Also das ist der aktuelle Stand der Funzt. zur abwechslung auch mal *g*
Code:$regfile = "m168def.dat" $crystal = 16000000 'Quarzfrequenz $baud = 9600 $hwstack = 32 $framesize = 32 $swstack = 32 Dim Center As Integer Dim Pos1 As Integer Dim Pos2 As Integer Dim Pos3 As Integer Center = 105 Pos1 = 30 Pos2 = 180 Pos3 = 140 'Servo config Config Servos = 1 , Servo1 = Portd.2 , Reload = 10 Config Portd = Output 'finally we must turn on the global interrupt Enable Interrupts 'ende Servo config Do Servo(1) = Center Waitms 1000 Servo(1) = Pos1 Waitms 1000 Servo(1) = Center Waitms 1000 Servo(1) = Pos3 Waitms 1000 Servo(1) = Center Waitms 1000 Servo(1) = Pos2 Waitms 1000 Loop
Zitieren
