Welche Version ist denn deine Lib? Das steht in asuro.c ganz oben. Ich verwende die ältere Version mit Wastes IR-Modifikation:
Die optimierten Versionen beginnen bei 2.7 oder so ... [Link]Code:/******************************************************************************* * * File Name: asuro.c * Project : ASURO * * Description: This file contains ASURO main features * * Ver. Date Author Comments * ------- ---------- -------------- ------------------------------ * 1.00 14.08.2003 Jan Grewe build * 2.00 14.10.2003 Jan Grewe LEFT_VEL, RIGHT_VEL -> MotorSpeed(unsigned char left_speed, unsigned char right_speed); * LeftRwd(),LeftFwd(),RightRwd(),RigthFwd() -> MotorDir(unsigned char left_dir, unsigned char right_dir); * GREEN_ON,GREEN_OFF,RED_ON,RED_OFF -> StatusLED(unsigned char color); * LED_RED_ON, LED_RED_OFF -> FrontLED(unsigned char color); * Blink(unsigned char left, unsigned char right) -> BackLED(unsigned char left, unsigned char right); * Alles in Funktionen gefasst => leichter verständlich ?!?! * 2.10 17.10.2003 Jan Grewe new Timer funktion void Sleep(unsigned char time36kHz) * * Copyright (c) 2003 DLR Robotics & Mechatronics *****************************************************************************/ /**************************************************************************** * * File Name: asuro.c * Project : asuro library "Robotrixer Buxtehude" * * Description: This file contains additional functions: * * signal (SIG_ADC) interrupt/signal routine for encoder-counter * signal (SIG_INTERRUPT1) signal for switches * Encoder_Init() initializing encoder-counter * Encoder_Start() start autoencoding * Encoder_Stop() stop autoencoding * Encoder_Set(int,int) set encodervalue * Msleep(int delay) wait for delay in milliseconds * Gettime() get systemtime in milliseconds * PrintInt(int) * * modifications in Sleep, SIG_OUTPUT_COMPARE2, PollSwitch, LineData * * Ver. Date Author Comments * ------- ---------- -------------- ------------------------------ * beta1 31.03.2005 Robotrixer asuro library * ------- ---------- -------------- ------------------------------ * the encoder source is based on RechteckDemo.c ver 2.0 by Jan Grewe 22.10.2003 * Copyright (c) 2003 DLR Robotics & Mechatronics *****************************************************************************/ /**************************************************************************** * * File Name: asuro.c * Project : asuro library modified for IR collision detector * * Description: modifications made in following functions: * * SIGNAL (SIG_OUTPUT_COMPARE2) -> SIGNAL (SIG_OVERFLOW2) * Gettime() counts now 36kHz * Init() timer2 modified for adjustable duty cycle * Batterie() bug fixed * Sleep() counts now 36kHz * Msleep() counts now 36kHz * * Ver. Date Author Comments * ------- ---------- -------------- ------------------------------ * beta2 11.06.2005 Waste asuro library * ------- ---------- -------------- ------------------------------ *****************************************************************************/
Zitieren
