Also die Verzeichnisstruktur sieht bei mir so aus:
Das Makefile sieht so aus:Code:C:\RP6Examples\ -RP6BASE_EXAMPLES -Test -Test.c -makefile -make_all.bat -make_clean.bat -RP6CONTROL_EXAMPLES -RP6Lib
Code:TARGET = Test RP6_LIB_PATH=../../RP6lib RP6_LIB_PATH_OTHERS= $(RP6_LIB_PATH)/RP6base $(RP6_LIB_PATH)/RP6common SRC = $(TARGET).c MCU = atmega32 FORMAT = ihex ASRC= DEBUG =dwarf-2 EXTRAINCDIRS = $(RP6_LIB_PATH) $(RP6_LIB_PATH_OTHERS) CSTANDARD = -std=gnu99 CDEFS = -DDEBUG_MEASURE_DUTY_CYCLE CINCS = CFLAGS = -g$(DEBUG) CFLAGS += $(CDEFS) $(CINCS) CFLAGS += -O$(OPT) CFLAGS += -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums CFLAGS += -Wall -Wstrict-prototypes CFLAGS += -Wa,-adhlns=$(<:.c=.lst) CFLAGS += $(patsubst %,-I%,$(EXTRAINCDIRS)) CFLAGS += $(CSTANDARD) PRINTF_LIB_MIN = -Wl,-u,vfprintf -lprintf_min PRINTF_LIB_FLOAT = -Wl,-u,vfprintf -lprintf_flt PRINTF_LIB = SCANF_LIB_MIN = -Wl,-u,vfscanf -lscanf_min SCANF_LIB_FLOAT = -Wl,-u,vfscanf -lscanf_flt SCANF_LIB = MATH_LIB = -lm EXTMEMOPTS = LDFLAGS = -Wl,-Map=$(TARGET).map,--cref LDFLAGS += $(EXTMEMOPTS) LDFLAGS += $(PRINTF_LIB) $(SCANF_LIB) $(MATH_LIB) AVRDUDE_PROGRAMMER = stk500 AVRDUDE_PORT = com1 # Programmer connected to serial device AVRDUDE_WRITE_FLASH = -U flash:w:$(TARGET).hex AVRDUDE_FLAGS = -p $(MCU) -P $(AVRDUDE_PORT) -c $(AVRDUDE_PROGRAMMER) AVRDUDE_FLAGS += $(AVRDUDE_NO_VERIFY) AVRDUDE_FLAGS += $(AVRDUDE_VERBOSE) AVRDUDE_FLAGS += $(AVRDUDE_ERASE_COUNTER) DEBUG_MFREQ = $(F_CPU) DEBUG_UI = insight DEBUG_BACKEND = avarice GDBINIT_FILE = __avr_gdbinit JTAG_DEV = /dev/com1 DEBUG_PORT = 4242 DEBUG_HOST = localhost SHELL = sh CC = avr-gcc OBJCOPY = avr-objcopy OBJDUMP = avr-objdump SIZE = avr-size NM = avr-nm AVRDUDE = avrdude REMOVE = rm -f REMOVEDIR = rmdir COPY = cp WINSHELL = cmd MSG_ERRORS_NONE = Errors: none MSG_BEGIN = -------- begin -------- MSG_END = -------- end -------- MSG_SIZE_BEFORE = Size before: MSG_SIZE_AFTER = Size after: MSG_COFF = Converting to AVR COFF: MSG_EXTENDED_COFF = Converting to AVR Extended COFF: MSG_FLASH = Creating load file for Flash: MSG_EEPROM = Creating load file for EEPROM: MSG_EXTENDED_LISTING = Creating Extended Listing: MSG_SYMBOL_TABLE = Creating Symbol Table: MSG_LINKING = Linking: MSG_COMPILING = Compiling: MSG_ASSEMBLING = Assembling: MSG_CLEANING = Cleaning project: OBJ = $(SRC:.c=.o) $(ASRC:.S=.o) LST = $(SRC:.c=.lst) $(ASRC:.S=.lst) GENDEPFLAGS = -MD -MP -MF .dep/$(@F).d ALL_CFLAGS = -mmcu=$(MCU) -I. $(CFLAGS) $(GENDEPFLAGS) ALL_ASFLAGS = -mmcu=$(MCU) -I. -x assembler-with-cpp $(ASFLAGS) all: begin gccversion sizebefore build sizeafter end build: elf hex eep lss sym elf: $(TARGET).elf hex: $(TARGET).hex eep: $(TARGET).eep lss: $(TARGET).lss sym: $(TARGET).sym begin: @echo @echo $(MSG_BEGIN) end: @echo $(MSG_END) @echo HEXSIZE = $(SIZE) --target=$(FORMAT) $(TARGET).hex ELFSIZE = $(SIZE) --format=avr --mcu=$(MCU) $(TARGET).elf sizebefore: @if test -f $(TARGET).elf; then echo; echo $(MSG_SIZE_BEFORE); $(ELFSIZE); \ 2>/dev/null; echo; fi sizeafter: @if test -f $(TARGET).elf; then echo; echo $(MSG_SIZE_AFTER); $(ELFSIZE); \ 2>/dev/null; echo; fi gccversion : @$(CC) --version program: $(TARGET).hex $(TARGET).eep $(AVRDUDE) $(AVRDUDE_FLAGS) $(AVRDUDE_WRITE_FLASH) $(AVRDUDE_WRITE_EEPROM) gdb-config: @$(REMOVE) $(GDBINIT_FILE) @echo define reset >> $(GDBINIT_FILE) @echo SIGNAL SIGHUP >> $(GDBINIT_FILE) @echo end >> $(GDBINIT_FILE) @echo file $(TARGET).elf >> $(GDBINIT_FILE) @echo target remote $(DEBUG_HOST):$(DEBUG_PORT) >> $(GDBINIT_FILE) ifeq ($(DEBUG_BACKEND),simulavr) @echo load >> $(GDBINIT_FILE) endif @echo break main >> $(GDBINIT_FILE) debug: gdb-config $(TARGET).elf ifeq ($(DEBUG_BACKEND), avarice) @echo Starting AVaRICE - Press enter when "waiting to connect" message displays. @$(WINSHELL) /c start avarice --jtag $(JTAG_DEV) --erase --program --file \ $(TARGET).elf $(DEBUG_HOST):$(DEBUG_PORT) @$(WINSHELL) /c pause else @$(WINSHELL) /c start simulavr --gdbserver --device $(MCU) --clock-freq \ $(DEBUG_MFREQ) --port $(DEBUG_PORT) endif @$(WINSHELL) /c start avr-$(DEBUG_UI) --command=$(GDBINIT_FILE) COFFCONVERT=$(OBJCOPY) --debugging \ --change-section-address .data-0x800000 \ --change-section-address .bss-0x800000 \ --change-section-address .noinit-0x800000 \ --change-section-address .eeprom-0x810000 coff: $(TARGET).elf @echo @echo $(MSG_COFF) $(TARGET).cof $(COFFCONVERT) -O coff-avr $< $(TARGET).cof extcoff: $(TARGET).elf @echo @echo $(MSG_EXTENDED_COFF) $(TARGET).cof $(COFFCONVERT) -O coff-ext-avr $< $(TARGET).cof %.hex: %.elf @echo @echo $(MSG_FLASH) $@ $(OBJCOPY) -O $(FORMAT) -R .eeprom $< $@ %.eep: %.elf @echo @echo $(MSG_EEPROM) $@ -$(OBJCOPY) -j .eeprom --set-section-flags .eeprom=alloc,load \ --change-section-lma .eeprom=0 --no-change-warnings -O $(FORMAT) $< $@ || exit 0 %.lss: %.elf @echo @echo $(MSG_EXTENDED_LISTING) $@ $(OBJDUMP) -h -S $< > $@ %.sym: %.elf @echo @echo $(MSG_SYMBOL_TABLE) $@ $(NM) -n $< > $@ .SECONDARY : $(TARGET).elf .PRECIOUS : $(OBJ) %.elf: $(OBJ) @echo @echo $(MSG_LINKING) $@ $(CC) $(ALL_CFLAGS) $^ --output $@ $(LDFLAGS) %.o : %.c @echo @echo $(MSG_COMPILING) $< $(CC) -c $(ALL_CFLAGS) $< -o $@ %.s : %.c $(CC) -S $(ALL_CFLAGS) $< -o $@ %.o : %.S @echo @echo $(MSG_ASSEMBLING) $< $(CC) -c $(ALL_ASFLAGS) $< -o $@ %.i : %.c $(CC) -E -mmcu=$(MCU) -I. $(CFLAGS) $< -o $@ clean: begin clean_list end clean_list : @echo @echo $(MSG_CLEANING) include $(shell mkdir .dep 2>/dev/null) $(wildcard .dep/*) .PHONY : all begin finish end sizebefore sizeafter gccversion \ build elf hex eep lss sym coff extcoff \ clean clean_list program debug gdb-config
Zitieren
