Ja natürlich, das regfile muss rein. Hier mein I2C_LCD_Testcode:
mfgCode:$regfile = "m2560def.dat" $hwstack = 82 '80 $framesize = 68 '64 $swstack = 68 '44 $crystal = 16000000 'Quarzfrequenz $baud = 9600 $lib "Lcd_i2c.lib" 'My I2C driver for the LCD Config I2cdelay = 1 Const Pcf8574_lcd = 64 'Defines the address of the I/O expander for LCD 'Config Portd.0 = Input 'Config Portd.1 = Input 'Portd.0 = 1 'Portd.1 = 1 Config Scl = Portd.0 'Configure I2C SCL Config Sda = Portd.1 'Configure I2C SDA Dim _lcd_e As Byte 'Needed to control 4 line LCD Enable Interrupts '_lcd_e = 128 select E1, 64 select E2, 192 select both (for CLS or DefLCDChar etc.) _lcd_e = 128 'Upper half of 4-line display is selected Dim A As Byte Config Lcd = 20 * 4 'configure lcd screen Start: Cls 'clear the LCD display Lcd "1. Zeile" 'display this at the top line Wait 2 Lowerline 'select the lower line Wait 1 Lcd "2. Zeile" 'display this at the lower line Wait 2 Upperline Locate 1 , 21 'set cursor position to 3. zeile, 1. Zeichen Lcd "3. Zeile" 'display this Wait 2 'wait a moment Lowerline Locate 2 , 21 'set cursor position to 3. zeile, 1. Zeichen Lcd "4. Zeile" 'display this Wait 2 'wait a moment Goto Start End
Stefan
Zitieren
