Ach - jeden Tag will einer geistig aussteigen! Bleib ruhig, Junge, im doc steht (im 8155A–AVR–06/08 auf Seite 5):Zitat von Gary
2.2.5 Port C (PC7:PC0)
Port C is an 8-bit bi-directional I/O port with internal pull-up resistors (selected for each bit). The Port C output buffers have symmetrical drive characteristics with both high sink and source capability. As inputs, Port C pins that are externally pulled low will source current if the pull-up resistors are activated. The Port C pins are tri-stated when a reset condition becomes active, even if the clock is not running. If the JTAG interface is enabled, the pull-up resistors on pins PC5(TDI), PC3(TMS) and PC2(TCK) will be activated even if a reset occurs.
Also - bei den Fuses JTAG disablen - und neuen Versuch starten. Dann sollte es klappen.
Viele Grüße, viel Erfolg
Zitieren
