das mit den slashes hat mich auch schon gewundert, hier ist das makefile:
aber im makefile sind alle slashes und so doch correct oder nicht?Code:############################################################################### # Makefile for the project test ############################################################################### ## General Flags PROJECT = test MCU = atmega8 TARGET = test.elf CC = avr-gcc ## Options common to compile, link and assembly rules COMMON = -mmcu=$(MCU) ## Compile options common for all C compilation units. CFLAGS = $(COMMON) CFLAGS += -Wall -gdwarf-2 -Os -std=gnu99 -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums CFLAGS += -MD -MP -MT $(*F).o -MF dep/$(@F).d ## Assembly specific flags ASMFLAGS = $(COMMON) ASMFLAGS += $(CFLAGS) ASMFLAGS += -x assembler-with-cpp -Wa,-gdwarf2 ## Linker flags LDFLAGS = $(COMMON) LDFLAGS += -Wl,-Map=test.map ## Intel Hex file production flags HEX_FLASH_FLAGS = -R .eeprom -R .fuse -R .lock -R .signature HEX_EEPROM_FLAGS = -j .eeprom HEX_EEPROM_FLAGS += --set-section-flags=.eeprom="alloc,load" HEX_EEPROM_FLAGS += --change-section-lma .eeprom=0 --no-change-warnings ## Include Directories INCLUDES = -I"C:\Dokumente und Einstellungen\Dittay\Eigene Dateien\..\..\..\AsuroLib-v280rc1\lib\inc" ## Library Directories LIBDIRS = -L"C:\AsuroLib-v280rc1\lib" ## Libraries LIBS = -lasuro ## Objects that must be built in order to link OBJECTS = test.o ## Objects explicitly added by the user LINKONLYOBJECTS = ## Build all: $(TARGET) test.hex test.eep test.lss size ## Compile test.o: ../test.c $(CC) $(INCLUDES) $(CFLAGS) -c $< ##Link $(TARGET): $(OBJECTS) $(CC) $(LDFLAGS) $(OBJECTS) $(LINKONLYOBJECTS) $(LIBDIRS) $(LIBS) -o $(TARGET) %.hex: $(TARGET) avr-objcopy -O ihex $(HEX_FLASH_FLAGS) $< $@ %.eep: $(TARGET) -avr-objcopy $(HEX_EEPROM_FLAGS) -O ihex $< $@ || exit 0 %.lss: $(TARGET) avr-objdump -h -S $< > $@ size: ${TARGET} @echo @avr-size -C --mcu=${MCU} ${TARGET} ## Clean target .PHONY: clean clean: -rm -rf $(OBJECTS) test.elf dep/* test.hex test.eep test.lss test.map ## Other dependencies -include $(shell mkdir dep 2>/dev/null) $(wildcard dep/*)
also ich benutze generell das AVR Studio, heißt das makefile wird von da aus ja direkt umgesetzt oder?
was ich mit den Libs verändert hab, war schlicht und ergreifend dass ich denen mal einen anderen pfad gegeben habe, nachdem ich mir die AsuroLib-v280rc1 runtergeladen hab.
Irgendwann hab ich auch mal versucht ein makefile selbst zu schreiben, was allerdings nicht so recht funktioniert hat. Ich hab dann hier und da ein wenig rumgefummelt mit dem ergebnis, dass ich auch diese Fehlermeldung bekam... Seitdem funzt es irgendwie nicht mehr, allerdings hab ich auch vergessen, was ich da gemacht habeAber kann man es sich damit so versauen, dass es generell nicht mehr geht?
@wolfgang: das Programm lief vorher so wie es da steht![]()
Wie binde ich denn die Libs richtig ein? Also ich hab die Libs über die Properties im AVR Studio versucht einzubinden.
Zitieren
