10, getDesSpeedRight());
    		if(getDesSpeedRight() < max_speed_right)
    			moveAtSpeed(getDesSpeedLeft(), getDesSpeedRight()+acl_right);
    			if(getDesSpeedRight() < 10)
    				moveAtSpeed(getDesSpeedLeft(), 10);
    		setStopwatch4(0);
    		startStopwatch4();
    #endif
    void deccelerate(void)
    	if(getStopwatch4() > 250)
    		if(getDesSpeedLeft() <= 10)
    			moveAtSpeed(0, getDesSpeedRight());
    		else
    			moveAtSpeed(getDesSpeedLeft()-decl_left, getDesSpeedRight());
    		if(getDesSpeedRight() <= 10)
    			moveAtSpeed(getDesSpeedLeft(), 0);
    		else
    			moveAtSpeed(getDesSpeedLeft(), getDesSpeedRight()-decl_right);
    		if (getDesSpeedRight() == 0 && getDesSpeedLeft() == 0)
    			stopStopwatch1();
    		max_speed_left = getDesSpeedLeft();
    		max_speed_right = getDesSpeedRight();
    		setLEDs(0b000000);
    		setStopwatch4(0);
    	if(getDesSpeedLeft() > max_speed_left)
    		else
    	if(getDesSpeedRight() > max_speed_right)
    		else
    int main(void)
    	initRobotBase();
    	setLEDs(0b111111);
    	writeChar('\n');
        writeString_P("RP6 controlled by RC5 TV Remote\n");
    	writeString_P("___________________________\n");
    	mSleep(500);
    	setLEDs(0b000000);
    	powerON();
    	IRCOMM_setRC5DataReadyHandler(receiveRC5Data);
    	writeString_P("\n * Turn Left: "); 					writeInteger(RC5_KEY_LEFT, DEC);
    	writeString_P("\n * Turn Right: "); 				writeInteger(RC5_KEY_RIGHT, DEC);
    	writeString_P("\n * Move Forwards: "); 				writeInteger(RC5_KEY_FORWARDS, DEC);
    	writeString_P("\n * Move Backwards: "); 			writeInteger(RC5_KEY_BACKWARDS, DEC);
    	writeString_P("\n * Stop: "); 						writeInteger(RC5_KEY_STOP, DEC);
    	writeString_P("\n * Move curve left forwards: "); 	writeInteger(RC5_KEY_CURVE_LEFT, DEC);
    	writeString_P("\n * Move curve right forwards: "); 	writeInteger(RC5_KEY_CURVE_RIGHT, DEC);
    	writeString_P("\n * Move curve left backwards: "); 	writeInteger(RC5_KEY_CURVE_BACK_LEFT, DEC);
    	writeString_P("\n * Move curve right backwards: "); writeInteger(RC5_KEY_CURVE_BACK_RIGHT, DEC);
    	writeString_P("\n * Motor left forwards: "); 		writeInteger(RC5_KEY_LEFT_MOTOR_FWD, DEC);
    	writeString_P("\n * Motor left backwards: "); 		writeInteger(RC5_KEY_LEFT_MOTOR_BWD, DEC);
    	writeString_P("\n * Motor right forwards: "); 		writeInteger(RC5_KEY_RIGHT_MOTOR_FWD, DEC);
    	writeString_P("\n * Motor right backwards: "); 		writeInteger(RC5_KEY_RIGHT_MOTOR_BWD, DEC);
    	writeString_P("\n * Servo nach rechts: ");			writeInteger(RC5_KEY_SERVO_R, DEC);
    	writeString_P("\n * Servo nach links: ");			writeInteger(RC5_KEY_SERVO_L, DEC);
    	writeString_P("\n-----------------------\n");
    	startStopwatch2();
    	initSERVO(SERVO1);
    	while(true)
    		servo1_position = pos;
    		deccelerate();
    		task_RP6System();
    	return 0;
    Wenn ich nun die entsprechende Taste drücke bewegt sich der servo aber nicht...  :-s
    Kann mir jemand helfen?
    danke schonmal
    gruß
    David
    NRW
    Hallo David,
    in die while(true) Schleife müßtest du noch die task_SERVO aufnehmen und sagen, wie sich das Servo bewegen soll:
    	startStopwatch2();					// Used for the demo
    	while(true)
    // The demo code for positioning servo 1:
    		if (getStopwatch2() > 48) {	// Change position every ~50ms
    			servo1_position = pos;		// Position of servo 1
    			pos++;						// Next position to the right
    			if (pos > RIGHT_TOUCH) {pos = 0;} // pos: 0..RIGHT_TOUCH
    			setStopwatch2(0);
    		task_SERVO();
    		deccelerate();
    		task_RP6System();
    Gruß Dirk
    hallo dirk,
    danke für deine antwort, ich werds gleich mal ausprobieren =)
    david
    Hallo Dirk,
    Ich habs jetzt so verändert wie du´s gesagt hast...
    // written by David Smutny
    #define RC_YOUR_OWN
    #ifdef RC_YOUR_OWN
    #endif
    uint8_t acl_left;
    uint8_t acl_right;
    uint8_t decl_left;
    uint8_t decl_right;
    uint16_t pos = 100;
    	writeChar('\n');
    #ifndef DO_NOT_MOVE
    		case RC5_KEY_LEFT:
    			setLEDs(0b100000);
    		break;
    		case RC5_KEY_RIGHT:
    			setLEDs(0b000100);
    		break;
    			setLEDs(0b100100);
    		break;
    			setLEDs(0b001001);
    		break;
    		case RC5_KEY_STOP:
    			max_speed_left = 0;
    			moveAtSpeed(0,0);
    			setLEDs(0b011011);
    		break;
    			setLEDs(0b110100);
    		break;
    			setLEDs(0b100110);
    		break;
    			setLEDs(0b011001);
    		break;
    			setLEDs(0b001011);
    		break;
    			max_speed_left = 0;
    			acl_left = 4;
    			acl_right = 4;
    			decl_left = 4;
    			decl_right = 4;
    			setLEDs(0b110000);
    		break;
    			max_speed_left = 0;
    			acl_left = 4;
    			acl_right = 4;
    			decl_left = 4;
    			decl_right = 4;
    			setLEDs(0b101000);
    		break;
    			acl_left = 4;
    			acl_right = 4;
    			decl_left = 4;
    			decl_right = 4;
    			setLEDs(0b000110);
    		break;
    			acl_left = 4;
    			acl_right = 4;
    			decl_left = 4;
    			decl_right = 4;
    			setLEDs(0b000101);
    		break;
    				pos ++;
    				writeInteger(pos, DEC);
    		break;
    			if (pos < LEFT_TOUCH)
    				pos --;
    		break;
    		setStopwatch4(0);
    		startStopwatch4();
    #endif
    		else
    		else
    			stopStopwatch1();
    		setLEDs(0b000000);
    		setStopwatch4(0);
    		else
    		else
    int main(void)
    	initRobotBase();
    	setLEDs(0b111111);
    	writeChar('\n');
    	mSleep(500);
    	setLEDs(0b000000);
    	powerON();
    	startStopwatch2();
    	initSERVO(SERVO1);
    	while(true)
    		 {servo1_position = pos;}
    		 setStopwatch2(0);
    		deccelerate();
    		task_SERVO();
    		task_RP6System();
    	return 0;
    Der Servo will aber noch immer nicht...
    Was ist noch falsch??
    Bei deinem Beispiel-Programm bewagt er sich...
    gruß David
    NRW
    Hallo David,
    erstmal die Klammern anders:
       startStopwatch2();
       initSERVO(SERVO1);
       while(true)
           setStopwatch2(0);
          deccelerate();
          task_SERVO();
          task_RP6System();
       return 0;
    ... und dann wird sich das Servo ja nur bewegen, wenn sich pos irgendwie ändert. Das must du machen.
    Gruß Dirk
    Ja, genau...
    Das mach ich doch mit:
    				pos ++;
    				writeString_P("Servo Position:\n");  writeInteger(pos, DEC);
    		break;
    				pos --;
    		break;
    oder?
    Also leider gehts bei mir noch immer nicht... Bild
    Wie ich es drehe und wende... Es will nicht funktionieren =(
    NRW
    Poste doch deinen aktuellen Code noch 'mal.
    Ich probiere ihn dann mal bei mir.
    Gruß Dirk
    Hallo Dirk,
    vielen Dank für deine Hilfe.
    Hier mein Aktueller Code:
    #define RC_YOUR_OWN
    #ifdef RC_YOUR_OWN
    #endif
    uint8_t acl_left;
    uint8_t acl_right;
    uint8_t decl_left;
    uint8_t decl_right;
    uint16_t pos = 100;
    	writeChar('\n');
    #ifndef DO_NOT_MOVE
    		case RC5_KEY_LEFT:
    			setLEDs(0b100000);
    		break;
    		case RC5_KEY_RIGHT:
    			setLEDs(0b000100);
    		break;
    			setLEDs(0b100100);
    		break;
    			setLEDs(0b001001);
    		break;
    		case RC5_KEY_STOP:
    			max_speed_left = 0;
    			moveAtSpeed(0,0);
    			setLEDs(0b011011);
    		break;
    			setLEDs(0b110100);
    		break;
    			setLEDs(0b100110);
    		break;
    			setLEDs(0b011001);
    		break;
    			setLEDs(0b001011);
    		break;
    			max_speed_left = 0;
    			acl_left = 4;
    			acl_right = 4;
    			decl_left = 4;
    			decl_right = 4;
    			setLEDs(0b110000);
    		break;
    			max_speed_left = 0;
    			acl_left = 4;
    			acl_right = 4;
    			decl_left = 4;
    			decl_right = 4;
    			setLEDs(0b101000);
    		break;
    			acl_left = 4;
    			acl_right = 4;
    			decl_left = 4;
    			decl_right = 4;
    			setLEDs(0b000110);
    		break;
    			acl_left = 4;
    			acl_right = 4;
    			decl_left = 4;
    			decl_right = 4;
    			setLEDs(0b000101);
    		break;
    				pos ++;
    		break;
    				pos --;
    		break;
    		setStopwatch4(0);
    		startStopwatch4();
    #endif
    		else
    		else
    			stopStopwatch1();
    		setLEDs(0b000000);
    		setStopwatch4(0);
    		else
    		else
    int main(void)
    	initRobotBase();
    	setLEDs(0b111111);
    	writeChar('\n');
    	mSleep(500);
    	setLEDs(0b000000);
    	powerON();
    	writeString_P("\n *curve left backwards: "); 	writeInteger(RC5_KEY_CURVE_BACK_LEFT, DEC);
       startStopwatch2();
       initSERVO(SERVO1);
       while(true)
           setStopwatch2(0);
          deccelerate();
          task_SERVO();
          task_RP6System();
       return 0;
    Ich hoffe du kanst den Fehler finden!
    gruß David
    NRW
    Hallo David,
    so, nun hab ich's:
    Ändere die RC5 Abfragen 'mal so:
    		startSERVO();
    		setStopwatch6(0);
    		startStopwatch6();
            if (pos >= 10) {
                pos -= 10;
    		else {
    			pos = 0;
          break;
    		startSERVO();
    		setStopwatch6(0);
    		startStopwatch6();
            if (pos <= (RIGHT_TOUCH - 10)) {
                pos += 10;
    		else {
    			pos = RIGHT_TOUCH;
          break;
    ... und die while(1) Schleife so:
    	stopSERVO();
       while(true)
          deccelerate();
          task_SERVO();
          if (getStopwatch6() > 300) {stopSERVO();}
          task_RP6System();
    Gruß Dirk
