kann mir jemand dabei helfen das standard testprogramm des Ultraschallsensors vom asuro so zu erweitern, dass der asuro nicht nur nach links abdreht wenn er ein hinderniss erkennt, sondern auch rechts abbiegt.
also mal links abdreht und mal rechts.
hier der Programmcode
Code:#include "asuro.h" void LocalInit(void) { // Change Oscillator-frequency of Timer 2 // to 40kHz, no toggling of IO-pin: TCCR2 = (1 << WGM21) | (1 << CS20); OCR2 = 0x64; // 40kHz @8MHz crystal ADCSRA = 0x00; // ADC off // Analog comparator: ACSR = 0x02; // Generate interrupt on falling edge ADMUX = 0x03; // Multiplexer for comparator to // ADC pin 3 SFIOR |= (1 << ACME); // Enable muliplexing of comparator DDRD &= ~(1 << 6); // Port D Pin 6 is input! } void Ping(unsigned char length) { count72kHz = 0; TCCR2 = (1 << WGM21) | (1 << COM20) | (1 << CS20); // Toggling of IO-Pin on // generate the Chirp while(count72kHz < length) { OCR2 = 0x64 + length / 2 - count72kHz; } TCCR2 = (1 << WGM21) | (1 << CS20); // Toggling of IO-Pin off OCR2 = 0x64; // set frequency to 40kHz } int main(void) { int pos, i; int posmarker; Init(); LocalInit(); while(TRUE) { posmarker = 0; Ping(20); for(pos = 0; pos < 100; pos++) { Sleep(10); if((ACSR & (1 << ACI)) != 0) { if(posmarker == 0) { posmarker = pos; } } ACSR |= (1 << ACI); } if(posmarker > 10) { StatusLED(GREEN); MotorDir(FWD, FWD); MotorSpeed(200, 200); } else { StatusLED(RED); MotorDir(RWD, FWD); MotorSpeed(200, 0); for(i = 0; i<10; i++) { Sleep(200); } } } return 0; }
Zitieren
