Ein kleines Video gefällig?
http://www.youtube.com/watch?v=Hmy_6wn5HFg
Das einfache "links dunkler als rechts"-Programm:
Und die Header-Datei dazu:Code:// Einfaches Linienfolgen mit dem asuro-ProBot 30.8.09 mic #include "selftest.h" void Init(void); void Sleep(unsigned char time36kHz); void Msleep(int dauer); void SerWrite(unsigned char *data,unsigned char length); void PrintInt(int wert); void PrintBin(char wert); inline void StatusLED(unsigned char color); inline void FrontLED(unsigned char status); void BackLED(unsigned char left, unsigned char right); inline void MotorSpeed(unsigned char left_speed, unsigned char right_speed); inline void MotorDir(unsigned char left_dir, unsigned char right_dir); void LineData(unsigned int *data); inline void StatusLED(unsigned char color); void SetLEDs(unsigned char status); int main(void) { unsigned int data[2]; //unsigned char i; Init(); SerWrite("\n\rasuro-ProBot-Linienfolgen\n\r",29); SerWrite("30.8.09 mic \n\r", 14); DDRD |= (1<<PD2) | (1<<PD3) | (1<<PD4) | (1<<PD5) | (1<<PD6); // D12-15 und FrontLED PORTD |= (1<<PD2) | (1<<PD3) | (1<<PD4) | (1<<PD5) | (1<<PD6); // high bedeutet LEDs aus //PORTD &= ~((1<<PD2) | (1<<PD3) | (1<<PD4) | (1<<PD5)); // D12-15 an //SetLEDs(0b11111); // FrontLED, D14(red), D15, D13, D12(green) FrontLED(ON); MotorSpeed(225,225); while(1) { LineData(data); if(data[0]<data[1]) MotorSpeed(200,250); else MotorSpeed(250,200); /* PrintInt(data[0]); SerWrite("- ", 2); PrintInt(data[1]); SerWrite("\n\r", 2); Msleep(100); */ Sleep(255); } return(0); // wird nie erreicht! } volatile unsigned char count36kHz; volatile unsigned long timebase; /* uses timer2 (36kHz for IR communication */ SIGNAL (SIG_OVERFLOW2) { TCNT2 += 0x25; count36kHz ++; if (!count36kHz) timebase ++; } void Init (void) { //-------- seriell interface programmed in boot routine and already running ------- // prepare 36kHz for IR - Communication TCCR2 = (1 << WGM20) | (1 << WGM21) | (1 << COM20) | (1 << COM21) | (1 << CS20); OCR2 = 0x91; // duty cycle for 36kHz TIMSK |= (1 << TOIE2); // 36kHz counter for sleep // prepare RS232 UCSRA = 0x00; UCSRB = 0x00; UCSRC = 0x86; // No Parity | 1 Stop Bit | 8 Data Bit UBRRL = 0xCF; // 2400bps @ 8.00MHz // I/O Ports DDRB = IRTX | LEFT_DIR | PWM | GREEN_LED; //DDRD = RIGHT_DIR | FRONT_LED | ODOMETRIE_LED | RED_LED; // for PWM (8-Bit PWM) on OC1A & OC1B TCCR1A = (1 << WGM10) | (1 << COM1A1) | (1 << COM1B1); // tmr1 running on MCU clock/8 TCCR1B = (1 << CS11); // A/D Conversion ADCSRA = (1 << ADEN) | (1 << ADPS2) | (1 << ADPS1); // clk/64 ODOMETRIE_LED_OFF; StatusLED(GREEN); MotorDir(FWD,FWD); MotorSpeed(0,0); sei(); } void Sleep(unsigned char time36kHz) { unsigned char ziel=(time36kHz+count36kHz) & 0x00FF; while (count36kHz != ziel); } void Msleep(int dauer) { while(dauer--) Sleep(36); } void SerWrite(unsigned char *data,unsigned char length) { unsigned char i = 0; UCSRB = 0x08; // enable transmitter while (length > 0) { if (UCSRA & 0x20) { // wait for empty transmit buffer UDR = data[i++]; length --; } } while (!(UCSRA & 0x40)); for (i = 0; i < 0xFE; i++) for(length = 0; length < 0xFE; length++); } void PrintInt(int wert) { char text[6]=" "; itoa(wert,text,10); SerWrite(text,5); } void PrintBin(char wert) { char text[8]=" "; itoa(wert,text,2); SerWrite(text,8); } /* Set motor speed */ inline void MotorSpeed(unsigned char left_speed, unsigned char right_speed) { OCR1A = left_speed; OCR1B = right_speed; } /* Set motor direction */ inline void MotorDir(unsigned char left_dir, unsigned char right_dir) { if(left_dir) PORTB &= ~(1 << PB5); else PORTB |= (1 << PB5); if(right_dir) PORTB &= ~(1 << PB4); else PORTB |= (1 << PB4); } void LineData(unsigned int *data) { ADMUX = (1 << REFS0) | IR_LEFT; // AVCC reference with external capacitor Sleep(10); ADCSRA |= (1 << ADSC); // Start conversion while (!(ADCSRA & (1 << ADIF))); // wait for conversion complete ADCSRA |= (1 << ADIF); // clear ADCIF data[0] = ADCL + (ADCH << 8); ADMUX = (1 << REFS0) | IR_RIGHT; // AVCC reference with external capacitor Sleep(10); ADCSRA |= (1 << ADSC); // Start conversion while (!(ADCSRA & (1 << ADIF))); // wait for conversion complete ADCSRA |= (1 << ADIF); // clear ADCIF data[1] = ADCL + (ADCH << 8); } inline void StatusLED(unsigned char color) { if (color == OFF) {GREEN_LED_OFF; RED_LED_OFF;} if (color == GREEN) {GREEN_LED_ON; RED_LED_OFF;} if (color == YELLOW) {GREEN_LED_ON; RED_LED_ON;} if (color == RED) {GREEN_LED_OFF; RED_LED_ON;} } void SetLEDs(unsigned char status) { status = ~(status<<2); // LEDs sind PD2-7 gegen Vcc schaltend! PORTD &= status; // nur gesetzte LEDs einschalten PORTD |= status & ~3; // PD0 und PD1 nicht verändern! } inline void FrontLED(unsigned char status) { if(status) FRONT_LED_on; else FRONT_LED_off; }
:)Code:// Einfaches Linienfolgen mit dem asuro-ProBot 30.8.09 mic #include <avr/io.h> #include <avr/interrupt.h> #include <stdlib.h> #define FALSE 0 #define TRUE 1 #define OFF 0 #define ON 1 #define GREEN 1 #define RED 2 #define YELLOW 3 /* --------------- INTERNAL ------------- */ #define GREEN_LED_OFF PORTD |= GREEN_LED #define GREEN_LED_ON PORTD &= ~GREEN_LED #define RED_LED_OFF PORTD |= RED_LED #define RED_LED_ON PORTD &= ~RED_LED #define FWD 0 #define RWD 1 #define BREAK 0x00 #define FREE (1 << PB4) | (1 << PB5) /* (1 << PD4) | (1 << PD5)*/ #define IRTX (1 << PB3) #define GREEN_LED (1 << PD5) #define RED_LED (1 << PD2) #define PWM (1 << PB1) | (1 << PB2) #define RIGHT_DIR (1 << PB4) | (1 << PB5) #define LEFT_DIR (1 << PD4) | (1 << PD5) #define BATTERIE (1 << MUX0) | (1 << MUX2) //ADC5 #define SWITCH (1 << MUX2) //ADC4 #define IR_LEFT (1 << MUX0) | (1 << MUX1) //ADC3 #define IR_RIGHT (1 << MUX1) //ADC2 #define Speaker (1 << PD5) // speaker an D14 #define Speaker_on PORTD &= ~(1<<PD5) #define Speaker_off PORTD |= (1<<PD5) #define FRONT_LED (1 << PD6) #define FRONT_LED_on PORTD &= ~(1<<PD6) #define FRONT_LED_off PORTD |= (1<<PD6) #define ODOMETRIE_LED (1 << PD7) #define ODOMETRIE_LED_ON PORTD |= ODOMETRIE_LED #define ODOMETRIE_LED_OFF PORTD &= ~ODOMETRIE_LED #define WHEEL_LEFT (1 << MUX0) //ADC1 #define WHEEL_RIGHT 0 //ADC0 #define LED12_on PORTD &= ~(1<<PD2) #define LED13_on PORTD &= ~(1<<PD3) #define LED14_on PORTD &= ~(1<<PD5) // Achtung Reihenfolge D14/15 getauscht! #define LED15_on PORTD &= ~(1<<PD4) #define LED12_off PORTD |= (1<<PD2) #define LED13_off PORTD |= (1<<PD3) #define LED14_off PORTD |= (1<<PD5) #define LED15_off PORTD |= (1<<PD4)
btw kann ich den Motortreiberumbau nur empfehlen.
Zitieren
