so stehst im der hilfe drin.
hast du ein eigenes board gebaut oder gekauft ??Code:$regfile = "m48def.dat" ' specify the used micro $crystal = 4000000 ' used crystal frequency $baud = 19200 ' use baud rate $hwstack = 32 ' default use 32 for the hardware stack $swstack = 10 ' default use 10 for the SW stack $framesize = 40 ' default use 40 for the frame space Config Debounce = 30 'when the config statement is not used a default of 25mS will be used but we override to use 30 mS 'Debounce Pind.0 , 1 , Pr 'try this for branching when high(1) Debounce Pind.0 , 0 , Pr , Sub Debounce Pind.0 , 0 , Pr , Sub ' ^----- label to branch to ' ^---------- Branch when P1.0 goes low(0) ' ^---------------- Examine P1.0 'When Pind.0 goes low jump to subroutine Pr 'Pind.0 must go high again before it jumps again 'to the label Pr when Pind.0 is low Debounce Pind.0 , 1 , Pr 'no branch Debounce Pind.0 , 1 , Pr 'will result in a return without gosub End Pr: Print "PIND.0 was/is low" Return
hast du einen int eingang belegt mit einem taster ?
Zitieren
