Thema: PCF 8574 auslesen
    PCF 8574 auslesen
    Hallo zuasmmen,
    habe folgendes Problem:
    Lese mit einem Mega16 einen PCF8574 aus.
    dazu verwende ich folgende Standardroutinen:
    void pcf8574_init (void)
      /*set bus speed*/
      TWBR = 0x40;
    unsigned char pcf8574_send_start (void)
      /*writing a one to TWINT clears it, TWSTA=Start, TWEN=TWI-enable*/
      TWCR = (1<<TWINT) | (1<<TWSTA) | (1<<TWEN);
      /*wait, until start condition has been sent --> ACK*/
      while (!(TWCR & (1<<TWINT)));
      return TWSR;
    void pcf8574_send_stop (void)
      /*writing a one to TWINT clears it, TWSTO=Stop, TWEN=TWI-enable*/
      TWCR = (1<<TWINT) | (1<<TWSTO) | (1<<TWEN);
    unsigned char pcf8574_send_add_rw (unsigned char address, unsigned char rw)
      /*address can be 0 .. 8; rw=0 --> write, rw=1 --> read*/
      unsigned char addr_byte = 0;
      /*shift address one bit left*/
      addr_byte = address << 1;
      /*set RW-Bit, if necessary*/
      addr_byte |= rw;
      /*0b0100xxx0 --> address of Expander*/
      addr_byte |= 0b01000000;
      /*TWDR contains byte to send*/
      TWDR = addr_byte;
      /*send content of TWDR*/
      TWCR = (1<<TWINT) | (1<<TWEN);
      /*wait, until address has been sent --> ACK*/
      return TWSR;
    unsigned char pcf8574_send_byte (unsigned char byte)
      TWDR = byte;
      /*wait, until byte has been sent --> ACK*/
      return TWSR;
    unsigned char pcf8574_read_byte (void)
      /*send content of TWDR; TWEA = enable ACK*/
      TWCR = (1<<TWINT) | (1<<TWEA) | (1<<TWEN);
      /*wait, until byte has been received --> ACK*/
      return TWDR;
    unsigned char pcf8574_get_inputs (unsigned char address)
      pcf8574_init ();
      pcf8574_send_start ();
      pcf8574_send_add_rw (address, 1);
      unsigned char input = pcf8574_read_byte ();
      pcf8574_send_stop ();
      return input;
    void pcf8574_set_outputs (unsigned char address, unsigned char byte)
      pcf8574_init ();
      pcf8574_send_add_rw (address, 0);
      pcf8574_send_byte (byte);
    nimm bitte "code" und nicht "list" (PicNick, Mod.)
    Das ganze funktioniert so lange, bis ich den 8. Eingang auf low ziehe, ich bekomme dann einmalig die information, aber danach hängt sich die ganze Kommunikation über den IIC Bus auf und ich muss den uC wieder neu starten.
    Kann mir jemand erklären woran das liegt ??
    Ich habe schon herausgefunden, das sich die ganze Sache an folgender Stelle im send_start aufhängt
    Diese bedingung wird nicht erfüllt nur warum ??
    Vielen DAnk schon einmal im vorraus
    Hamburg
    Moin
    Uff.. .. also ich muss gestehen ich hab deinen Code nicht durchgearbeitet, da ich dazu grade keine Zeit habe, aber hier mal ein paar Standard-Tipps die mich bei I2C anfangs weitergebracht haben:
    1. Ja, du brauchst wirklcih zu extra Widerstände als PullUp, die internen vom Atmega reichen nicht aus.
    2. Anstand lange mit eigenem Code rum zu probieren hab ich lieber die fertige Lib genommen und dann zur Kapselung Funktionen außenrum geschrieben.
    http://jump.to/fleury und da auf AVR-Software - Libs
    Vll kann dir ja aber jemand anderes noch helfen, warum dein Code nicht geht.
    Andun
    www.subms.de
    habe fehler soeben gefunden Bild
    ich habe den TWEA gelöscht, da laut Datenblatt bei einem Lesevorgang kein ACK mehr zurück kommt, aber dennoch DAnke.
    P.S. Das ist ein fertiger Code, der nur ein wenig geändert wurde Bild
