Ganz so isses nicht: "adr" ist ja nur eine temporäre Variable für den Sub-Call
Code:Declare Sub Ds1820_temperature_read(byref Temperatur As Integer , Byref Adr As Word) Dim Addr As Word Dim Temperatur As Integer Addr = Loadlabel(sensor1) Call Ds1820_temperature_read(temperatur , Addr) Addr = Loadlabel(sensor2) Call Ds1820_temperature_read(temperatur , Addr) Addr = Loadlabel(sensor3) Call Ds1820_temperature_read(temperatur , Addr) End sub DS1820_TEMPERATURE_READ(byref Temperatur as Integer, byref adr as word) LOCAL ptr AS WORD LOCAL x as BYTE LOCAL rombyte as BYTE for x = 0 TO 7 ptr = adr+x rombyte = CPEEK(ptr) next End Sub Sensor1: Data 1, 2, 3, 4, 5, 6, 7, 8 Sensor2: Data 1, 2, 3, 4, 5, 6, 7, 8 Sensor3: Data 1, 2, 3, 4, 5, 6, 7, 8
Zitieren
