Ergebnis 1 bis 7 von 7
Thema: MSC Bootloader & M644p => Hilfe
    Hinsdorf
    ich bin eben dabei mir den Bootloader von MSC so umzuschreiben das ich ihn mit einem Mega644p nutzen kann. Leider bekomme ich es nicht hin:
    '                          (c) 1995-2007, MCS
    '                        Bootloader.bas
    '  This sample demonstrates how you can write your own bootloader
    '  in Bascom BASIC
    '  VERSION 2 of the BOOTLOADER. The waiting for the NAK is stretched
    '  further a bug was resolved for the M64/M128 that have a big page size
    'This sample will be extended to support other chips with bootloader
    'The loader is supported from the IDE
    $crystal = 12000000
    '$crystal = 14745600
    $baud = 38400        'this loader uses serial com
    'It is VERY IMPORTANT that the baud rate matches the one of the boot loader
    'do not try to use buffered com as we can not use interrupts
    $regfile = "m644pdef.dat"
    'Const Loaderchip = 32
    '#if Loaderchip = 32                                                             ' Mega32
        $loader = $7c00                                                             ' 1024 words
        Const Maxwordbit = 6                                                        'Z6 is maximum bit                                   '
        Config Com1 = Dummy , Synchrone = 0 , Parity = None , Stopbits = 1 , Databits = 8 , Clockpol = 0
    '#endif
    Const Maxword =(2 ^ Maxwordbit) * 2                                             '128
    Const Maxwordshift = Maxwordbit + 1
    Const Cdebug = 0        ' leave this to 0
    #if Cdebug
       Print Maxword
       Print Maxwordshift
    #endif
    'Dim the used variables
    Dim Bstatus As Byte , Bretries As Byte , Bblock As Byte , Bblocklocal As Byte
    Dim Bcsum1 As Byte , Bcsum2 As Byte , Buf(128) As Byte , Csum As Byte
    Dim J As Byte , Spmcrval As Byte                                                ' self program command byte value
    Dim Z As Long        'this is the Z pointer word
    Dim Vl As Byte , Vh As Byte                                                     ' these bytes are used for the data values
    Dim Wrd As Word , Page As Word                                                  'these vars contain the page and word address
    Dim Bkind As Byte , Bstarted As Byte
    'Mega 88 : 32 words, 128 pages
    Disable Interrupts                                                              'we do not use ints
    'Waitms 100                                                  'wait 100 msec sec
    'We start with receiving a file. The PC must send this binary file
    'some constants used in serial com
    Const Nak = &H15
    Const Ack = &H06
    Const Can = &H18
    '(we use some leds as indication in this sample , you might want to remove it
    Config Pina.7 = Output
    Porta.7 = 1        'the stk200 has inverted logic for the leds
    Config Pina.6 = Output
    Porta.6 = 1
    $timeout = 400000                                                               'we use a timeout
    'When you get LOADER errors during the upload, increase the timeout value
    'for example at 16 Mhz, use 200000
    Bretries = 5        'we try 5 times
    Testfor123:
    #if Cdebug
        Print "Try " ; Bretries
        Print "Wait"
    #endif
    Bstatus = Waitkey()                                                             'wait for the loader to send a byte
    #if Cdebug
       Print "Got "
    #endif
    Print Chr(bstatus);
    If Bstatus = 123 Then                                                           'did we received value 123 ?
       Bkind = 0        'normal flash loader
       Goto Loader
    Elseif Bstatus = 124 Then                                                       ' EEPROM
       Bkind = 1        ' EEPROM loader
       Goto Loader
    Elseif Bstatus <> 0 Then
       Decr Bretries
       If Bretries <> 0 Then Goto Testfor123                                        'we test again
    End If
    For J = 1 To 10        'this is a simple indication that we start the normal reset vector
       Toggle Portb.0 : Waitms 100
    Next
    #if Cdebug
      Print "RESET"
    #endif
    Goto _reset        'goto the normal reset vector at address 0
    'this is the loader routine. It is a Xmodem-checksum reception routine
    Loader:
      #if Cdebug
          Print "Clear buffer"
      #endif
         Bstatus = Waitkey()
      Loop Until Bstatus = 0
      For J = 1 To 3        'this is a simple indication that we start the normal reset vector
         Toggle Portb.0 : Waitms 50
      Next
      If Bkind = 0 Then
         Spmcrval = 3 : Gosub Do_spm                                                ' erase  the first page
         Spmcrval = 17 : Gosub Do_spm                                               ' re-enable page
      End If
    Bretries = 10        'number of retries
      Bstarted = 0        ' we were not started yet
      Csum = 0        'checksum is 0 when we start
      Print Chr(nak);                                                               ' firt time send a nack
        Bstatus = Waitkey()                                                         'wait for statuse byte
        Select Case Bstatus
           Case 1:        ' start of heading, PC is ready to send
                Incr Bblocklocal                                                    'increase local block count
                Csum = 1                                                            'checksum is 1
                Bblock = Waitkey() : Csum = Csum + Bblock                           'get block
                Bcsum1 = Waitkey() : Csum = Csum + Bcsum1                           'get checksum first byte
                For J = 1 To 128                                                    'get 128 bytes
                  Buf(j) = Waitkey() : Csum = Csum + Buf(j)
                Next
                Bcsum2 = Waitkey()                                                  'get second checksum byte
                If Bblocklocal = Bblock Then                                        'are the blocks the same?
                   If Bcsum2 = Csum Then                                            'is the checksum the same?
                      Gosub Writepage                                               'yes go write the page
                      Print Chr(ack);                                               'acknowledge
                   Else                                                             'no match so send nak
                      Print Chr(nak);
                   End If
                Else
                   Print Chr(nak);                                                  'blocks do not match
                End If
           Case 4:        ' end of transmission , file is transmitted
                 If Wrd > 0 And Bkind = 0 Then                                      'if there was something left in the page
                     Wrd = 0                                                        'Z pointer needs wrd to be 0
                     Spmcrval = 5 : Gosub Do_spm                                    'write page
                 End If
                 Print Chr(ack);                                                    ' send ack and ready
                 Portb.3 = 0                                                        ' simple indication that we are finished and ok
                 Waitms 20
                 Goto _reset                                                        ' start new program
           Case &H18:                                                               ' PC aborts transmission
                 Goto _reset                                                        ' ready
           Case 123 : Exit Do                                                       'was probably still in the buffer
           Case 124 : Exit Do
           Case Else
              Exit Do                                                               ' no valid data
        End Select
      If Bretries > 0 Then                                                          'attempte left?
         Waitms 1000
         Decr Bretries                                                              'decrease attempts
      Else
         Goto _reset        'reset chip
      End If
    'write one or more pages
    Writepage:
     If Bkind = 0 Then
       For J = 1 To 128 Step 2                                                      'we write 2 bytes into a page
          Vl = Buf(j) : Vh = Buf(j + 1)                                             'get Low and High bytes
          lds r0, {vl}                                                              'store them into r0 and r1 registers
          lds r1, {vh}
          Spmcrval = 1 : Gosub Do_spm                                               'write value into page at word address
          Wrd = Wrd + 2                                                             ' word address increases with 2 because LS bit of Z is not used
          If Wrd = Maxword Then                                                     ' page is full
              Page = Page + 1                                                       'next page
              Spmcrval = 3 : Gosub Do_spm                                           ' erase  next page
          End If
       Next
     Else        'eeprom
         For J = 1 To 128
           Writeeeprom Buf(j) , Wrd
           Wrd = Wrd + 1
         Next
     End If
     Toggle Portb.2 : Waitms 10 : Toggle Portb.2                                    'indication that we write
    Return
    Do_spm:
      Bitwait Spmcsr.0 , Reset                                                      ' check for previous SPM complete
      Bitwait Eecr.1 , Reset                                                        'wait for eeprom
      Z = Page        'make equal to page
      Shift Z , Left , Maxwordshift                                                 'shift to proper place
      Z = Z + Wrd        'add word
      lds r30,{Z}
      lds r31,{Z+1}
      #if _romsize > 65536
          lds r24,{Z+2}
          sts rampz,r24                                                             ' we need to set rampz also for the M128
      #endif
      Spmcsr = Spmcrval                                                             'assign register
      spm        'this is an asm instruction
      nop
      nop
    Return
    Ich hatte diesen schon erfolgreich an einem M32 und M128 am laufen, aber beim Mega644p läuft er irgend wie nicht. Was ist an dem Code falsch?
    Gruß MAT
    Hinsdorf
    Hallo Leut's,
    ich habe nun nach langem suchen das Problem gefunden:
    Fusebit C: division by 8 muss auf "disable" stehen und dann funktioniert dieser Code:
    '                          (c) 1995-2009, MCS
    '                        Bootloader.bas
    '  in Bascom BASIC
    '$crystal = 8000000
    $crystal = 14745600
    $baud = 57600        'this loader uses serial com
    '$regfile = "m8def.dat"
    'Const Loaderchip = 8
    '$regfile = "m168def.dat"
    'Const Loaderchip = 168
    '$regfile = "m16def.dat"
    '$regfile = "m32def.dat"
    '$regfile = "m88def.dat"
    'Const Loaderchip = 88
    '$regfile = "m162def.dat"
    'Const Loaderchip = 162
    '$regfile = "m8515.dat"
    'Const Loaderchip = 8515
    '$regfile = "m128def.dat"
    'Const Loaderchip = 128
    '$regfile = "m64def.dat"
    'Const Loaderchip = 64
    '$regfile = "m2561def.dat"
    'Const Loaderchip = 2561
    '$regfile = "m2560def.dat"
    'Const Loaderchip = 2560
    '$regfile = "m329def.dat"
    'Const Loaderchip = 329
    '$regfile = "m324pdef.dat"
    'Const Loaderchip = 324
    $regfile = "m644def.dat"
    Const Loaderchip = 644
    #if Loaderchip = 88                                                             'Mega88
        $loader = $c00                                                              'this address you can find in the datasheet
        'the loader address is the same as the boot vector address
        Const Maxwordbit = 5
    #endif
    #if Loaderchip = 168                                                            'Mega168
        $loader = $1c00                                                             'this address you can find in the datasheet
    #endif
        $loader = $3c00                                                             ' 1024 words
    #endif
    #if Loaderchip = 8                                                              ' Mega8
        $loader = $c00                                                              ' 1024 words
        Const Maxwordbit = 5                                                        'Z5 is maximum bit                                   '
    #endif
    #if Loaderchip = 161                                                            ' Mega161
        $loader = $1e00                                                             ' 1024 words
    #endif
    #if Loaderchip = 162                                                            ' Mega162
        $loader = $1c00                                                             ' 1024 words
    #endif
    #if Loaderchip = 8515                                                           ' Mega8515
        Const Maxwordbit = 5                                                        'Z6 is maximum bit                                   '
        Osccal = &HB3                                                               ' the internal osc needed a new value
    #endif
    #if Loaderchip = 64                                                             ' Mega64
        Const Maxwordbit = 7                                                        'Z7 is maximum bit                                   '
    #endif
    #if Loaderchip = 128                                                            ' Mega128
        $loader = &HFC00                                                            ' 1024 words
    #endif
    #if Loaderchip = 2561                                                           ' Mega2561
        $loader = &H1FC00                                                           ' 1024 words
    #endif
    #if Loaderchip = 2560                                                           ' Mega2560
    #endif
    #if Loaderchip = 16                                                             ' Mega16
    #endif
    #if Loaderchip = 329                                                            ' Mega32
    #endif
    #if Loaderchip = 324                                                            ' Mega32
    #endif
    #if Loaderchip = 644                                                            ' Mega644P
    #endif
    Const Cdebug = 1        ' leave this to 0
    #if Cdebug
       Print Maxword
       Print Maxwordshift
    #endif
    Const Nak = &H15
    Const Ack = &H06
    Const Can = &H18
    'we use some leds as indication in this sample , you might want to remove it
    Config Pinb.2 = Output
    Portb.2 = 1        'the stk200 has inverted logic for the leds
    Config Pinb.3 = Output
    Portb.3 = 1
    Testfor123:
    #if Cdebug
        Print "Wait"
    #endif
    #if Cdebug
       Print "Got "
    #endif
    Print Chr(bstatus);
       Goto Loader
       Goto Loader
       Decr Bretries
    End If
       Toggle Portb.2 : Waitms 100
    Next
    #if Cdebug
      Print "RESET"
    #endif
    Loader:
      #if Cdebug
      #endif
         Bstatus = Waitkey()
         Toggle Portb.2 : Waitms 50
      Next
      If Bkind = 0 Then
      End If
        Select Case Bstatus
                Next
                      Print Chr(nak);
                   End If
                Else
                End If
                 End If
                 Waitms 20
                 Goto _reset                                                        ' ready
           Case 124 : Exit Do
           Case Else
        End Select
         Waitms 1000
      Else
      End If
    Writepage:
     If Bkind = 0 Then
          lds r1, {vh}
          End If
       Next
     Else        'eeprom
         For J = 1 To 128
           Wrd = Wrd + 1
         Next
     End If
    Return
    Do_spm:
      lds r30,{Z}
      lds r31,{Z+1}
      nop
      nop
    Return
    'How you need to use this program:
    '1- compile this program
    '2- program into chip with sample elctronics Programmer
    '3- select MCS Bootloader from programmers
    '4- compile a new program for example M88.bas
    '5- press F4 and reset your micro
    ' the program will now be uploaded into the chip with Xmodem Checksum
    ' you can write your own loader.too
    'A stand alone command line loader is also available
    'How to call the bootloader from your program without a reset ???
    'Do
    '   Print "test"
    '   Waitms 1000
    '   If Inkey() = 27 Then
    '      Print "boot"
    '      Goto &H1C00
    '   End If
    'Loop
    'The GOTO will do the work, you need to specify the correct bootloader address
    'this is the same as the $LOADER statement.
    Soooo, jetzt kann das proggen wieder weiter gehen Bild
    MAT
    Schifferstadt
    ich hätte da auch noch so ein problem mit meinem mega644p und dem Bootloader. Ich benutze folgenden Code:
    '                          (c) 1995-2005, MCS
    '                        Bootloader.bas
    '  in Bascom BASIC
    $crystal = 18432000
        $loader = $7c00
                                                 ' leave this to 0
    Const Nak = &H15
    Const Ack = &H06
    Const Can = &H18
    Config Pind.7 = Output
    Portd.7 = 1                                                 'the stk200 has inverted logic for the leds
    $timeout = 200000                                           'we use a timeout
    Testfor123:
    Print Chr(bstatus);
       Goto Loader
       Goto Loader
       Decr Bretries
    End If
       Toggle Portd.7 : Waitms 100
    Next
    Loader:
         Bstatus = Waitkey()
         Toggle Portd.7 : Waitms 50
      Next
      If Bkind = 0 Then
      End If
        Select Case Bstatus
                Next
                      Print Chr(nak);
                   End If
                Else
                End If
                 If Wrd > 0 Then                                'if there was something left in the page
                 End If
                 Portd.7 = 0                                    ' simple indication that we are finished and ok
                 Waitms 20
                 Goto _reset                                    ' ready
           Case 124 : Exit Do
           Case Else
        End Select
         Waitms 1000
      Else
      End If
    Writepage:
     If Bkind = 0 Then
          lds r1, {vh}
          End If
       Next
     Else                                                       'eeprom
         For J = 1 To 128
           Wrd = Wrd + 1
         Next
     End If
     Toggle Portd.7 : Waitms 10 : Toggle Portd.7                'indication that we write
    Return
    Do_spm:
      lds r30,{Z}
      lds r31,{Z+1}
      nop
      nop
    Return
    Die Fuses habe ich folgendermaßen eingestellt.
    - Boot Flash section Size = 1024 words
    - Boot Start Adress = 0x7c00
    - Boot Reset Vector enabled
    Beim starten blinkt meine Led. Wenn ich den MCS Bootloader starte und dann auf upload gehe wird die Datei auch übertragen. Doch nachdem die Datei übertragen wurde, blinkt die Led wieder wie vorher. Das geladene Programm wird garnicht gestartet.
    Hat jemand ne idee, an was das liegen könnte ?
    Gruß Kay
    Hinsdorf
    Hi BlaueLed,
    Wichtig sind zu erst die Fusebits siehe Anhang.
    Dann schau mal, ob der Bootloadercode auch ab F800 beginnt und bis fde0 geht.
    Ansonsten fällt mir da auch nichts mehr ein.....
    Gruß MAT
    Miniaturansichten angehängter Grafiken Miniaturansichten angehängter Grafiken unbenannt_368.jpg
    Schifferstadt
    Hallo mat-sche,
    die fuses stimmen und der Code fängt auch erst ab F800 an. Mittlerweile bin ich ein wenig am verzweifeln. Wäre es möglich, das Du mir dein Code als Hex mal sendest, damit ich den einfach mal brennen kann, um zu sehen, an was es hängt ? Ich verwende allerdings einen 18,4320 Mhz Quarz.
    Gruß BlaueLed
    Schifferstadt
    es funktioniert. Es lag nicht am Bootloader oder an den Fuses. Es lag an der Bascom Version. Ich hatte die 1.11.9.2 build 1. Ich habe ein Update auf 1.11.9.4 gemacht und siehe da, nachdem ich mit der neuen Version compiliert habe läuft der Bootloader.
    Gruß Kay
    Hinsdorf
    na also! Geht doch Bild
    Nicht aufgeben ist die Devise Bild   . Na dann kann es ja reichlich weiter mit dem proggen gehen!
    MAT
