Ergebnis 11 bis 13 von 13
Thema: fehler beim kompilieren
    Ok werde ich mal studieren
    Gruß smusmuth
    hallo,
    ich habe ein ähnliches problem . . . ich hab WinXP und WinAVR-20090313.
    wenn ich etwas kompilen will kommt diese fehler meldung:
    > "make.exe" all
    -------- begin --------
    avr-gcc (WinAVR 20090313) 4.3.2
    Copyright (C) 2008 Free Software Foundation, Inc.
    This is free software; see the source for copying conditions.  There is NO
    warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
    Compiling: ../../RP6Lib/RP6base/RP6RobotBaseLib.c
    avr-gcc -c -mmcu=atmega32 -I. -gdwarf-2   -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=../../RP6Lib/RP6base/RP6RobotBaseLib.lst -I../../RP6Lib -I../../RP6Lib/RP6base -I../../RP6Lib/RP6common -std=gnu99 -MD -MP -MF .dep/RP6RobotBaseLib.o.d ../../RP6Lib/RP6base/RP6RobotBaseLib.c -o ../../RP6Lib/RP6base/RP6RobotBaseLib.o
    Compiling: RP6BaseServoLib.c
    avr-gcc -c -mmcu=atmega32 -I. -gdwarf-2   -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=RP6BaseServoLib.lst -I../../RP6Lib -I../../RP6Lib/RP6base -I../../RP6Lib/RP6common -std=gnu99 -MD -MP -MF .dep/RP6BaseServoLib.o.d RP6BaseServoLib.c -o RP6BaseServoLib.o
    Compiling: ../../RP6Lib/RP6common/RP6uart.c
    avr-gcc -c -mmcu=atmega32 -I. -gdwarf-2   -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=../../RP6Lib/RP6common/RP6uart.lst -I../../RP6Lib -I../../RP6Lib/RP6base -I../../RP6Lib/RP6common -std=gnu99 -MD -MP -MF .dep/RP6uart.o.d ../../RP6Lib/RP6common/RP6uart.c -o ../../RP6Lib/RP6common/RP6uart.o
    Linking: RP6_Prog_ADC0.elf
    avr-gcc -mmcu=atmega32 -I. -gdwarf-2   -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=../../RP6Lib/RP6base/RP6RobotBaseLib.o -I../../RP6Lib -I../../RP6Lib/RP6base -I../../RP6Lib/RP6common -std=gnu99 -MD -MP -MF .dep/RP6_Prog_ADC0.elf.d ../../RP6Lib/RP6base/RP6RobotBaseLib.o RP6BaseServoLib.o ../../RP6Lib/RP6common/RP6uart.o --output RP6_Prog_ADC0.elf -Wl,-Map=RP6_Prog_ADC0.map,--cref    -lm
    c:/winavr-20090313/bin/../lib/gcc/avr/4.3.2/../../../../avr/lib/avr5/crtm32.o:(.init9+0x0): undefined reference to `main'
    make.exe: *** [RP6_Prog_ADC0.elf] Error 1
    > Process Exit Code: 2
    > Time Taken: 00:11
    ich weiß nicht an was es liegt aber es hat schon mal funktioniert und dann hab ich windows runter gemacht und neu drauf gmacht... und jetzt fehler...
    Gruß Robin
    Gibt es ne main()-Funktion in deinem Programm? Ohne die ist nicht klar, wo später mit der Ausführung des Programms angefangen werden soll. Jedes C-Programm muss genau eine main() enthalten, die beim Start des Programms (hier also beim Einschalten des RP6) automatisch aufgerufen wird.
